Project: 5014 (Run 1, Clone 105, Gen 168)
TiSwAs
Post by TiSwAs »
Related post - viewtopic.php?f=52&t=6917&st=0&sk=t&sd=a&start=15#p69076
--- Opening Log file [November 17 09:51:59 UTC]
                       Folding@Home Client Version 6.20r1
                          http://folding.stanford.edu
Launch directory: C:\Documents and Settings\DePuy CMW\Application Data\Folding@home-gpu3
Arguments: -verbosity 9 -gpu 2
[09:52:17] - Ask before connecting: No
[09:52:17] - User name: TiSwAs (Team 35947)
[09:52:17] - User ID: 31F792A4154ACC71
[09:52:17] - Machine ID: 5
[09:52:17]
[09:52:17] Work directory not found. Creating...
[09:52:17] Could not open work queue, generating new queue...
[09:52:17] Initialization complete
[09:52:17] - Preparing to get new work unit...
[09:52:17] + Attempting to get work packet
[09:52:17] - Autosending finished units... [November 17 09:52:17 UTC]
[09:52:17] Trying to send all finished work units
[09:52:17] + No unsent completed units remaining.
[09:52:17] - Autosend completed
[09:52:17] - Will indicate memory of 2047 MB
[09:52:17] - Detect CPU. Vendor: AuthenticAMD, Family: 15, Model: 11, Stepping: 2
[09:52:17] - Connecting to assignment server
[09:52:17] Connecting to http://assign-GPU.stanford.edu:8080/
[09:52:18] Posted data.
[09:52:18] Initial: 40AB; - Successful: assigned to (171.64.65.20).
[09:52:18] + News From Folding@Home: GPU folding beta
[09:52:18] Loaded queue successfully.
[09:52:18] Connecting to http://171.64.65.20:8080/
[09:52:19] Posted data.
[09:52:19] Initial: 0000; - Receiving payload (expected size: 44575)
[09:52:20] - Downloaded at ~43 kB/s
[09:52:20] - Averaged speed for that direction ~43 kB/s
[09:52:20] + Received work.
[09:52:20] + Closed connections
[09:52:20]
[09:52:20] + Processing work unit
[09:52:20] Core required: FahCore_11.exe
[09:52:20] Core found.
[09:52:20] Working on queue slot 01 [November 17 09:52:20 UTC]
[09:52:20] + Working ...
[09:52:20] - Calling '.\FahCore_11.exe -dir work/ -suffix 01 -priority 96 -checkpoint 15 -verbose -lifeline 960 -version 620'
[09:52:20]
[09:52:20] *------------------------------*
[09:52:20] Folding@Home GPU Core - Beta
[09:52:20] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[09:52:20]
[09:52:20] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[09:52:20] Build host: amoeba
[09:52:20] Board Type: Nvidia
[09:52:20] Core      :
[09:52:20] Preparing to commence simulation
[09:52:20] - Looking at optimizations...
[09:52:20] - Created dyn
[09:52:20] - Files status OK
[09:52:20] - Expanded 44063 -> 244433 (decompressed 554.7 percent)
[09:52:20] Called DecompressByteArray: compressed_data_size=44063 data_size=244433, decompressed_data_size=244433 diff=0
[09:52:20] - Digital signature verified
[09:52:21]
[09:52:21] Project: 5014 (Run 1, Clone 105, Gen 168)
[09:52:21]
[09:52:21] Assembly optimizations on if available.
[09:52:21] Entering M.D.
[09:52:27] Working on 576 p5005_supervillin_e1
[09:52:27] Client config found, loading data.
[09:52:28] Starting GUI Server
[09:53:03] mdrun_gpu returned
[09:53:03] NANs detected on GPU
[09:53:03]
[09:53:03] Folding@home Core Shutdown: UNSTABLE_MACHINE
[09:53:06] CoreStatus = 7A (122)
[09:53:06] Sending work to server
[09:53:06] Project: 5014 (Run 1, Clone 105, Gen 168)
[09:53:06] - Read packet limit of 540015616... Set to 524286976.
