Project: 5506 (Run 8, Clone 200, Gen 192)
Drugless
Post by Drugless »
Repeated failures:
Anyone else manage to complete this one? :cry:
[17:04:02] Project: 5506 (Run 8, Clone 200, Gen 192)
[17:04:02]
[17:04:02] Assembly optimizations on if available.
[17:04:02] Entering M.D.
[17:04:08] Working on p5506_supervillin_e1
[17:04:09] Client config found, loading data.
[17:04:09] Starting GUI Server
[17:04:09] mdrun_gpu returned
[17:04:09] NANs detected on GPU
[17:04:09]
[17:04:09] Folding@home Core Shutdown: UNSTABLE_MACHINE
[17:04:12] CoreStatus = 7A (122)
[17:04:12] Sending work to server
[17:04:12] Project: 5506 (Run 8, Clone 200, Gen 192)
[17:04:12] - Read packet limit of 540015616... Set to 524286976.
[17:04:12] - Error: Could not get length of results file work/wuresults_05.dat
[17:04:12] - Error: Could not read unit 05 file. Removing from queue.
[17:04:12] EUE limit exceeded. Pausing 24 hours.
Folding Tools:8 X PS3's, 5 x GTX280,1 x 8800GS, 8 x 9800GX2 GPU's
Re: Project: 5506 (Run 8, Clone 200, Gen 192)
There is another report for 0 credit ... it looks like a bad WU :(
Bobby-Uschi
Hardware configuration: PC1//C2Q-Q9450,GA-X48-DS5-NinjaMini,GTX285,2x160GB Western Sata2,2x1GB Geil800,Tagan 800W;XP Pro SP3-32Bit;
PC2//C2Q-Q2600k.GB-P67UD4-Freezer 7Pro,GTX285Leadtek,260 GB Western Sata2,4x2GB GeilPC3,OCZ600W;Win7-64Bit;Siemens 22"
Post by Bobby-Uschi »
20:37:25] Project: 5506 (Run 8, Clone 200, Gen 192)
[20:37:25]
[20:37:25] Assembly optimizations on if available.
[20:37:25] Entering M.D.
[20:37:31] Working on p5506_supervillin_e1
[20:37:31] Client config found, loading data.
[20:37:31] Starting GUI Server
[20:37:31] mdrun_gpu returned
[20:37:31] NANs detected on GPU
[20:37:31]
[20:37:31] Folding@home Core Shutdown: UNSTABLE_MACHINE
[20:37:38] CoreStatus = 7A (122)
[20:37:38] Sending work to server
[20:37:38] Project: 5506 (Run 8, Clone 200, Gen 192)
[20:37:38] - Read packet limit of 540015616... Set to 524286976.
[20:37:38] - Error: Could not get length of results file work/wuresults_02.dat
[20:37:38] - Error: Could not read unit 02 file. Removing from queue.
[20:37:38] EUE limit exceeded. Pausing 24 hours.
Bad WU-killen!!
PC1//C2Q-Q9450,GA-X48-DS5-,2xGTX285,2x160GB Western Sata2,2x1GB Geil800,Tagan 800W;XP Pro SP3-32Bit
PC2//C2Q-Q2600k.GB-P67UD4-Freezer 7Pro,GTX285Leadtek,260 GB WeSata2,4x2GB GeilPC3,OCZ600W;Win7-64Bit;Siemens 22"stern
hackman2007
Post by hackman2007 »
I'm getting hit by it too, grrrrr.
[14:43:40] Folding@Home GPU Core - Beta
[14:43:40] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[14:43:40]
[14:43:40] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[14:43:40] Build host: amoeba
[14:43:40] Board Type: Nvidia
[14:43:40] Core      :
[14:43:40] Preparing to commence simulation
[14:43:40] - Looking at optimizations...
[14:43:40] - Created dyn
[14:43:40] - Files status OK
[14:43:40] - Expanded 45864 -> 246249 (decompressed 536.9 percent)
[14:43:40] Called DecompressByteArray: compressed_data_size=45864 data_size=246249, decompressed_data_size=246249 diff=0
[14:43:40] - Digital signature verified
[14:43:40]
[14:43:40] Project: 5506 (Run 8, Clone 200, Gen 192)
[14:43:40]
[14:43:40] Assembly optimizations on if available.
[14:43:40] Entering M.D.
[14:43:46] Working on p5506_supervillin_e1
[14:43:47] Client config found, loading data.
[14:43:47] mdrun_gpu returned
[14:43:47] NANs detected on GPU
[14:43:47]
[14:43:47] Folding@home Core Shutdown: UNSTABLE_MACHINE
[14:43:51] CoreStatus = 7A (122)
[14:43:51] Sending work to server
[14:43:51] Project: 5506 (Run 8, Clone 200, Gen 192)
[14:43:51] - Error: Could not get length of results file work/wuresults_03.dat
[14:43:51] - Error: Could not read unit 03 file. Removing from queue.
[14:43:51] - Preparing to get new work unit...
[14:43:51] + Attempting to get work packet
[14:43:51] - Connecting to assignment server
[14:43:51] - Successful: assigned to (171.64.65.106).
[14:43:51] + News From Folding@Home: GPU folding beta
[14:43:51] Loaded queue successfully.
[14:43:52] + Closed connections
[14:43:57]
[14:43:57] + Processing work unit
[14:43:57] Core required: FahCore_11.exe
[14:43:57] Core found.
[14:43:57] Working on queue slot 04 [November 16 14:43:57 UTC]
[14:43:57] + Working ...
[14:43:57]
[14:43:57] *------------------------------*
[14:43:57] Folding@Home GPU Core - Beta
[14:43:57] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[14:43:57]
[14:43:57] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[14:43:57] Build host: amoeba
[14:43:57] Board Type: Nvidia
[14:43:57] Core      :
[14:43:57] Preparing to commence simulation
[14:43:57] - Looking at optimizations...
[14:43:57] - Created dyn
[14:43:57] - Files status OK
[14:43:57] - Expanded 45864 -> 246249 (decompressed 536.9 percent)
[14:43:57] Called DecompressByteArray: compressed_data_size=45864 data_size=246249, decompressed_data_size=246249 diff=0
[14:43:57] - Digital signature verified
[14:43:57]
[14:43:57] Project: 5506 (Run 8, Clone 200, Gen 192)
[14:43:57]
[14:43:57] Assembly optimizations on if available.
