Project: 5506 (Run 0, Clone 641, Gen 287)
osgorth
Post by osgorth »
Here's another instant EUE, killing two cards overnight :(
[04:04:42] Project: 5506 (Run 0, Clone 641, Gen 287)
[04:04:42]
[04:04:42] Assembly optimizations on if available.
[04:04:42] Entering M.D.
[04:04:49] Working on p5506_supervillin_e1
[04:04:50] Client config found, loading data.
[04:04:50] mdrun_gpu returned
[04:04:50] NANs detected on GPU
[04:04:50]
[04:04:50] Folding@home Core Shutdown: UNSTABLE_MACHINE
[04:04:54] CoreStatus = 7A (122)
Re: Project: 5506 (Run 0, Clone 641, Gen 287)
There is only one report in th DB, but it's an instant EUE too.
MrBooMY
Post by MrBooMY »
Instant EUEs until my folding stopped on one machine. It kept assigning the same WU for some odd reason. :evil:
[07:06:24]
[07:06:24] *------------------------------*
[07:06:24] Folding@Home GPU Core - Beta
[07:06:24] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[07:06:24]
[07:06:24] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[07:06:24] Build host: amoeba
[07:06:24] Board Type: Nvidia
[07:06:24] Core      :
[07:06:24] Preparing to commence simulation
[07:06:24] - Looking at optimizations...
[07:06:24] - Created dyn
[07:06:24] - Files status OK
[07:06:24] - Expanded 45482 -> 246249 (decompressed 541.4 percent)
[07:06:24] Called DecompressByteArray: compressed_data_size=45482 data_size=246249, decompressed_data_size=246249 diff=0
[07:06:24] - Digital signature verified
[07:06:24]
[07:06:24] Project: 5506 (Run 0, Clone 641, Gen 287)
[07:06:24]
[07:06:24] Assembly optimizations on if available.
[07:06:24] Entering M.D.
[07:06:30] Working on p5506_supervillin_e1
[07:06:31] Client config found, loading data.
[07:06:31] mdrun_gpu returned
[07:06:31] NANs detected on GPU
[07:06:31]
[07:06:31] Folding@home Core Shutdown: UNSTABLE_MACHINE
[07:06:35] CoreStatus = 7A (122)
[07:06:35] Sending work to server
[07:06:35] Project: 5506 (Run 0, Clone 641, Gen 287)
Reason: Added code tags.
dschief
Hardware configuration: Gigabyte Z790 UD AC , i7-14700K (x2) Win11
ASUS Z97_K , i5-4460 (x2) Win10 & UBUNTU 24.04
GPU's ASUS RTX1660 x2, RTX3050 x2
EVGA1060
Post by dschief »
this one got one of my boxes also;
[13:38:13] Folding@home Core Shutdown: FINISHED_UNIT
[13:38:17] CoreStatus = 64 (100)
[13:38:17] Unit 3 finished with 97 percent of time to deadline remaining.
[13:38:17] Updated performance fraction: 0.971524
[13:38:17] Sending work to server
[13:38:17] Project: 5506 (Run 7, Clone 260, Gen 284)
[13:38:17] - Read packet limit of 540015616... Set to 524286976.
[13:38:17] + Attempting to send results [November 24 13:38:17 UTC]
[13:38:17] - Reading file work/wuresults_03.dat from core
[13:38:17]   (Read 1293892 bytes from disk)
[13:38:17] Connecting to http://171.64.65.106:8080/
[13:38:49] Posted data.
[13:38:50] Initial: 0000; - Uploaded at ~38 kB/s
[13:38:50] - Averaged speed for that direction ~36 kB/s
[13:38:50] + Results successfully sent
[13:38:50] Thank you for your contribution to Folding@Home.
[13:38:50] + Number of Units Completed: 752
[13:38:54] Trying to send all finished work units
[13:38:54] + No unsent completed units remaining.
[13:38:54] - Preparing to get new work unit...
[13:38:54] + Attempting to get work packet
[13:38:54] - Will indicate memory of 2045 MB
[13:38:54] - Connecting to assignment server
[13:38:54] Connecting to http://assign-GPU.stanford.edu:8080/
[13:38:55] Posted data.
[13:38:55] Initial: 40AB; - Successful: assigned to (171.64.65.106).
[13:38:55] + News From Folding@Home: GPU folding beta
[13:38:55] Loaded queue successfully.
[13:38:55] Connecting to http://171.64.65.106:8080/
[13:38:55] Initial: 0000; - Receiving payload (expected size: 45994)
[13:38:55] Conversation time very short, giving reduced weight in bandwidth avg
[13:38:55] - Downloaded at ~89 kB/s
[13:38:55] - Averaged speed for that direction ~70 kB/s
[13:38:55] + Received work.