[09:53:06] - Error: Could not get length of results file work/wuresults_01.dat
[09:53:06] - Error: Could not read unit 01 file. Removing from queue.
[09:53:06] Trying to send all finished work units
[09:53:06] + No unsent completed units remaining.
[09:53:06] - Preparing to get new work unit...
[09:53:06] + Attempting to get work packet
[09:53:06] - Will indicate memory of 2047 MB
[09:53:06] - Connecting to assignment server
[09:53:06] Connecting to http://assign-GPU.stanford.edu:8080/
[09:53:07] Posted data.
[09:53:07] Initial: 40AB; - Successful: assigned to (171.64.65.20).
[09:53:07] + News From Folding@Home: GPU folding beta
[09:53:07] Loaded queue successfully.
[09:53:07] Connecting to http://171.64.65.20:8080/
[09:53:08] Posted data.
[09:53:08] Initial: 0000; - Receiving payload (expected size: 44575)
[09:53:09] - Downloaded at ~43 kB/s
[09:53:09] - Averaged speed for that direction ~43 kB/s
[09:53:09] + Received work.
[09:53:09] Trying to send all finished work units
[09:53:09] + No unsent completed units remaining.
[09:53:09] + Closed connections
[09:53:14]
[09:53:14] + Processing work unit
[09:53:14] Core required: FahCore_11.exe
[09:53:14] Core found.
[09:53:14] Working on queue slot 02 [November 17 09:53:14 UTC]
[09:53:14] + Working ...
[09:53:14] - Calling '.\FahCore_11.exe -dir work/ -suffix 02 -priority 96 -checkpoint 15 -verbose -lifeline 960 -version 620'
[09:53:14]
[09:53:14] *------------------------------*
[09:53:14] Folding@Home GPU Core - Beta
[09:53:14] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[09:53:14]
[09:53:14] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[09:53:14] Build host: amoeba
[09:53:14] Board Type: Nvidia
[09:53:14] Core      :
[09:53:14] Preparing to commence simulation
[09:53:14] - Looking at optimizations...
[09:53:14] - Created dyn
[09:53:14] - Files status OK
[09:53:14] - Expanded 44063 -> 244433 (decompressed 554.7 percent)
[09:53:14] Called DecompressByteArray: compressed_data_size=44063 data_size=244433, decompressed_data_size=244433 diff=0
[09:53:14] - Digital signature verified
[09:53:14]
[09:53:14] Project: 5014 (Run 1, Clone 105, Gen 168)
[09:53:14]
[09:53:14] Assembly optimizations on if available.
[09:53:14] Entering M.D.
[09:53:21] Working on 576 p5005_supervillin_e1
[09:53:21] Client config found, loading data.
[09:53:21] Starting GUI Server
[09:53:42] mdrun_gpu returned
[09:53:42] NANs detected on GPU
[09:53:42]
[09:53:42] Folding@home Core Shutdown: UNSTABLE_MACHINE
[09:53:44] CoreStatus = 7A (122)
[09:53:44] Sending work to server
[09:53:44] Project: 5014 (Run 1, Clone 105, Gen 168)
[09:53:44] - Read packet limit of 540015616... Set to 524286976.
[09:53:44] - Error: Could not get length of results file work/wuresults_02.dat
[09:53:44] - Error: Could not read unit 02 file. Removing from queue.
[09:53:44] Trying to send all finished work units
[09:53:44] + No unsent completed units remaining.
[09:53:44] - Preparing to get new work unit...
[09:53:44] + Attempting to get work packet
[09:53:44] - Will indicate memory of 2047 MB
[09:53:44] - Connecting to assignment server
[09:53:44] Connecting to http://assign-GPU.stanford.edu:8080/
[09:53:45] Posted data.
[09:53:45] Initial: 40AB; - Successful: assigned to (171.64.65.20).
[09:53:45] + News From Folding@Home: GPU folding beta
[09:53:45] Loaded queue successfully.
