Project: 5506 (Run 8, Clone 0, Gen 247)
Oldhat
Post by Oldhat »
Hi there,
Getting machine errors on this work unit as well. NAN error 7a Unstable Machine.
Windows XP SP3 AMD 64 4000 1024Mb RAM 2 x 8800GS
[00:24:36]
[00:24:36] *------------------------------*
[00:24:36] Folding@Home GPU Core - Beta
[00:24:36] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[00:24:36]
[00:24:36] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[00:24:36] Build host: amoeba
[00:24:36] Board Type: Nvidia
[00:24:36] Core      :
[00:24:36] Preparing to commence simulation
[00:24:36] - Looking at optimizations...
[00:24:36] - Created dyn
[00:24:36] - Files status OK
[00:24:36] - Expanded 45557 -> 246249 (decompressed 540.5 percent)
[00:24:36] Called DecompressByteArray: compressed_data_size=45557 data_size=246249, decompressed_data_size=246249 diff=0
[00:24:36] - Digital signature verified
[00:24:36]
[00:24:36] Project: 5506 (Run 8, Clone 0, Gen 247)
[00:24:36]
[00:24:36] Assembly optimizations on if available.
[00:24:36] Entering M.D.
[00:24:43] Working on p5506_supervillin_e1
[00:24:43] Client config found, loading data.
[00:24:43] mdrun_gpu returned
[00:24:43] NANs detected on GPU
[00:24:43]
[00:24:43] Folding@home Core Shutdown: UNSTABLE_MACHINE
[00:24:46] CoreStatus = 7A (122)
[00:24:46] Sending work to server
[00:24:46] Project: 5506 (Run 8, Clone 0, Gen 247)
[00:24:46] - Read packet limit of 540015616... Set to 524286976.
[00:24:46] - Error: Could not get length of results file work/wuresults_04.dat
[00:24:46] - Error: Could not read unit 04 file. Removing from queue.
[00:24:46] - Preparing to get new work unit...
[00:24:46] + Attempting to get work packet
[00:24:46] - Connecting to assignment server
[00:24:47] - Successful: assigned to (171.64.65.106).
[00:24:47] + News From Folding@Home: GPU folding beta
[00:24:47] Loaded queue successfully.
[00:24:49] + Closed connections
[00:24:54]
[00:24:54] + Processing work unit
[00:24:54] Core required: FahCore_11.exe
[00:24:54] Core found.
[00:24:54] Working on queue slot 05 [November 18 00:24:54 UTC]
[00:24:54] + Working ...
[00:24:54]
[00:24:54] *------------------------------*
[00:24:54] Folding@Home GPU Core - Beta
[00:24:54] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[00:24:54]
[00:24:54] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[00:24:54] Build host: amoeba
[00:24:54] Board Type: Nvidia
[00:24:54] Core      :
[00:24:54] Preparing to commence simulation
[00:24:54] - Looking at optimizations...
[00:24:54] - Created dyn
[00:24:54] - Files status OK
[00:24:54] - Expanded 45557 -> 246249 (decompressed 540.5 percent)
[00:24:54] Called DecompressByteArray: compressed_data_size=45557 data_size=246249, decompressed_data_size=246249 diff=0
[00:24:54] - Digital signature verified
[00:24:54]
[00:24:54] Project: 5506 (Run 8, Clone 0, Gen 247)
[00:24:54]
[00:24:54] Assembly optimizations on if available.
[00:24:54] Entering M.D.
[00:25:00] Working on p5506_supervillin_e1
[00:25:01] Client config found, loading data.
[00:25:01] mdrun_gpu returned
[00:25:01] NANs detected on GPU
[00:25:01]
[00:25:01] Folding@home Core Shutdown: UNSTABLE_MACHINE
[00:25:01] Starting GUI Server
[00:25:04] CoreStatus = 7A (122)
[00:25:04] Sending work to server
[00:25:04] Project: 5506 (Run 8, Clone 0, Gen 247)
[00:25:04] - Read packet limit of 540015616... Set to 524286976.
[00:25:04] - Error: Could not get length of results file work/wuresults_05.dat
[00:25:04] - Error: Could not read unit 05 file. Removing from queue.
[00:25:04] - Preparing to get new work unit...
[00:25:04] + Attempting to get work packet
[00:25:04] - Connecting to assignment server
[00:25:05] - Successful: assigned to (171.64.65.106).
[00:25:05] + News From Folding@Home: GPU folding beta
[00:25:05] Loaded queue successfully.
[00:25:06] + Closed connections
[00:25:11]
Cheers
Re: Project: 5506 (Run 8, Clone 0, Gen 247)
Another bad WU that no one was able to start :(
VijayPande
Pande Group Member
Post by VijayPande »
We've manually stopped this WU. We're also looking into new client and/or server code to better handle these situations.
Prof. Vijay Pande, PhD
Chair, Biophysics
Stanford University