[13:38:55] Trying to send all finished work units
[13:38:55] + No unsent completed units remaining.
[13:38:55] + Closed connections
[13:38:55]
[13:38:55] + Processing work unit
[13:38:55] Core required: FahCore_11.exe
[13:38:55] Core found.
[13:38:55] Working on queue slot 04 [November 24 13:38:55 UTC]
[13:38:55] + Working ...
[13:38:55] - Calling '.\FahCore_11.exe -dir work/ -suffix 04 -priority 96 -nocpulock -checkpoint 15 -verbose -lifeline 3836 -version 620'
[13:38:55]
[13:38:55] *------------------------------*
[13:38:55] Folding@Home GPU Core - Beta
[13:38:55] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[13:38:55]
[13:38:55] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[13:38:55] Build host: amoeba
[13:38:55] Board Type: Nvidia
[13:38:55] Core      :
[13:38:55] Preparing to commence simulation
[13:38:55] - Looking at optimizations...
[13:38:55] - Created dyn
[13:38:55] - Files status OK
[13:38:55] - Expanded 45482 -> 246249 (decompressed 541.4 percent)
[13:38:55] Called DecompressByteArray: compressed_data_size=45482 data_size=246249, decompressed_data_size=246249 diff=0
[13:38:55] - Digital signature verified
[13:38:55]
[13:38:55] Project: 5506 (Run 0, Clone 641, Gen 287)
[13:38:55]
[13:38:55] Assembly optimizations on if available.
[13:38:55] Entering M.D.
[13:39:02] Working on p5506_supervillin_e1
[13:39:02] Client config found, loading data.
[13:39:02] Starting GUI Server
[13:39:02] mdrun_gpu returned
[13:39:02] NANs detected on GPU
[13:39:02]
[13:39:02] Folding@home Core Shutdown: UNSTABLE_MACHINE
[13:39:05] CoreStatus = 7A (122)
[13:39:05] Sending work to server
[13:39:05] Project: 5506 (Run 0, Clone 641, Gen 287)
[13:39:05] - Read packet limit of 540015616... Set to 524286976.
[13:39:05] - Error: Could not get length of results file work/wuresults_04.dat
[13:39:05] - Error: Could not read unit 04 file. Removing from queue.
[13:39:05] Trying to send all finished work units
[13:39:05] + No unsent completed units remaining.
[13:39:05] - Preparing to get new work unit...
[13:39:05] + Attempting to get work packet
[13:39:05] - Will indicate memory of 2045 MB
[13:39:05] - Connecting to assignment server
[13:39:05] Connecting to http://assign-GPU.stanford.edu:8080/
[13:39:06] Posted data.
[13:39:06] Initial: 40AB; - Successful: assigned to (171.64.65.106).
[13:39:06] + News From Folding@Home: GPU folding beta
[13:39:06] Loaded queue successfully.
[13:39:06] Connecting to http://171.64.65.106:8080/
[13:39:06] Initial: 0000; - Receiving payload (expected size: 45994)
[13:39:06] Conversation time very short, giving reduced weight in bandwidth avg
[13:39:06] - Downloaded at ~89 kB/s
[13:39:06] - Averaged speed for that direction ~72 kB/s
[13:39:06] + Received work.
[13:39:06] Trying to send all finished work units
[13:39:06] + No unsent completed units remaining.
[13:39:06] + Closed connections
[13:39:11]
[13:39:11] + Processing work unit
[13:39:11] Core required: FahCore_11.exe
[13:39:11] Core found.
[13:39:11] Working on queue slot 05 [November 24 13:39:11 UTC]
[13:39:11] + Working ...
[13:39:11] - Calling '.\FahCore_11.exe -dir work/ -suffix 05 -priority 96 -nocpulock -checkpoint 15 -verbose -lifeline 3836 -version 620'
[13:39:11]
[13:39:11] *------------------------------*
[13:39:11] Folding@Home GPU Core - Beta
[13:39:11] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[13:39:11]
[13:39:11] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[13:39:11] Build host: amoeba
[13:39:11] Board Type: Nvidia
[13:39:11] Core      :
[13:39:11] Preparing to commence simulation
[13:39:11] - Looking at optimizations...
[13:39:11] - Created dyn
[13:39:11] - Files status OK
[13:39:11] - Expanded 45482 -> 246249 (decompressed 541.4 percent)
[13:39:11] Called DecompressByteArray: compressed_data_size=45482 data_size=246249, decompressed_data_size=246249 diff=0
[13:39:11] - Digital signature verified
[13:39:11]
[13:39:11] Project: 5506 (Run 0, Clone 641, Gen 287)
[13:39:11]
[13:39:11] Assembly optimizations on if available.