[14:43:57] Entering M.D.
[14:44:03] Working on p5506_supervillin_e1
[14:44:04] Client config found, loading data.
[14:44:04] mdrun_gpu returned
[14:44:04] NANs detected on GPU
[14:44:04]
[14:44:04] Folding@home Core Shutdown: UNSTABLE_MACHINE
[14:44:08] CoreStatus = 7A (122)
[14:44:08] Sending work to server
[14:44:08] Project: 5506 (Run 8, Clone 200, Gen 192)
[14:44:08] - Error: Could not get length of results file work/wuresults_04.dat
[14:44:08] - Error: Could not read unit 04 file. Removing from queue.
[14:44:08] - Preparing to get new work unit...
[14:44:08] + Attempting to get work packet
[14:44:08] - Connecting to assignment server
[14:44:08] - Successful: assigned to (171.64.65.106).
[14:44:08] + News From Folding@Home: GPU folding beta
[14:44:08] Loaded queue successfully.
[14:44:09] + Closed connections
[14:44:14]
[14:44:14] + Processing work unit
[14:44:14] Core required: FahCore_11.exe
[14:44:14] Core found.
[14:44:14] Working on queue slot 05 [November 16 14:44:14 UTC]
[14:44:14] + Working ...
[14:44:14]
[14:44:14] *------------------------------*
[14:44:14] Folding@Home GPU Core - Beta
[14:44:14] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[14:44:15]
[14:44:15] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[14:44:15] Build host: amoeba
[14:44:15] Board Type: Nvidia
[14:44:15] Core      :
[14:44:15] Preparing to commence simulation
[14:44:15] - Looking at optimizations...
[14:44:15] - Created dyn
[14:44:15] - Files status OK
[14:44:15] - Expanded 45864 -> 246249 (decompressed 536.9 percent)
[14:44:15] Called DecompressByteArray: compressed_data_size=45864 data_size=246249, decompressed_data_size=246249 diff=0
[14:44:15] - Digital signature verified
[14:44:15]
[14:44:15] Project: 5506 (Run 8, Clone 200, Gen 192)
[14:44:15]
[14:44:15] Assembly optimizations on if available.
[14:44:15] Entering M.D.
[14:44:22] Working on p5506_supervillin_e1
[14:44:23] Client config found, loading data.
[14:44:23] mdrun_gpu returned
[14:44:23] NANs detected on GPU
[14:44:23]
[14:44:23] Folding@home Core Shutdown: UNSTABLE_MACHINE
[14:44:27] CoreStatus = 7A (122)
[14:44:27] Sending work to server
[14:44:27] Project: 5506 (Run 8, Clone 200, Gen 192)
[14:44:27] - Error: Could not get length of results file work/wuresults_05.dat
[14:44:27] - Error: Could not read unit 05 file. Removing from queue.
[14:44:27] - Preparing to get new work unit...
[14:44:27] + Attempting to get work packet
[14:44:27] - Connecting to assignment server
[14:44:27] - Successful: assigned to (171.64.65.106).
[14:44:27] + News From Folding@Home: GPU folding beta
[14:44:27] Loaded queue successfully.
[14:44:28] + Closed connections
[14:44:33]
[14:44:33] + Processing work unit
[14:44:33] Core required: FahCore_11.exe
[14:44:33] Core found.
[14:44:33] Working on queue slot 06 [November 16 14:44:33 UTC]
[14:44:33] + Working ...
[14:44:33]
[14:44:33] *------------------------------*
[14:44:33] Folding@Home GPU Core - Beta
[14:44:33] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[14:44:33]
[14:44:33] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[14:44:33] Build host: amoeba
[14:44:33] Board Type: Nvidia
[14:44:33] Core      :
[14:44:33] Preparing to commence simulation
[14:44:33] - Looking at optimizations...
[14:44:33] - Created dyn
[14:44:33] - Files status OK
[14:44:33] - Expanded 45864 -> 246249 (decompressed 536.9 percent)
[14:44:33] Called DecompressByteArray: compressed_data_size=45864 data_size=246249, decompressed_data_size=246249 diff=0
[14:44:33] - Digital signature verified
[14:44:33]
[14:44:33] Project: 5506 (Run 8, Clone 200, Gen 192)
[14:44:33]
[14:44:33] Assembly optimizations on if available.
[14:44:33] Entering M.D.
[14:44:40] Working on p5506_supervillin_e1
[14:44:40] Client config found, loading data.
[14:44:40] mdrun_gpu returned
[14:44:40] NANs detected on GPU
[14:44:40]
[14:44:40] Folding@home Core Shutdown: UNSTABLE_MACHINE
[14:44:40] Starting GUI Server
[14:44:44] CoreStatus = 7A (122)
[14:44:44] Sending work to server
[14:44:44] Project: 5506 (Run 8, Clone 200, Gen 192)
[14:44:44] - Error: Could not get length of results file work/wuresults_06.dat
[14:44:44] - Error: Could not read unit 06 file. Removing from queue.
[14:44:44] - Preparing to get new work unit...
[14:44:44] + Attempting to get work packet
[14:44:44] - Connecting to assignment server
[14:44:44] - Successful: assigned to (171.64.65.106).
[14:44:44] + News From Folding@Home: GPU folding beta
[14:44:44] Loaded queue successfully.
[14:44:45] + Closed connections
[14:44:50]
[14:44:50] + Processing work unit
[14:44:50] Core required: FahCore_11.exe
[14:44:50] Core found.
[14:44:50] Working on queue slot 07 [November 16 14:44:50 UTC]
[14:44:50] + Working ...
[14:44:50]
[14:44:50] *------------------------------*
[14:44:50] Folding@Home GPU Core - Beta
[14:44:50] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[14:44:50]
[14:44:50] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[14:44:50] Build host: amoeba
[14:44:50] Board Type: Nvidia
[14:44:50] Core      :
[14:44:50] Preparing to commence simulation
[14:44:50] - Looking at optimizations...
