171.67.108.25 Server has no record?
Razor_FX_II
Hardware configuration: Proud Member of the [H]orde
Proud Member of the [H]ard DC Commandos
Post by Razor_FX_II »
Give me a break! We starting this load of BS again?
[02:44:27] Connecting to http://171.67.108.25:8080/
[02:44:27] - Couldn't send HTTP request to server
[02:44:27]   (Got status 503)
[02:44:27] + Could not connect to Work Server (results)
[02:44:27]     (171.67.108.25:8080)
[02:44:27] + Retrying using alternative port
[02:44:27] Connecting to http://171.67.108.25:80/
[02:44:48] Posted data.
[02:44:48] Initial: 0000; - Server does not have record of this unit. Will try again later.
[02:44:48]   Could not transmit unit 08 to Collection server; keeping in queue.
[02:44:48] + Sent 0 of 1 completed units to the server
[02:44:48] - Autosend completed
[02:44:48] + Working...
[02:45:25] Completed 5%
ppetrone
Pande Group Member
Re: 171.67.108.25 Server has no record?
Post by ppetrone »
It is possible that the Collection Server has too much work. It might clear up in the next days. Otherwise, please keep us posted. Thanks,
Paula
KE1HA
Hardware configuration: Beta Rig - All Stock For Testing
| Q9770 3.2GHz | Rampage Formula | 4GB OCZ Reaper 8500
| BFG 8800 GTS | Raptor 73GB | G15 | Razer Copperhead |
| ASUS MK2401H HDMI @ 1920x1200 |
Post by KE1HA »
That could. I got this on three different machines, then failed to connect to get more work on 65.20 I think it was.
04:01:33] + Could not connect to Work Server (results)
[04:01:33]     (171.67.108.25:8080)
[04:01:33] + Retrying using alternative port
[04:01:33] Connecting to http://171.67.108.25:80/
[04:01:33] - Couldn't send HTTP request to server
[04:01:33]   (Got status 503)
[04:01:33] + Could not connect to Work Server (results)
2x - Q6600 1 with 2x 9800GT's / 1 with 2x 8800GTS G92 512's UB-8.04 CLI Only
2x - AMD 9850 1 with 3x 9800 GT's / 1 with 1x 9800 GT's UB-8.04 CLI Only
1x - QX9770 GTX-280 WinDoze Vista 64
Fahwiki entry about this error : http://fahwiki.net/index.php/Common_Err ... _this_unit
Razor_FX_II
toTOW wrote:Fahwiki entry about this error : http://fahwiki.net/index.php/Common_Err ... _this_unit
I know what it means: More Stanford Server Problems!
We have just about had our fill of them lately. I'm thinking they need to put an end to these problems or continue to loose doners.