[13:39:11] Entering M.D.
[13:39:18] Working on p5506_supervillin_e1
[13:39:18] Client config found, loading data.
[13:39:18] Starting GUI Server
[13:39:18] mdrun_gpu returned
[13:39:18] NANs detected on GPU
[13:39:18]
[13:39:18] Folding@home Core Shutdown: UNSTABLE_MACHINE
[13:39:22] CoreStatus = 7A (122)
[13:39:22] Sending work to server
[13:39:22] Project: 5506 (Run 0, Clone 641, Gen 287)
[13:39:22] - Read packet limit of 540015616... Set to 524286976.
[13:39:22] - Error: Could not get length of results file work/wuresults_05.dat
[13:39:22] - Error: Could not read unit 05 file. Removing from queue.
[13:39:22] Trying to send all finished work units
[13:39:22] + No unsent completed units remaining.
[13:39:22] - Preparing to get new work unit...
[13:39:22] + Attempting to get work packet
[13:39:22] - Will indicate memory of 2045 MB
[13:39:22] - Connecting to assignment server
[13:39:22] Connecting to http://assign-GPU.stanford.edu:8080/
[13:39:22] Posted data.
[13:39:22] Initial: 40AB; - Successful: assigned to (171.64.65.106).
[13:39:22] + News From Folding@Home: GPU folding beta
[13:39:22] Loaded queue successfully.
[13:39:22] Connecting to http://171.64.65.106:8080/
[13:39:22] Initial: 0000; - Receiving payload (expected size: 45994)
[13:39:22] Conversation time very short, giving reduced weight in bandwidth avg
[13:39:22] - Downloaded at ~89 kB/s
[13:39:22] - Averaged speed for that direction ~74 kB/s
[13:39:22] + Received work.
[13:39:22] + Closed connections
[13:39:27]
[13:39:27] + Processing work unit
[13:39:27] Core required: FahCore_11.exe
[13:39:27] Core found.
[13:39:27] Working on queue slot 06 [November 24 13:39:27 UTC]
[13:39:27] + Working ...
[13:39:27] - Calling '.\FahCore_11.exe -dir work/ -suffix 06 -priority 96 -nocpulock -checkpoint 15 -verbose -lifeline 3836 -version 620'
[13:39:27]
[13:39:27] *------------------------------*
[13:39:27] Folding@Home GPU Core - Beta
[13:39:27] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[13:39:27]
[13:39:27] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[13:39:27] Build host: amoeba
[13:39:27] Board Type: Nvidia
[13:39:27] Core      :
[13:39:27] Preparing to commence simulation
[13:39:27] - Looking at optimizations...
[13:39:27] - Created dyn
[13:39:27] - Files status OK
[13:39:27] - Expanded 45482 -> 246249 (decompressed 541.4 percent)
[13:39:27] Called DecompressByteArray: compressed_data_size=45482 data_size=246249, decompressed_data_size=246249 diff=0
[13:39:27] - Digital signature verified
[13:39:27]
[13:39:27] Project: 5506 (Run 0, Clone 641, Gen 287)
[13:39:27]
[13:39:27] Assembly optimizations on if available.
[13:39:27] Entering M.D.
[13:39:34] Working on p5506_supervillin_e1
[13:39:34] Client config found, loading data.
[13:39:34] Starting GUI Server
[13:39:34] mdrun_gpu returned
[13:39:34] NANs detected on GPU
[13:39:34]
[13:39:34] Folding@home Core Shutdown: UNSTABLE_MACHINE
[13:39:38] CoreStatus = 7A (122)
[13:39:38] Sending work to server
[13:39:38] Project: 5506 (Run 0, Clone 641, Gen 287)
[13:39:38] - Read packet limit of 540015616... Set to 524286976.
[13:39:38] - Error: Could not get length of results file work/wuresults_06.dat
[13:39:38] - Error: Could not read unit 06 file. Removing from queue.
[13:39:38] Trying to send all finished work units
[13:39:38] + No unsent completed units remaining.
[13:39:38] - Preparing to get new work unit...
[13:39:38] + Attempting to get work packet
[13:39:38] - Will indicate memory of 2045 MB
[13:39:38] - Connecting to assignment server
[13:39:38] Connecting to http://assign-GPU.stanford.edu:8080/
[13:39:38] Posted data.
[13:39:38] Initial: 40AB; - Successful: assigned to (171.64.65.106).
[13:39:38] + News From Folding@Home: GPU folding beta
[13:39:38] Loaded queue successfully.