[14:44:50] - Created dyn
[14:44:50] - Files status OK
[14:44:50] - Expanded 45864 -> 246249 (decompressed 536.9 percent)
[14:44:50] Called DecompressByteArray: compressed_data_size=45864 data_size=246249, decompressed_data_size=246249 diff=0
[14:44:50] - Digital signature verified
[14:44:50]
[14:44:50] Project: 5506 (Run 8, Clone 200, Gen 192)
[14:44:50]
[14:44:50] Assembly optimizations on if available.
[14:44:50] Entering M.D.
[14:44:56] Working on p5506_supervillin_e1
[14:44:57] Client config found, loading data.
[14:44:57] mdrun_gpu returned
[14:44:57] NANs detected on GPU
[14:44:57]
[14:44:57] Folding@home Core Shutdown: UNSTABLE_MACHINE
[14:45:01] CoreStatus = 7A (122)
[14:45:01] Sending work to server
[14:45:01] Project: 5506 (Run 8, Clone 200, Gen 192)
[14:45:01] - Error: Could not get length of results file work/wuresults_07.dat
[14:45:01] - Error: Could not read unit 07 file. Removing from queue.
[14:45:01] EUE limit exceeded. Pausing 24 hours.
MichaelO
Post by MichaelO »
I have had this same WU stop one of my GPU's twicw now in 18 hours. I lost the entire night of folding thanks to this project and just got hit with it again. Is there no way to get this thing either pulled or corrected???
dschief
Hardware configuration: Gigabyte Z790 UD AC , i7-14700K (x2) Win11
ASUS Z97_K , i5-4460 (x2) Win10 & UBUNTU 24.04
GPU's ASUS RTX1660 x2, RTX3050 x2
EVGA1060
Post by dschief »
I've got this one also, crashes as soon as it loads. over and over. forceing 24 hr suspension.
00:28:28] + Attempting to get work packet
[00:28:28] - Will indicate memory of 2044 MB
[00:28:28] - Connecting to assignment server
[00:28:28] Connecting to http://assign-GPU.stanford.edu:8080/
[00:28:29] Posted data.
[00:28:29] Initial: 40AB; - Successful: assigned to (171.64.65.106).
[00:28:29] + News From Folding@Home: GPU folding beta
[00:28:29] Loaded queue successfully.
[00:28:29] Connecting to http://171.64.65.106:8080/
[00:28:29] Initial: 0000; - Receiving payload (expected size: 46376)
[00:28:29] Conversation time very short, giving reduced weight in bandwidth avg
[00:28:29] - Downloaded at ~90 kB/s
[00:28:29] - Averaged speed for that direction ~79 kB/s
[00:28:29] + Received work.
[00:28:29] Trying to send all finished work units
[00:28:29] + No unsent completed units remaining.
[00:28:29] + Closed connections
[00:28:29]
[00:28:29] + Processing work unit
[00:28:29] Core required: FahCore_11.exe
[00:28:29] Core found.
[00:28:29] Working on queue slot 03 [November 20 00:28:29 UTC]
[00:28:29] + Working ...
[00:28:29] - Calling '.\FahCore_11.exe -dir work/ -suffix 03 -priority 96 -checkpoint 6 -verbose -lifeline 2012 -version 620'
[00:28:29]
[00:28:29] *------------------------------*
[00:28:29] Folding@Home GPU Core - Beta
[00:28:29] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[00:28:29]
[00:28:29] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[00:28:29] Build host: amoeba
[00:28:29] Board Type: Nvidia
[00:28:29] Core      :
[00:28:29] Preparing to commence simulation
[00:28:29] - Looking at optimizations...
[00:28:29] - Created dyn
[00:28:29] - Files status OK
[00:28:29] - Expanded 45864 -> 246249 (decompressed 536.9 percent)
[00:28:29] Called DecompressByteArray: compressed_data_size=45864 data_size=246249, decompressed_data_size=246249 diff=0
[00:28:29] - Digital signature verified
[00:28:29]
[00:28:29] Project: 5506 (Run 8, Clone 200, Gen 192)
[00:28:29]
[00:28:29] Assembly optimizations on if available.
[00:28:29] Entering M.D.
[00:28:36] Working on p5506_supervillin_e1
[00:28:36] Client config found, loading data.
[00:28:36] mdrun_gpu returned
[00:28:36] NANs detected on GPU
[00:28:36]
[00:28:36] Folding@home Core Shutdown: UNSTABLE_MACHINE
[00:28:40] CoreStatus = 7A (122)
[00:28:40] Sending work to server
[00:28:40] Project: 5506 (Run 8, Clone 200, Gen 192)
[00:28:40] - Read packet limit of 540015616... Set to 524286976.
[00:28:40] - Error: Could not get length of results file work/wuresults_03.dat
[00:28:40] - Error: Could not read unit 03 file. Removing from queue.
[00:28:40] Trying to send all finished work units
[00:28:40] + No unsent completed units remaining.
[00:28:40] - Preparing to get new work unit...
[00:28:40] + Attempting to get work packet
[00:28:40] - Will indicate memory of 2044 MB
[00:28:40] - Connecting to assignment server
[00:28:40] Connecting to http://assign-GPU.stanford.edu:8080/
[00:28:40] Posted data.
[00:28:40] Initial: 40AB; - Successful: assigned to (171.64.65.106).
[00:28:40] + News From Folding@Home: GPU folding beta
[00:28:40] Loaded queue successfully.
[00:28:40] Connecting to http://171.64.65.106:8080/
[00:28:40] Initial: 0000; - Receiving payload (expected size: 46376)
[00:28:40] Conversation time very short, giving reduced weight in bandwidth avg
[00:28:40] - Downloaded at ~90 kB/s
[00:28:40] - Averaged speed for that direction ~80 kB/s
[00:28:40] + Received work.
[00:28:40] + Closed connections
[00:28:45]
[00:28:45] + Processing work unit
[00:28:45] Core required: FahCore_11.exe
[00:28:45] Core found.
[00:28:45] Working on queue slot 04 [November 20 00:28:45 UTC]
[00:28:45] + Working ...
[00:28:45] - Calling '.\FahCore_11.exe -dir work/ -suffix 04 -priority 96 -checkpoint 6 -verbose -lifeline 2012 -version 620'
[00:28:45]
[00:28:45] *------------------------------*
[00:28:45] Folding@Home GPU Core - Beta
[00:28:45] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[00:28:45]
[00:28:45] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[00:28:45] Build host: amoeba
[00:28:45] Board Type: Nvidia
[00:28:45] Core      :
[00:28:45] Preparing to commence simulation
[00:28:45] - Looking at optimizations...
