Project: 5506 (Run 0, Clone 668, Gen 294)
osgorth
Post by osgorth »
Another one of the recent "instant EUE" work units.. Can we please get these removed, they're killing my farm. :(
[11:42:20] Project: 5506 (Run 0, Clone 668, Gen 294)
[11:42:20]
[11:42:20] Assembly optimizations on if available.
[11:42:20] Entering M.D.
[11:42:27] Working on p5506_supervillin_e1
[11:42:27] Client config found, loading data.
[11:42:28] Starting GUI Server
[11:42:28] mdrun_gpu returned
[11:42:28] NANs detected on GPU
[11:42:28]
[11:42:28] Folding@home Core Shutdown: UNSTABLE_MACHINE
[11:42:31] CoreStatus = 7A (122)
[11:42:31] Sending work to server
Re: Project: 5506 (Run 0, Clone 668, Gen 294)
That's a bad WU : 5 similar reports of failures :(
Drugless
Post by Drugless »
Failed here again.
[22:07:38] Project: 5506 (Run 0, Clone 668, Gen 294)
[22:07:38]
[22:07:38] Assembly optimizations on if available.
[22:07:38] Entering M.D.
[22:07:44] Working on p5506_supervillin_e1
[22:07:45] Client config found, loading data.
[22:07:45] mdrun_gpu returned
[22:07:45] NANs detected on GPU
[22:07:45]
[22:07:45] Folding@home Core Shutdown: UNSTABLE_MACHINE
[22:07:48] CoreStatus = 7A (122)
[22:07:48] Sending work to server
[22:07:48] Project: 5506 (Run 0, Clone 668, Gen 294)
[22:07:48] - Read packet limit of 540015616... Set to 524286976.
[22:07:48] - Error: Could not get length of results file work/wuresults_09.dat
[22:07:48] - Error: Could not read unit 09 file. Removing from queue.
[22:07:48] EUE limit exceeded. Pausing 24 hours.
Folding Tools:8 X PS3's, 5 x GTX280,1 x 8800GS, 8 x 9800GX2 GPU's
subego
Post by subego »
Got me, too.
[06:56:26] Project: 5506 (Run 0, Clone 668, Gen 294)
[06:56:26]
[06:56:26] Assembly optimizations on if available.
[06:56:26] Entering M.D.
[06:56:32] Working on p5506_supervillin_e1
[06:56:33] Client config found, loading data.
[06:56:33] mdrun_gpu returned
[06:56:33] NANs detected on GPU
[06:56:33]
[06:56:33] Folding@home Core Shutdown: UNSTABLE_MACHINE
[06:56:36] CoreStatus = 7A (122)
[06:56:36] Sending work to server
[06:56:36] Project: 5506 (Run 0, Clone 668, Gen 294)
[06:56:36] - Read packet limit of 540015616... Set to 524286976.
[06:56:36] - Error: Could not get length of results file work/wuresults_04.dat
[06:56:36] - Error: Could not read unit 04 file. Removing from queue.
[06:56:36] EUE limit exceeded. Pausing 24 hours.
[09:01:55] + Working...
[15:01:54] + Working...
subego
Post by subego »
It's still being distributed. Just got me again.
[19:13:22] Project: 5506 (Run 0, Clone 668, Gen 294)
[19:13:22]
[19:13:22] Assembly optimizations on if available.
[19:13:22] Entering M.D.
[19:13:29] Working on p5506_supervillin_e1
[19:13:29] Client config found, loading data.
[19:13:29] mdrun_gpu returned
[19:13:29] NANs detected on GPU
[19:13:29]
[19:13:29] Folding@home Core Shutdown: UNSTABLE_MACHINE
[19:13:32] CoreStatus = 7A (122)
[19:13:32] Sending work to server
[19:13:32] Project: 5506 (Run 0, Clone 668, Gen 294)
[19:13:32] - Read packet limit of 540015616... Set to 524286976.
[19:13:32] - Error: Could not get length of results file work/wuresults_06.dat
[19:13:32] - Error: Could not read unit 06 file. Removing from queue.
[19:13:32] EUE limit exceeded. Pausing 24 hours.
Drugless
Post by Drugless »
I'm still receiving this bad wu!
[23:41:51] Project: 5506 (Run 0, Clone 668, Gen 294)
[23:41:51]
[23:41:51] Assembly optimizations on if available.
[23:41:51] Entering M.D.
[23:41:58] Working on p5506_supervillin_e1
[23:41:58] Client config found, loading data.
[23:41:58] Starting GUI Server
[23:41:58] mdrun_gpu returned
[23:41:58] NANs detected on GPU
[23:41:58]
[23:41:58] Folding@home Core Shutdown: UNSTABLE_MACHINE
[23:42:01] CoreStatus = 7A (122)
[23:42:01] Sending work to server
[23:42:01] Project: 5506 (Run 0, Clone 668, Gen 294)
[23:42:01] - Read packet limit of 540015616... Set to 524286976.
[23:42:01] - Error: Could not get length of results file work/wuresults_08.dat
[23:42:01] - Error: Could not read unit 08 file. Removing from queue.
[23:42:01] EUE limit exceeded. Pausing 24 hours.
VijayPande
Pande Group Member
Post by VijayPande »
Thanks for the reports and sorry for this hassle. We've manually removed this WU. We are looking into what needs to be done to better automate this problem (looks like an updated client will be needed to send the right info to the server).
Prof. Vijay Pande, PhD
Chair, Biophysics
Stanford University