[13:39:38] Connecting to http://171.64.65.106:8080/
[13:39:38] Initial: 0000; - Receiving payload (expected size: 45994)
[13:39:39] - Downloaded at ~44 kB/s
[13:39:39] - Averaged speed for that direction ~68 kB/s
[13:39:39] + Received work.
[13:39:39] Trying to send all finished work units
[13:39:39] + No unsent completed units remaining.
[13:39:39] + Closed connections
[13:39:44]
[13:39:44] + Processing work unit
[13:39:44] Core required: FahCore_11.exe
[13:39:44] Core found.
[13:39:44] Working on queue slot 07 [November 24 13:39:44 UTC]
[13:39:44] + Working ...
[13:39:44] - Calling '.\FahCore_11.exe -dir work/ -suffix 07 -priority 96 -nocpulock -checkpoint 15 -verbose -lifeline 3836 -version 620'
[13:39:44]
[13:39:44] *------------------------------*
[13:39:44] Folding@Home GPU Core - Beta
[13:39:44] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[13:39:44]
[13:39:44] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[13:39:44] Build host: amoeba
[13:39:44] Board Type: Nvidia
[13:39:44] Core      :
[13:39:44] Preparing to commence simulation
[13:39:44] - Looking at optimizations...
[13:39:44] - Created dyn
[13:39:44] - Files status OK
[13:39:44] - Expanded 45482 -> 246249 (decompressed 541.4 percent)
[13:39:44] Called DecompressByteArray: compressed_data_size=45482 data_size=246249, decompressed_data_size=246249 diff=0
[13:39:44] - Digital signature verified
[13:39:44]
[13:39:44] Project: 5506 (Run 0, Clone 641, Gen 287)
[13:39:44]
[13:39:44] Assembly optimizations on if available.
[13:39:44] Entering M.D.
[13:39:50] Working on p5506_supervillin_e1
[13:39:51] Client config found, loading data.
[13:39:51] mdrun_gpu returned
[13:39:51] NANs detected on GPU
[13:39:51]
[13:39:51] Folding@home Core Shutdown: UNSTABLE_MACHINE
[13:39:54] CoreStatus = 7A (122)
[13:39:54] Sending work to server
[13:39:54] Project: 5506 (Run 0, Clone 641, Gen 287)
[13:39:54] - Read packet limit of 540015616... Set to 524286976.
[13:39:54] - Error: Could not get length of results file work/wuresults_07.dat
[13:39:54] - Error: Could not read unit 07 file. Removing from queue.
[13:39:54] Trying to send all finished work units
[13:39:54] + No unsent completed units remaining.
[13:39:54] - Preparing to get new work unit...
[13:39:54] + Attempting to get work packet
[13:39:54] - Will indicate memory of 2045 MB
[13:39:54] - Connecting to assignment server
[13:39:54] Connecting to http://assign-GPU.stanford.edu:8080/
[13:39:54] Posted data.
[13:39:54] Initial: 40AB; - Successful: assigned to (171.64.65.106).
[13:39:54] + News From Folding@Home: GPU folding beta
[13:39:54] Loaded queue successfully.
[13:39:54] Connecting to http://171.64.65.106:8080/
[13:39:54] Initial: 0000; - Receiving payload (expected size: 45994)
[13:39:55] - Downloaded at ~44 kB/s
[13:39:55] - Averaged speed for that direction ~63 kB/s
[13:39:55] + Received work.
[13:39:55] Trying to send all finished work units
[13:39:55] + No unsent completed units remaining.
[13:39:55] + Closed connections
[13:40:00]
[13:40:00] + Processing work unit
[13:40:00] Core required: FahCore_11.exe
[13:40:00] Core found.
[13:40:00] Working on queue slot 08 [November 24 13:40:00 UTC]
[13:40:00] + Working ...
[13:40:00] - Calling '.\FahCore_11.exe -dir work/ -suffix 08 -priority 96 -nocpulock -checkpoint 15 -verbose -lifeline 3836 -version 620'
[13:40:00]
[13:40:00] *------------------------------*
[13:40:00] Folding@Home GPU Core - Beta
[13:40:00] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[13:40:00]
[13:40:00] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[13:40:00] Build host: amoeba
[13:40:00] Board Type: Nvidia
[13:40:00] Core      :
[13:40:00] Preparing to commence simulation
[13:40:00] - Looking at optimizations...
[13:40:00] - Created dyn
[13:40:00] - Files status OK
[13:40:00] - Expanded 45482 -> 246249 (decompressed 541.4 percent)
[13:40:00] Called DecompressByteArray: compressed_data_size=45482 data_size=246249, decompressed_data_size=246249 diff=0
[13:40:00] - Digital signature verified
[13:40:00]
[13:40:00] Project: 5506 (Run 0, Clone 641, Gen 287)
[13:40:00]
[13:40:00] Assembly optimizations on if available.