[00:28:45] - Created dyn
[00:28:45] - Files status OK
[00:28:45] - Expanded 45864 -> 246249 (decompressed 536.9 percent)
[00:28:45] Called DecompressByteArray: compressed_data_size=45864 data_size=246249, decompressed_data_size=246249 diff=0
[00:28:45] - Digital signature verified
[00:28:45]
[00:28:45] Project: 5506 (Run 8, Clone 200, Gen 192)
[00:28:45]
[00:28:45] Assembly optimizations on if available.
[00:28:45] Entering M.D.
[00:28:52] Working on p5506_supervillin_e1
[00:28:52] Client config found, loading data.
[00:28:52] mdrun_gpu returned
[00:28:52] NANs detected on GPU
[00:28:52]
[00:28:52] Folding@home Core Shutdown: UNSTABLE_MACHINE
[00:28:56] CoreStatus = 7A (122)
[00:28:56] Sending work to server
[00:28:56] Project: 5506 (Run 8, Clone 200, Gen 192)
[00:28:56] - Read packet limit of 540015616... Set to 524286976.
[00:28:56] - Error: Could not get length of results file work/wuresults_04.dat
[00:28:56] - Error: Could not read unit 04 file. Removing from queue.
[00:28:56] Trying to send all finished work units
[00:28:56] + No unsent completed units remaining.
[00:28:56] - Preparing to get new work unit...
[00:28:56] + Attempting to get work packet
[00:28:56] - Will indicate memory of 2044 MB
[00:28:56] - Connecting to assignment server
[00:28:56] Connecting to http://assign-GPU.stanford.edu:8080/
[00:28:56] Posted data.
[00:28:56] Initial: 40AB; - Successful: assigned to (171.64.65.106).
[00:28:56] + News From Folding@Home: GPU folding beta
[00:28:56] Loaded queue successfully.
[00:28:56] Connecting to http://171.64.65.106:8080/
[00:28:56] Initial: 0000; - Receiving payload (expected size: 46376)
[00:28:57] - Downloaded at ~45 kB/s
[00:28:57] - Averaged speed for that direction ~73 kB/s
[00:28:57] + Received work.
[00:28:57] Trying to send all finished work units
[00:28:57] + No unsent completed units remaining.
[00:28:57] + Closed connections
[00:29:02]
[00:29:02] + Processing work unit
[00:29:02] Core required: FahCore_11.exe
[00:29:02] Core found.
[00:29:02] Working on queue slot 05 [November 20 00:29:02 UTC]
[00:29:02] + Working ...
[00:29:02] - Calling '.\FahCore_11.exe -dir work/ -suffix 05 -priority 96 -checkpoint 6 -verbose -lifeline 2012 -version 620'
[00:29:02]
[00:29:02] *------------------------------*
[00:29:02] Folding@Home GPU Core - Beta
[00:29:02] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[00:29:02]
[00:29:02] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[00:29:02] Build host: amoeba
[00:29:02] Board Type: Nvidia
[00:29:02] Core      :
[00:29:02] Preparing to commence simulation
[00:29:02] - Looking at optimizations...
[00:29:02] - Created dyn
[00:29:02] - Files status OK
[00:29:02] - Expanded 45864 -> 246249 (decompressed 536.9 percent)
[00:29:02] Called DecompressByteArray: compressed_data_size=45864 data_size=246249, decompressed_data_size=246249 diff=0
[00:29:02] - Digital signature verified
[00:29:02]
[00:29:02] Project: 5506 (Run 8, Clone 200, Gen 192)
[00:29:02]
[00:29:02] Assembly optimizations on if available.
[00:29:02] Entering M.D.
[00:29:08] Working on p5506_supervillin_e1
[00:29:09] Client config found, loading data.
[00:29:09] mdrun_gpu returned
[00:29:09] NANs detected on GPU
[00:29:09]
[00:29:09] Folding@home Core Shutdown: UNSTABLE_MACHINE
[00:29:12] CoreStatus = 7A (122)
[00:29:12] Sending work to server
[00:29:12] Project: 5506 (Run 8, Clone 200, Gen 192)
[00:29:12] - Read packet limit of 540015616... Set to 524286976.
[00:29:12] - Error: Could not get length of results file work/wuresults_05.dat
[00:29:12] - Error: Could not read unit 05 file. Removing from queue.
[00:29:12] Trying to send all finished work units
[00:29:12] + No unsent completed units remaining.
[00:29:12] - Preparing to get new work unit...
[00:29:12] + Attempting to get work packet
[00:29:12] - Will indicate memory of 2044 MB
[00:29:12] - Connecting to assignment server
[00:29:12] Connecting to http://assign-GPU.stanford.edu:8080/
[00:29:12] Posted data.
[00:29:12] Initial: 40AB; - Successful: assigned to (171.64.65.106).
[00:29:12] + News From Folding@Home: GPU folding beta
[00:29:12] Loaded queue successfully.
[00:29:12] Connecting to http://171.64.65.106:8080/
[00:29:12] Initial: 0000; - Receiving payload (expected size: 46376)
[00:29:13] - Downloaded at ~45 kB/s
[00:29:13] - Averaged speed for that direction ~67 kB/s
[00:29:13] + Received work.
[00:29:13] Trying to send all finished work units
[00:29:13] + No unsent completed units remaining.
[00:29:13] + Closed connections
[00:29:18]
[00:29:18] + Processing work unit
[00:29:18] Core required: FahCore_11.exe
[00:29:18] Core found.
[00:29:18] Working on queue slot 06 [November 20 00:29:18 UTC]
[00:29:18] + Working ...
[00:29:18] - Calling '.\FahCore_11.exe -dir work/ -suffix 06 -priority 96 -checkpoint 6 -verbose -lifeline 2012 -version 620'
[00:29:18]
[00:29:18] *------------------------------*
[00:29:18] Folding@Home GPU Core - Beta
[00:29:18] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[00:29:18]
[00:29:18] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[00:29:18] Build host: amoeba
[00:29:18] Board Type: Nvidia
[00:29:18] Core      :
[00:29:18] Preparing to commence simulation
[00:29:18] - Looking at optimizations...
