Project: 5506 (Run 2, Clone 223, Gen 183)
Ytterbium
Post by Ytterbium »
[04:56:45] *------------------------------*
[04:56:45] Folding@Home GPU Core - Beta
[04:56:45] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[04:56:45]
[04:56:45] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[04:56:45] Build host: amoeba
[04:56:45] Board Type: Nvidia
[04:56:45] Core      :
[04:56:45] Preparing to commence simulation
[04:56:45] - Looking at optimizations...
[04:56:45] - Created dyn
[04:56:45] - Files status OK
[04:56:45] - Expanded 45626 -> 246249 (decompressed 539.7 percent)
[04:56:45] Called DecompressByteArray: compressed_data_size=45626 data_size=246249, decompressed_data_size=246249 diff=0
[04:56:45] - Digital signature verified
[04:56:45]
[04:56:45] Project: 5506 (Run 2, Clone 223, Gen 183)
[04:56:45]
[04:56:45] Assembly optimizations on if available.
[04:56:45] Entering M.D.
[04:56:51] Working on p5506_supervillin_e1
[04:56:52] Client config found, loading data.
[04:56:53] Starting GUI Server
[05:01:29] Completed 1%
[05:06:06] Completed 2%
[05:10:43] Completed 3%
[05:15:19] Completed 4%
[05:19:56] Completed 5%
[05:24:33] Completed 6%
[05:29:10] Completed 7%
[05:33:46] Completed 8%
[05:38:23] Completed 9%
[05:43:00] Completed 10%
[05:47:37] Completed 11%
[05:52:14] Completed 12%
[05:56:51] Completed 13%
[06:01:28] Completed 14%
[06:06:04] Completed 15%
[06:10:41] Completed 16%
[06:15:18] Completed 17%
[06:17:01] mdrun_gpu returned
[06:17:01] NANs detected on GPU
[06:17:01]
[06:17:01] Folding@home Core Shutdown: UNSTABLE_MACHINE
[06:17:05] CoreStatus = 7A (122)
[06:17:05] Sending work to server
[06:17:05] Project: 5506 (Run 2, Clone 223, Gen 183)
[06:17:05] - Read packet limit of 540015616... Set to 524286976.
[06:17:05] - Error: Could not get length of results file work/wuresults_04.dat
[06:17:05] - Error: Could not read unit 04 file. Removing from queue.
[06:17:05] - Preparing to get new work unit...
[06:17:05] + Attempting to get work packet
[06:17:05] - Connecting to assignment server
[06:17:06] - Successful: assigned to (171.67.108.11).
[06:17:06] + News From Folding@Home: GPU folding beta
[06:17:06] Loaded queue successfully.
[06:17:08] + Closed connections
uncle_fungus
Re: Project: 5506 (Run 2, Clone 223, Gen 183)
Post by uncle_fungus »
This WU has been completed successfully by someone else.
That strange, this time the good result has been returned before you got that WU ... :?
anandhanju
Post by anandhanju »
Can someone at the Pande labs check if the assignment servers are handling out duplicate WUs? With all this trouble of unreachable server and 503 errors, last thing I'd want to see is the same work being assigned multiple times.