[13:40:00] Entering M.D.
[13:40:06] Working on p5506_supervillin_e1
[13:40:07] Client config found, loading data.
[13:40:07] Starting GUI Server
[13:40:07] mdrun_gpu returned
[13:40:07] NANs detected on GPU
[13:40:07]
[13:40:07] Folding@home Core Shutdown: UNSTABLE_MACHINE
[13:40:10] CoreStatus = 7A (122)
[13:40:10] Sending work to server
[13:40:10] Project: 5506 (Run 0, Clone 641, Gen 287)
[13:40:10] - Read packet limit of 540015616... Set to 524286976.
[13:40:10] - Error: Could not get length of results file work/wuresults_08.dat
[13:40:10] - Error: Could not read unit 08 file. Removing from queue.
[13:40:10] EUE limit exceeded. Pausing 24 hours.
[14:32:30] - Autosending finished units... [November 24 14:32:30 UTC]
[14:32:30] Trying to send all finished work units
[14:32:30] + No unsent completed units remaining.
Looks like a repeat of last week
BrokenWolf
Post by BrokenWolf »
I have one of these as well
[10:36:58] + Attempting to send results [November 24 10:36:58 UTC]
[10:36:58] - Reading file work/wuresults_00.dat from core
[10:36:58]   (Read 1178408 bytes from disk)
[10:36:58] Connecting to http://171.64.65.106:8080/
[10:37:16] Posted data.
[10:37:17] Initial: 0000; - Uploaded at ~60 kB/s
[10:37:17] - Averaged speed for that direction ~57 kB/s
[10:37:17] + Results successfully sent
[10:37:17] Thank you for your contribution to Folding@Home.
[10:37:17] + Number of Units Completed: 546
[10:37:21] Trying to send all finished work units
[10:37:21] + No unsent completed units remaining.
[10:37:21] - Preparing to get new work unit...
[10:37:21] + Attempting to get work packet
[10:37:21] - Will indicate memory of 8124 MB
[10:37:21] - Connecting to assignment server
[10:37:21] Connecting to http://assign-GPU.stanford.edu:8080/
[10:37:22] Posted data.
[10:37:22] Initial: 40AB; - Successful: assigned to (171.64.65.106).
[10:37:22] + News From Folding@Home: GPU folding beta
[10:37:22] Loaded queue successfully.
[10:37:22] Connecting to http://171.64.65.106:8080/
[10:37:22] Initial: 0000; - Receiving payload (expected size: 45994)
[10:37:22] Conversation time very short, giving reduced weight in bandwidth avg
[10:37:22] - Downloaded at ~89 kB/s
[10:37:22] - Averaged speed for that direction ~62 kB/s
[10:37:22] + Received work.
[10:37:22] Trying to send all finished work units
[10:37:22] + No unsent completed units remaining.
[10:37:22] + Closed connections
[10:37:22]
[10:37:22] + Processing work unit
[10:37:22] Core required: FahCore_11.exe
[10:37:22] Core found.
[10:37:22] Working on queue slot 01 [November 24 10:37:22 UTC]
[10:37:22] + Working ...
[10:37:22] - Calling '.\FahCore_11.exe -dir work/ -suffix 01 -priority 96 -checkpoint 15 -verbose -lifeline 4268 -version 620'
[10:37:23]
[10:37:23] *------------------------------*
[10:37:23] Folding@Home GPU Core - Beta
[10:37:23] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[10:37:23]
[10:37:23] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[10:37:23] Build host: amoeba
[10:37:23] Board Type: Nvidia
[10:37:23] Core      :
[10:37:23] Preparing to commence simulation
[10:37:23] - Looking at optimizations...
[10:37:23] - Created dyn
[10:37:23] - Files status OK
[10:37:23] - Expanded 45482 -> 246249 (decompressed 541.4 percent)
[10:37:23] Called DecompressByteArray: compressed_data_size=45482 data_size=246249, decompressed_data_size=246249 diff=0
[10:37:23] - Digital signature verified
[10:37:23]
[10:37:23] Project: 5506 (Run 0, Clone 641, Gen 287)
[10:37:23]
[10:37:23] Assembly optimizations on if available.
[10:37:23] Entering M.D.
[10:37:29] Working on p5506_supervillin_e1
[10:37:30] Client config found, loading data.