[00:29:18] - Created dyn
[00:29:18] - Files status OK
[00:29:18] - Expanded 45864 -> 246249 (decompressed 536.9 percent)
[00:29:18] Called DecompressByteArray: compressed_data_size=45864 data_size=246249, decompressed_data_size=246249 diff=0
[00:29:18] - Digital signature verified
[00:29:18]
[00:29:18] Project: 5506 (Run 8, Clone 200, Gen 192)
[00:29:18]
[00:29:18] Assembly optimizations on if available.
[00:29:18] Entering M.D.
[00:29:24] Working on p5506_supervillin_e1
[00:29:25] Client config found, loading data.
[00:29:25] mdrun_gpu returned
[00:29:25] NANs detected on GPU
[00:29:25]
[00:29:25] Folding@home Core Shutdown: UNSTABLE_MACHINE
[00:29:28] CoreStatus = 7A (122)
[00:29:28] Sending work to server
[00:29:28] Project: 5506 (Run 8, Clone 200, Gen 192)
[00:29:28] - Read packet limit of 540015616... Set to 524286976.
[00:29:28] - Error: Could not get length of results file work/wuresults_06.dat
[00:29:28] - Error: Could not read unit 06 file. Removing from queue.
[00:29:28] Trying to send all finished work units
[00:29:28] + No unsent completed units remaining.
[00:29:28] - Preparing to get new work unit...
[00:29:28] + Attempting to get work packet
[00:29:28] - Will indicate memory of 2044 MB
[00:29:28] - Connecting to assignment server
[00:29:28] Connecting to http://assign-GPU.stanford.edu:8080/
[00:29:28] Posted data.
[00:29:28] Initial: 40AB; - Successful: assigned to (171.64.65.106).
[00:29:28] + News From Folding@Home: GPU folding beta
[00:29:28] Loaded queue successfully.
[00:29:28] Connecting to http://171.64.65.106:8080/
[00:29:28] Initial: 0000; - Receiving payload (expected size: 46376)
[00:29:29] - Downloaded at ~45 kB/s
[00:29:29] - Averaged speed for that direction ~63 kB/s
[00:29:29] + Received work.
[00:29:29] Trying to send all finished work units
[00:29:29] + No unsent completed units remaining.
[00:29:29] + Closed connections
[00:29:34]
[00:29:34] + Processing work unit
[00:29:34] Core required: FahCore_11.exe
[00:29:34] Core found.
[00:29:34] Working on queue slot 07 [November 20 00:29:34 UTC]
[00:29:34] + Working ...
[00:29:34] - Calling '.\FahCore_11.exe -dir work/ -suffix 07 -priority 96 -checkpoint 6 -verbose -lifeline 2012 -version 620'
[00:29:34]
[00:29:34] *------------------------------*
[00:29:34] Folding@Home GPU Core - Beta
[00:29:34] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[00:29:34]
[00:29:34] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[00:29:34] Build host: amoeba
[00:29:34] Board Type: Nvidia
[00:29:34] Core      :
[00:29:34] Preparing to commence simulation
[00:29:34] - Looking at optimizations...
[00:29:34] - Created dyn
[00:29:34] - Files status OK
[00:29:34] - Expanded 45864 -> 246249 (decompressed 536.9 percent)
[00:29:34] Called DecompressByteArray: compressed_data_size=45864 data_size=246249, decompressed_data_size=246249 diff=0
[00:29:34] - Digital signature verified
[00:29:34]
[00:29:34] Project: 5506 (Run 8, Clone 200, Gen 192)
[00:29:34]
[00:29:34] Assembly optimizations on if available.
[00:29:34] Entering M.D.
[00:29:40] Working on p5506_supervillin_e1
[00:29:41] Client config found, loading data.
[00:29:41] mdrun_gpu returned
[00:29:41] NANs detected on GPU
[00:29:41]
[00:29:41] Folding@home Core Shutdown: UNSTABLE_MACHINE
[00:29:44] CoreStatus = 7A (122)
[00:29:44] Sending work to server
[00:29:44] Project: 5506 (Run 8, Clone 200, Gen 192)
[00:29:44] - Read packet limit of 540015616... Set to 524286976.
[00:29:44] - Error: Could not get length of results file work/wuresults_07.dat
[00:29:44] - Error: Could not read unit 07 file. Removing from queue.
[00:29:44] EUE limit exceeded. Pausing 24 hours.
[00:31:08] - Autosending finished units... [November 20 00:31:08 UTC]
[00:31:08] Trying to send all finished work units
[00:31:08] + No unsent completed units remaining.
[00:31:08] - Autosend completed
[00:31:08] + Working...
how much more time needs to be wasted before this is pulled
MtM
Hardware configuration: Q6600 - 8gb - p5q deluxe - gtx275 - hd4350 ( not folding ) win7 x64 - smp:4 - gpu slot
T5450 - 4gb - ?? - 8600M GT 512 ( DDR2 ) - win7 x64 - smp:2 - gpu slot
Post by MtM »
Grrrr... you to?? This really needs a client/server fix, either the clients need to be able to report their results where corrupted and that someone needs to look at the wu or the servers should not keep sending this wu out if their not getting any reports back on the results.
dschief
EVGA1060
Post by dschief »
Checked again this am, when I got up to make coffee. Same machine froze up with this same Wu .
getting really tired of this
06:16:54] Project: 5506 (Run 8, Clone 95, Gen 256)
[06:16:54] - Read packet limit of 540015616... Set to 524286976.
[06:16:54] + Attempting to send results [November 20 06:16:54 UTC]
[06:16:54] - Reading file work/wuresults_05.dat from core
[06:16:54]   (Read 1180142 bytes from disk)
[06:16:54] Connecting to http://171.64.65.106:8080/
[06:17:25] Posted data.
[06:17:25] Initial: 0000; - Uploaded at ~34 kB/s
[06:17:27] - Averaged speed for that direction ~35 kB/s
[06:17:27] + Results successfully sent
[06:17:27] Thank you for your contribution to Folding@Home.
[06:17:27] + Number of Units Completed: 699
[06:17:31] Trying to send all finished work units
[06:17:31] + No unsent completed units remaining.
[06:17:31] - Preparing to get new work unit...
