Project: 5742 (Run 3, Clone 4, Gen 8)
osgorth
Post by osgorth »
Failed instantly with an error I haven't seen before ("Self-test failure")
This is on a 4870x2 that is stable otherwise.
[00:04:43] Folding@Home GPU Core - Beta
[00:04:43] Version 1.18 (Mon Oct 13 11:11:30 PDT 2008)
[00:04:43]
[00:04:43] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[00:04:43] Build host: amoeba
[00:04:43] Board Type: AMD
[00:04:43] Core      :
[00:04:43] Preparing to commence simulation
[00:04:43] - Looking at optimizations...
[00:04:43] - Created dyn
[00:04:43] - Files status OK
[00:04:43] - Expanded 70207 -> 360060 (decompressed 512.8 percent)
[00:04:43] Called DecompressByteArray: compressed_data_size=70207 data_size=360060, decompressed_data_size=360060 diff=0
[00:04:43] - Digital signature verified
[00:04:43]
[00:04:43] Project: 5742 (Run 3, Clone 4, Gen 8)
[00:04:43]
[00:04:43] Assembly optimizations on if available.
[00:04:43] Entering M.D.
[00:04:49] Working on Protein
[00:04:49] Client config found, loading data.
[00:04:49] Starting GUI Server
[00:04:52] mdrun_gpu returned
[00:04:52] Self-test failure
[00:04:52]
[00:04:52] Folding@home Core Shutdown: UNSTABLE_MACHINE
[00:04:55] CoreStatus = 7A (122)
[00:04:55] Sending work to server
Re: Project: 5742 (Run 3, Clone 4, Gen 8)
It looks like you were able to complete it :
Hi osgorth (team 37451),
Your WU (P5742 R3 C4 G8) was added to the stats database on 2008-11-20 20:51:04 for 384 points of credit.