[10:37:30] mdrun_gpu returned
[10:37:30] NANs detected on GPU
[10:37:30]
[10:37:30] Folding@home Core Shutdown: UNSTABLE_MACHINE
[10:37:33] CoreStatus = 7A (122)
[10:37:33] Sending work to server
[10:37:33] Project: 5506 (Run 0, Clone 641, Gen 287)
[10:37:33] - Read packet limit of 540015616... Set to 524286976.
[10:37:33] - Error: Could not get length of results file work/wuresults_01.dat
[10:37:33] - Error: Could not read unit 01 file. Removing from queue.
[10:37:33] Trying to send all finished work units
[10:37:33] + No unsent completed units remaining.
[10:37:33] - Preparing to get new work unit...
[10:37:33] + Attempting to get work packet
[10:37:33] - Will indicate memory of 8124 MB
[10:37:33] - Connecting to assignment server
[10:37:33] Connecting to http://assign-GPU.stanford.edu:8080/
[10:37:33] Posted data.
[10:37:33] Initial: 40AB; - Successful: assigned to (171.64.65.106).
[10:37:33] + News From Folding@Home: GPU folding beta
[10:37:33] Loaded queue successfully.
[10:37:33] Connecting to http://171.64.65.106:8080/
[10:37:33] Initial: 0000; - Receiving payload (expected size: 45994)
[10:37:34] - Downloaded at ~44 kB/s
[10:37:34] - Averaged speed for that direction ~58 kB/s
[10:37:34] + Received work.
[10:37:34] Trying to send all finished work units
[10:37:34] + No unsent completed units remaining.
[10:37:34] + Closed connections
[10:37:39]
[10:37:39] + Processing work unit
[10:37:39] Core required: FahCore_11.exe
[10:37:39] Core found.
[10:37:39] Working on queue slot 02 [November 24 10:37:39 UTC]
[10:37:39] + Working ...
[10:37:39] - Calling '.\FahCore_11.exe -dir work/ -suffix 02 -priority 96 -checkpoint 15 -verbose -lifeline 4268 -version 620'
[10:37:39]
[10:37:39] *------------------------------*
[10:37:39] Folding@Home GPU Core - Beta
[10:37:39] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[10:37:39]
[10:37:39] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[10:37:39] Build host: amoeba
[10:37:39] Board Type: Nvidia
[10:37:39] Core      :
[10:37:39] Preparing to commence simulation
[10:37:39] - Looking at optimizations...
[10:37:39] - Created dyn
[10:37:39] - Files status OK
[10:37:39] - Expanded 45482 -> 246249 (decompressed 541.4 percent)
[10:37:39] Called DecompressByteArray: compressed_data_size=45482 data_size=246249, decompressed_data_size=246249 diff=0
[10:37:39] - Digital signature verified
[10:37:39]
[10:37:39] Project: 5506 (Run 0, Clone 641, Gen 287)
[10:37:39]
[10:37:39] Assembly optimizations on if available.
[10:37:39] Entering M.D.
[10:37:47] Working on p5506_supervillin_e1
[10:37:48] Client config found, loading data.
[10:37:48] mdrun_gpu returned
[10:37:48] NANs detected on GPU
[10:37:48]
[10:37:48] Folding@home Core Shutdown: UNSTABLE_MACHINE
[10:37:51] CoreStatus = 7A (122)
[10:37:51] Sending work to server
[10:37:51] Project: 5506 (Run 0, Clone 641, Gen 287)
[10:37:51] - Read packet limit of 540015616... Set to 524286976.
[10:37:51] - Error: Could not get length of results file work/wuresults_02.dat
[10:37:51] - Error: Could not read unit 02 file. Removing from queue.
[10:37:51] Trying to send all finished work units
[10:37:51] + No unsent completed units remaining.
[10:37:51] - Preparing to get new work unit...
[10:37:51] + Attempting to get work packet
[10:37:51] - Will indicate memory of 8124 MB
[10:37:51] - Connecting to assignment server
[10:37:51] Connecting to http://assign-GPU.stanford.edu:8080/
[10:37:51] Posted data.
[10:37:51] Initial: 40AB; - Successful: assigned to (171.64.65.106).
[10:37:51] + News From Folding@Home: GPU folding beta
[10:37:52] Loaded queue successfully.
[10:37:52] Connecting to http://171.64.65.106:8080/
[10:37:52] Posted data.
[10:37:52] Initial: 0000; - Receiving payload (expected size: 45994)
[10:37:52] Conversation time very short, giving reduced weight in bandwidth avg
[10:37:52] - Downloaded at ~89 kB/s
[10:37:52] - Averaged speed for that direction ~62 kB/s
[10:37:52] + Received work.
[10:37:52] Trying to send all finished work units
[10:37:52] + No unsent completed units remaining.