[06:17:31] + Attempting to get work packet
[06:17:31] - Will indicate memory of 2046 MB
[06:17:31] - Connecting to assignment server
[06:17:31] Connecting to http://assign-GPU.stanford.edu:8080/
[06:17:31] Posted data.
[06:17:31] Initial: 40AB; - Successful: assigned to (171.64.65.106).
[06:17:31] + News From Folding@Home: GPU folding beta
[06:17:31] Loaded queue successfully.
[06:17:31] Connecting to http://171.64.65.106:8080/
[06:17:32] Posted data.
[06:17:32] Initial: 0000; - Receiving payload (expected size: 46376)
[06:17:32] Conversation time very short, giving reduced weight in bandwidth avg
[06:17:32] - Downloaded at ~90 kB/s
[06:17:32] - Averaged speed for that direction ~72 kB/s
[06:17:32] + Received work.
[06:17:32] Trying to send all finished work units
[06:17:32] + No unsent completed units remaining.
[06:17:32] + Closed connections
[06:17:32]
[06:17:32] + Processing work unit
[06:17:32] Core required: FahCore_11.exe
[06:17:32] Core found.
[06:17:32] Working on queue slot 06 [November 20 06:17:32 UTC]
[06:17:32] + Working ...
[06:17:32] - Calling '.\FahCore_11.exe -dir work/ -suffix 06 -priority 96 -nocpulock -checkpoint 15 -verbose -lifeline 5312 -version 620'
[06:17:32]
[06:17:32] *------------------------------*
[06:17:32] Folding@Home GPU Core - Beta
[06:17:32] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[06:17:32]
[06:17:32] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[06:17:32] Build host: amoeba
[06:17:32] Board Type: Nvidia
[06:17:32] Core      :
[06:17:32] Preparing to commence simulation
[06:17:32] - Looking at optimizations...
[06:17:32] - Created dyn
[06:17:32] - Files status OK
[06:17:32] - Expanded 45864 -> 246249 (decompressed 536.9 percent)
[06:17:32] Called DecompressByteArray: compressed_data_size=45864 data_size=246249, decompressed_data_size=246249 diff=0
[06:17:32] - Digital signature verified
[06:17:32]
[06:17:32] Project: 5506 (Run 8, Clone 200, Gen 192)
[06:17:32]
[06:17:32] Assembly optimizations on if available.
[06:17:32] Entering M.D.
[06:17:38] Working on p5506_supervillin_e1
[06:17:39] Client config found, loading data.
[06:17:39] Starting GUI Server
[06:17:39] mdrun_gpu returned
[06:17:39] NANs detected on GPU
[06:17:39]
[06:17:39] Folding@home Core Shutdown: UNSTABLE_MACHINE
[06:17:42] CoreStatus = 7A (122)
[06:17:42] Sending work to server
[06:17:42] Project: 5506 (Run 8, Clone 200, Gen 192)
[06:17:42] - Read packet limit of 540015616... Set to 524286976.
[06:17:42] - Error: Could not get length of results file work/wuresults_06.dat
[06:17:42] - Error: Could not read unit 06 file. Removing from queue.
[06:17:42] Trying to send all finished work units
[06:17:42] + No unsent completed units remaining.
[06:17:42] - Preparing to get new work unit...
[06:17:42] + Attempting to get work packet
[06:17:42] - Will indicate memory of 2046 MB
[06:17:42] - Connecting to assignment server
[06:17:42] Connecting to http://assign-GPU.stanford.edu:8080/
[06:17:43] Posted data.
[06:17:43] Initial: 40AB; - Successful: assigned to (171.64.65.106).
[06:17:43] + News From Folding@Home: GPU folding beta
[06:17:43] Loaded queue successfully.
[06:17:43] Connecting to http://171.64.65.106:8080/
[06:17:43] Initial: 0000; - Receiving payload (expected size: 46376)
[06:17:43] Conversation time very short, giving reduced weight in bandwidth avg
[06:17:43] - Downloaded at ~90 kB/s
[06:17:43] - Averaged speed for that direction ~74 kB/s
[06:17:43] + Received work.
[06:17:43] Trying to send all finished work units
[06:17:43] + No unsent completed units remaining.
[06:17:43] + Closed connections
[06:17:49]
[06:17:49] + Processing work unit
[06:17:49] Core required: FahCore_11.exe
[06:17:49] Core found.
[06:17:49] Working on queue slot 07 [November 20 06:17:49 UTC]
[06:17:49] + Working ...
[06:17:49] - Calling '.\FahCore_11.exe -dir work/ -suffix 07 -priority 96 -nocpulock -checkpoint 15 -verbose -lifeline 5312 -version 620'
[06:17:49]
[06:17:49] *------------------------------*
[06:17:49] Folding@Home GPU Core - Beta
[06:17:49] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[06:17:49]
[06:17:49] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[06:17:49] Build host: amoeba
[06:17:49] Board Type: Nvidia
[06:17:49] Core      :
[06:17:49] Preparing to commence simulation
[06:17:49] - Looking at optimizations...
[06:17:49] - Created dyn
[06:17:49] - Files status OK
[06:17:49] - Expanded 45864 -> 246249 (decompressed 536.9 percent)
[06:17:49] Called DecompressByteArray: compressed_data_size=45864 data_size=246249, decompressed_data_size=246249 diff=0
[06:17:49] - Digital signature verified
[06:17:49]
[06:17:49] Project: 5506 (Run 8, Clone 200, Gen 192)
[06:17:49]
[06:17:49] Assembly optimizations on if available.
[06:17:49] Entering M.D.
[06:17:55] Working on p5506_supervillin_e1
[06:17:55] Client config found, loading data.
[06:17:55] Starting GUI Server
[06:17:55] mdrun_gpu returned
[06:17:55] NANs detected on GPU
[06:17:55]
[06:17:55] Folding@home Core Shutdown: UNSTABLE_MACHINE
[06:17:59] CoreStatus = 7A (122)
[06:17:59] Sending work to server
[06:17:59] Project: 5506 (Run 8, Clone 200, Gen 192)
[06:17:59] - Read packet limit of 540015616... Set to 524286976.
[06:17:59] - Error: Could not get length of results file work/wuresults_07.dat
[06:17:59] - Error: Could not read unit 07 file. Removing from queue.