[09:53:45] Connecting to http://171.64.65.20:8080/
[09:53:46] Posted data.
[09:53:46] Initial: 0000; - Receiving payload (expected size: 44575)
[09:53:47] - Downloaded at ~43 kB/s
[09:53:47] - Averaged speed for that direction ~43 kB/s
[09:53:47] + Received work.
[09:53:47] Trying to send all finished work units
[09:53:47] + No unsent completed units remaining.
[09:53:47] + Closed connections
[09:53:52]
[09:53:52] + Processing work unit
[09:53:52] Core required: FahCore_11.exe
[09:53:52] Core found.
[09:53:52] Working on queue slot 03 [November 17 09:53:52 UTC]
[09:53:52] + Working ...
[09:53:52] - Calling '.\FahCore_11.exe -dir work/ -suffix 03 -priority 96 -checkpoint 15 -verbose -lifeline 960 -version 620'
[09:53:52]
[09:53:52] *------------------------------*
[09:53:52] Folding@Home GPU Core - Beta
[09:53:52] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[09:53:52]
[09:53:52] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[09:53:52] Build host: amoeba
[09:53:52] Board Type: Nvidia
[09:53:52] Core      :
[09:53:52] Preparing to commence simulation
[09:53:52] - Looking at optimizations...
[09:53:52] - Created dyn
[09:53:52] - Files status OK
[09:53:52] - Expanded 44063 -> 244433 (decompressed 554.7 percent)
[09:53:52] Called DecompressByteArray: compressed_data_size=44063 data_size=244433, decompressed_data_size=244433 diff=0
[09:53:52] - Digital signature verified
[09:53:52]
[09:53:52] Project: 5014 (Run 1, Clone 105, Gen 168)
[09:53:52]
[09:53:52] Assembly optimizations on if available.
[09:53:52] Entering M.D.
[09:53:58] Working on 576 p5005_supervillin_e1
[09:53:59] Client config found, loading data.
[09:53:59] Starting GUI Server
[09:54:15] mdrun_gpu returned
[09:54:15] NANs detected on GPU
[09:54:15]
[09:54:15] Folding@home Core Shutdown: UNSTABLE_MACHINE
[09:54:18] CoreStatus = 7A (122)
[09:54:18] Sending work to server
[09:54:18] Project: 5014 (Run 1, Clone 105, Gen 168)
[09:54:18] - Read packet limit of 540015616... Set to 524286976.
[09:54:18] - Error: Could not get length of results file work/wuresults_03.dat
[09:54:18] - Error: Could not read unit 03 file. Removing from queue.
[09:54:18] Trying to send all finished work units
[09:54:18] + No unsent completed units remaining.
[09:54:18] - Preparing to get new work unit...
[09:54:18] + Attempting to get work packet
[09:54:18] - Will indicate memory of 2047 MB
[09:54:18] - Connecting to assignment server
[09:54:18] Connecting to http://assign-GPU.stanford.edu:8080/
[09:54:19] Posted data.
[09:54:19] Initial: 40AB; - Successful: assigned to (171.64.65.20).
[09:54:19] + News From Folding@Home: GPU folding beta
[09:54:19] Loaded queue successfully.
[09:54:19] Connecting to http://171.64.65.20:8080/
[09:54:19] Initial: 0000; - Receiving payload (expected size: 44575)
[09:54:20] - Downloaded at ~43 kB/s
[09:54:20] - Averaged speed for that direction ~43 kB/s
[09:54:20] + Received work.
[09:54:20] Trying to send all finished work units
[09:54:20] + No unsent completed units remaining.
[09:54:20] + Closed connections
[09:54:22] ***** Got a SIGTERM signal (2)
[09:54:22] Killing all core threads
Folding@Home Client Shutdown.
Re: Project: 5014 (Run 1, Clone 105, Gen 168)
There's no report in the DB for this WU ... which is affected by the unreadable results issue :(
TiSwAs
Post by TiSwAs »
ok thanks for looking - found out what the issue was - thought this had be WU related.
Sorry for inconvenience.
Regards