[10:37:52] + Closed connections
[10:37:57]
[10:37:57] + Processing work unit
[10:37:57] Core required: FahCore_11.exe
[10:37:57] Core found.
[10:37:57] Working on queue slot 03 [November 24 10:37:57 UTC]
[10:37:57] + Working ...
[10:37:57] - Calling '.\FahCore_11.exe -dir work/ -suffix 03 -priority 96 -checkpoint 15 -verbose -lifeline 4268 -version 620'
[10:37:57]
[10:37:57] *------------------------------*
[10:37:57] Folding@Home GPU Core - Beta
[10:37:57] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[10:37:57]
[10:37:57] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[10:37:57] Build host: amoeba
[10:37:57] Board Type: Nvidia
[10:37:57] Core      :
[10:37:57] Preparing to commence simulation
[10:37:57] - Looking at optimizations...
[10:37:57] - Created dyn
[10:37:57] - Files status OK
[10:37:57] - Expanded 45482 -> 246249 (decompressed 541.4 percent)
[10:37:57] Called DecompressByteArray: compressed_data_size=45482 data_size=246249, decompressed_data_size=246249 diff=0
[10:37:57] - Digital signature verified
[10:37:57]
[10:37:57] Project: 5506 (Run 0, Clone 641, Gen 287)
[10:37:57]
[10:37:57] Assembly optimizations on if available.
[10:37:57] Entering M.D.
[10:38:04] Working on p5506_supervillin_e1
[10:38:04] Client config found, loading data.
[10:38:04] mdrun_gpu returned
[10:38:04] NANs detected on GPU
[10:38:04]
[10:38:04] Folding@home Core Shutdown: UNSTABLE_MACHINE
[10:38:08] CoreStatus = 7A (122)
[10:38:08] Sending work to server
[10:38:08] Project: 5506 (Run 0, Clone 641, Gen 287)
[10:38:08] - Read packet limit of 540015616... Set to 524286976.
[10:38:08] - Error: Could not get length of results file work/wuresults_03.dat
[10:38:08] - Error: Could not read unit 03 file. Removing from queue.
[10:38:08] Trying to send all finished work units
[10:38:08] + No unsent completed units remaining.
[10:38:08] - Preparing to get new work unit...
[10:38:08] + Attempting to get work packet
[10:38:08] - Will indicate memory of 8124 MB
[10:38:08] - Connecting to assignment server
[10:38:08] Connecting to http://assign-GPU.stanford.edu:8080/
[10:38:08] Posted data.
[10:38:08] Initial: 40AB; - Successful: assigned to (171.64.65.106).
[10:38:08] + News From Folding@Home: GPU folding beta
[10:38:08] Loaded queue successfully.
[10:38:08] Connecting to http://171.64.65.106:8080/
[10:38:08] Initial: 0000; - Receiving payload (expected size: 45994)
[10:38:09] - Downloaded at ~44 kB/s
[10:38:09] - Averaged speed for that direction ~58 kB/s
[10:38:09] + Received work.
[10:38:09] Trying to send all finished work units
[10:38:09] + No unsent completed units remaining.
[10:38:09] + Closed connections
[10:38:14]
[10:38:14] + Processing work unit
[10:38:14] Core required: FahCore_11.exe
[10:38:14] Core found.
[10:38:14] Working on queue slot 04 [November 24 10:38:14 UTC]
[10:38:14] + Working ...
[10:38:14] - Calling '.\FahCore_11.exe -dir work/ -suffix 04 -priority 96 -checkpoint 15 -verbose -lifeline 4268 -version 620'
[10:38:14]
[10:38:14] *------------------------------*
[10:38:14] Folding@Home GPU Core - Beta
[10:38:14] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[10:38:14]
[10:38:14] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[10:38:14] Build host: amoeba
[10:38:14] Board Type: Nvidia
[10:38:14] Core      :
[10:38:14] Preparing to commence simulation
[10:38:14] - Looking at optimizations...
[10:38:14] - Created dyn
[10:38:14] - Files status OK
[10:38:15] - Expanded 45482 -> 246249 (decompressed 541.4 percent)
[10:38:15] Called DecompressByteArray: compressed_data_size=45482 data_size=246249, decompressed_data_size=246249 diff=0
[10:38:15] - Digital signature verified
[10:38:15]
[10:38:15] Project: 5506 (Run 0, Clone 641, Gen 287)
[10:38:15]
[10:38:15] Assembly optimizations on if available.
[10:38:15] Entering M.D.
[10:38:21] Working on p5506_supervillin_e1
[10:38:21] Client config found, loading data.