[06:17:59] Trying to send all finished work units
[06:17:59] + No unsent completed units remaining.
[06:17:59] - Preparing to get new work unit...
[06:17:59] + Attempting to get work packet
[06:17:59] - Will indicate memory of 2046 MB
[06:17:59] - Connecting to assignment server
[06:17:59] Connecting to http://assign-GPU.stanford.edu:8080/
[06:17:59] Posted data.
[06:17:59] Initial: 40AB; - Successful: assigned to (171.64.65.106).
[06:17:59] + News From Folding@Home: GPU folding beta
[06:17:59] Loaded queue successfully.
[06:17:59] Connecting to http://171.64.65.106:8080/
[06:18:00] Posted data.
[06:18:00] Initial: 0000; - Receiving payload (expected size: 46376)
[06:18:00] Conversation time very short, giving reduced weight in bandwidth avg
[06:18:00] - Downloaded at ~90 kB/s
[06:18:00] - Averaged speed for that direction ~76 kB/s
[06:18:00] + Received work.
[06:18:00] Trying to send all finished work units
[06:18:00] + No unsent completed units remaining.
[06:18:00] + Closed connections
[06:18:05]
[06:18:05] + Processing work unit
[06:18:05] Core required: FahCore_11.exe
[06:18:05] Core found.
[06:18:05] Working on queue slot 08 [November 20 06:18:05 UTC]
[06:18:05] + Working ...
[06:18:05] - Calling '.\FahCore_11.exe -dir work/ -suffix 08 -priority 96 -nocpulock -checkpoint 15 -verbose -lifeline 5312 -version 620'
[06:18:05]
[06:18:05] *------------------------------*
[06:18:05] Folding@Home GPU Core - Beta
[06:18:05] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[06:18:05]
[06:18:05] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[06:18:05] Build host: amoeba
[06:18:05] Board Type: Nvidia
[06:18:05] Core      :
[06:18:05] Preparing to commence simulation
[06:18:05] - Looking at optimizations...
[06:18:05] - Created dyn
[06:18:05] - Files status OK
[06:18:05] - Expanded 45864 -> 246249 (decompressed 536.9 percent)
[06:18:05] Called DecompressByteArray: compressed_data_size=45864 data_size=246249, decompressed_data_size=246249 diff=0
[06:18:05] - Digital signature verified
[06:18:05]
[06:18:05] Project: 5506 (Run 8, Clone 200, Gen 192)
[06:18:05]
[06:18:05] Assembly optimizations on if available.
[06:18:05] Entering M.D.
[06:18:12] Working on p5506_supervillin_e1
[06:18:12] Client config found, loading data.
[06:18:12] mdrun_gpu returned
[06:18:12] NANs detected on GPU
[06:18:12]
[06:18:12] Folding@home Core Shutdown: UNSTABLE_MACHINE
[06:18:16] CoreStatus = 7A (122)
[06:18:16] Sending work to server
[06:18:16] Project: 5506 (Run 8, Clone 200, Gen 192)
[06:18:16] - Read packet limit of 540015616... Set to 524286976.
[06:18:16] - Error: Could not get length of results file work/wuresults_08.dat
[06:18:16] - Error: Could not read unit 08 file. Removing from queue.
[06:18:16] Trying to send all finished work units
[06:18:16] + No unsent completed units remaining.
[06:18:16] - Preparing to get new work unit...
[06:18:16] + Attempting to get work packet
[06:18:16] - Will indicate memory of 2046 MB
[06:18:16] - Connecting to assignment server
[06:18:16] Connecting to http://assign-GPU.stanford.edu:8080/
[06:18:16] Posted data.
[06:18:16] Initial: 40AB; - Successful: assigned to (171.64.65.106).
[06:18:16] + News From Folding@Home: GPU folding beta
[06:18:16] Loaded queue successfully.
[06:18:16] Connecting to http://171.64.65.106:8080/
[06:18:17] Posted data.
[06:18:17] Initial: 0000; - Receiving payload (expected size: 46376)
[06:18:17] Conversation time very short, giving reduced weight in bandwidth avg
[06:18:17] - Downloaded at ~90 kB/s
[06:18:17] - Averaged speed for that direction ~78 kB/s
[06:18:17] + Received work.
[06:18:17] Trying to send all finished work units
[06:18:17] + No unsent completed units remaining.
[06:18:17] + Closed connections
[06:18:22]
[06:18:22] + Processing work unit
[06:18:22] Core required: FahCore_11.exe
[06:18:22] Core found.
[06:18:22] Working on queue slot 09 [November 20 06:18:22 UTC]
[06:18:22] + Working ...
[06:18:22] - Calling '.\FahCore_11.exe -dir work/ -suffix 09 -priority 96 -nocpulock -checkpoint 15 -verbose -lifeline 5312 -version 620'
[06:18:22]
[06:18:22] *------------------------------*
[06:18:22] Folding@Home GPU Core - Beta
[06:18:22] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[06:18:22]
[06:18:22] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[06:18:22] Build host: amoeba
[06:18:22] Board Type: Nvidia
[06:18:22] Core      :
[06:18:22] Preparing to commence simulation
[06:18:22] - Looking at optimizations...
[06:18:22] - Created dyn
[06:18:22] - Files status OK
[06:18:22] - Expanded 45864 -> 246249 (decompressed 536.9 percent)
[06:18:22] Called DecompressByteArray: compressed_data_size=45864 data_size=246249, decompressed_data_size=246249 diff=0
[06:18:22] - Digital signature verified
[06:18:22]
[06:18:22] Project: 5506 (Run 8, Clone 200, Gen 192)
[06:18:22]
[06:18:22] Assembly optimizations on if available.
[06:18:22] Entering M.D.
[06:18:28] Working on p5506_supervillin_e1
[06:18:29] Client config found, loading data.
[06:18:29] Starting GUI Server
[06:18:29] mdrun_gpu returned
[06:18:29] NANs detected on GPU
[06:18:29]
[06:18:29] Folding@home Core Shutdown: UNSTABLE_MACHINE
[06:18:32] CoreStatus = 7A (122)
[06:18:32] Sending work to server
[06:18:32] Project: 5506 (Run 8, Clone 200, Gen 192)
[06:18:32] - Read packet limit of 540015616... Set to 524286976.