[10:38:21] mdrun_gpu returned
[10:38:21] NANs detected on GPU
[10:38:21]
[10:38:21] Folding@home Core Shutdown: UNSTABLE_MACHINE
[10:38:21] Starting GUI Server
[10:38:24] CoreStatus = 7A (122)
[10:38:24] Sending work to server
[10:38:24] Project: 5506 (Run 0, Clone 641, Gen 287)
[10:38:24] - Read packet limit of 540015616... Set to 524286976.
[10:38:24] - Error: Could not get length of results file work/wuresults_04.dat
[10:38:24] - Error: Could not read unit 04 file. Removing from queue.
[10:38:24] Trying to send all finished work units
[10:38:24] + No unsent completed units remaining.
[10:38:24] - Preparing to get new work unit...
[10:38:24] + Attempting to get work packet
[10:38:24] - Will indicate memory of 8124 MB
[10:38:24] - Connecting to assignment server
[10:38:24] Connecting to http://assign-GPU.stanford.edu:8080/
[10:38:24] Posted data.
[10:38:24] Initial: 40AB; - Successful: assigned to (171.64.65.106).
[10:38:24] + News From Folding@Home: GPU folding beta
[10:38:25] Loaded queue successfully.
[10:38:25] Connecting to http://171.64.65.106:8080/
[10:38:25] Posted data.
[10:38:25] Initial: 0000; - Receiving payload (expected size: 45994)
[10:38:25] Conversation time very short, giving reduced weight in bandwidth avg
[10:38:25] - Downloaded at ~89 kB/s
[10:38:25] - Averaged speed for that direction ~62 kB/s
[10:38:25] + Received work.
[10:38:25] Trying to send all finished work units
[10:38:25] + No unsent completed units remaining.
[10:38:25] + Closed connections
[10:38:30]
[10:38:30] + Processing work unit
[10:38:30] Core required: FahCore_11.exe
[10:38:30] Core found.
[10:38:30] Working on queue slot 05 [November 24 10:38:30 UTC]
[10:38:30] + Working ...
[10:38:30] - Calling '.\FahCore_11.exe -dir work/ -suffix 05 -priority 96 -checkpoint 15 -verbose -lifeline 4268 -version 620'
[10:38:30]
[10:38:30] *------------------------------*
[10:38:30] Folding@Home GPU Core - Beta
[10:38:30] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[10:38:30]
[10:38:30] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[10:38:30] Build host: amoeba
[10:38:30] Board Type: Nvidia
[10:38:30] Core      :
[10:38:30] Preparing to commence simulation
[10:38:30] - Looking at optimizations...
[10:38:30] - Created dyn
[10:38:30] - Files status OK
[10:38:30] - Expanded 45482 -> 246249 (decompressed 541.4 percent)
[10:38:30] Called DecompressByteArray: compressed_data_size=45482 data_size=246249, decompressed_data_size=246249 diff=0
[10:38:30] - Digital signature verified
[10:38:30]
[10:38:30] Project: 5506 (Run 0, Clone 641, Gen 287)
[10:38:30]
[10:38:30] Assembly optimizations on if available.
[10:38:30] Entering M.D.
[10:38:37] Working on p5506_supervillin_e1
[10:38:38] Client config found, loading data.
[10:38:38] Starting GUI Server
[10:38:38] mdrun_gpu returned
[10:38:38] NANs detected on GPU
[10:38:38]
[10:38:38] Folding@home Core Shutdown: UNSTABLE_MACHINE
[10:38:41] CoreStatus = 7A (122)
[10:38:41] Sending work to server
[10:38:41] Project: 5506 (Run 0, Clone 641, Gen 287)
[10:38:41] - Read packet limit of 540015616... Set to 524286976.
[10:38:41] - Error: Could not get length of results file work/wuresults_05.dat
[10:38:41] - Error: Could not read unit 05 file. Removing from queue.
[10:38:41] EUE limit exceeded. Pausing 24 hours.
[15:53:25] - Autosending finished units... [November 24 15:53:25 UTC]
[15:53:25] Trying to send all finished work units
[15:53:25] + No unsent completed units remaining.
[15:53:25] - Autosend completed
[15:53:25] + Working...
[21:53:22] - Autosending finished units... [November 24 21:53:22 UTC]
[21:53:22] Trying to send all finished work units
[21:53:22] + No unsent completed units remaining.
[21:53:22] - Autosend completed
[21:53:22] + Working...
[03:53:19] - Autosending finished units... [November 25 03:53:19 UTC]
[03:53:19] Trying to send all finished work units
[03:53:19] + No unsent completed units remaining.
[03:53:19] - Autosend completed
[03:53:19] + Working...
BrokenWolf
There are now 12 reports of instant EUE ... this is a bad WU :(