[06:18:32] - Error: Could not get length of results file work/wuresults_09.dat
[06:18:32] - Error: Could not read unit 09 file. Removing from queue.
[06:18:32] Trying to send all finished work units
[06:18:32] + No unsent completed units remaining.
[06:18:32] - Preparing to get new work unit...
[06:18:32] + Attempting to get work packet
[06:18:32] - Will indicate memory of 2046 MB
[06:18:32] - Connecting to assignment server
[06:18:32] Connecting to http://assign-GPU.stanford.edu:8080/
[06:18:33] Posted data.
[06:18:33] Initial: 40AB; - Successful: assigned to (171.64.65.106).
[06:18:33] + News From Folding@Home: GPU folding beta
[06:18:33] Loaded queue successfully.
[06:18:33] Connecting to http://171.64.65.106:8080/
[06:18:33] Initial: 0000; - Receiving payload (expected size: 46376)
[06:18:33] Conversation time very short, giving reduced weight in bandwidth avg
[06:18:33] - Downloaded at ~90 kB/s
[06:18:33] - Averaged speed for that direction ~79 kB/s
[06:18:33] + Received work.
[06:18:33] Trying to send all finished work units
[06:18:33] + No unsent completed units remaining.
[06:18:33] + Closed connections
[06:18:38]
[06:18:38] + Processing work unit
[06:18:38] Core required: FahCore_11.exe
[06:18:38] Core found.
[06:18:38] Working on queue slot 00 [November 20 06:18:38 UTC]
[06:18:38] + Working ...
[06:18:38] - Calling '.\FahCore_11.exe -dir work/ -suffix 00 -priority 96 -nocpulock -checkpoint 15 -verbose -lifeline 5312 -version 620'
[06:18:39]
[06:18:39] *------------------------------*
[06:18:39] Folding@Home GPU Core - Beta
[06:18:39] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[06:18:39]
[06:18:39] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[06:18:39] Build host: amoeba
[06:18:39] Board Type: Nvidia
[06:18:39] Core      :
[06:18:39] Preparing to commence simulation
[06:18:39] - Looking at optimizations...
[06:18:39] - Created dyn
[06:18:39] - Files status OK
[06:18:39] - Expanded 45864 -> 246249 (decompressed 536.9 percent)
[06:18:39] Called DecompressByteArray: compressed_data_size=45864 data_size=246249, decompressed_data_size=246249 diff=0
[06:18:39] - Digital signature verified
[06:18:39]
[06:18:39] Project: 5506 (Run 8, Clone 200, Gen 192)
[06:18:39]
[06:18:39] Assembly optimizations on if available.
[06:18:39] Entering M.D.
[06:18:45] Working on p5506_supervillin_e1
[06:18:45] Client config found, loading data.
[06:18:45] mdrun_gpu returned
[06:18:45] NANs detected on GPU
[06:18:45]
[06:18:45] Folding@home Core Shutdown: UNSTABLE_MACHINE
[06:18:49] CoreStatus = 7A (122)
[06:18:49] Sending work to server
[06:18:49] Project: 5506 (Run 8, Clone 200, Gen 192)
[06:18:49] - Read packet limit of 540015616... Set to 524286976.
[06:18:49] - Error: Could not get length of results file work/wuresults_00.dat
[06:18:49] - Error: Could not read unit 00 file. Removing from queue.
[06:18:49] EUE limit exceeded. Pausing 24 hours.
[10:33:22] - Autosending finished units... [November 20 10:33:22 UTC]
[10:33:22] Trying to send all finished work units
[10:33:22] + No unsent completed units remaining.
[10:33:22] - Autosend completed
[10:33:22] + Working...
dschief
EVGA1060
Post by dschief »
Ok now I'm mad as hell! In checking out the rest of my farm, I found a second machine froze up with this Wu.
[05:05:28]
[05:05:28] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[05:05:28] Build host: amoeba
[05:05:28] Board Type: Nvidia
[05:05:28] Core      :
[05:05:28] Preparing to commence simulation
[05:05:28] - Looking at optimizations...
[05:05:28] - Created dyn
[05:05:28] - Files status OK
[05:05:29] - Expanded 45864 -> 246249 (decompressed 536.9 percent)
[05:05:29] Called DecompressByteArray: compressed_data_size=45864 data_size=246249, decompressed_data_size=246249 diff=0
[05:05:29] - Digital signature verified
[05:05:29]
[05:05:29] Project: 5506 (Run 8, Clone 200, Gen 192)
[05:05:29]
[05:05:29] Assembly optimizations on if available.
[05:05:29] Entering M.D.
[05:05:35] Working on p5506_supervillin_e1
[05:05:35] Client config found, loading data.
[05:05:35] mdrun_gpu returned
[05:05:35] NANs detected on GPU
[05:05:35]
[05:05:35] Folding@home Core Shutdown: UNSTABLE_MACHINE
[05:05:39] CoreStatus = 7A (122)
[05:05:39] Sending work to server
[05:05:39] Project: 5506 (Run 8, Clone 200, Gen 192)
[05:05:39] - Read packet limit of 540015616... Set to 524286976.
[05:05:39] - Error: Could not get length of results file work/wuresults_01.dat
[05:05:39] - Error: Could not read unit 01 file. Removing from queue.
[05:05:39] Trying to send all finished work units
[05:05:39] + No unsent completed units remaining.
[05:05:39] - Preparing to get new work unit...
[05:05:39] + Attempting to get work packet
[05:05:39] - Will indicate memory of 2044 MB
[05:05:39] - Connecting to assignment server
[05:05:39] Connecting to http://assign-GPU.stanford.edu:8080/
[05:05:39] Posted data.
[05:05:39] Initial: 40AB; - Successful: assigned to (171.64.65.106).
[05:05:39] + News From Folding@Home: GPU folding beta
[05:05:39] Loaded queue successfully.
[05:05:39] Connecting to http://171.64.65.106:8080/
[05:05:39] Initial: 0000; - Receiving payload (expected size: 46376)
[05:05:39] Conversation time very short, giving reduced weight in bandwidth avg
[05:05:39] - Downloaded at ~90 kB/s
[05:05:39] - Averaged speed for that direction ~90 kB/s
[05:05:39] + Received work.
[05:05:39] + Closed connections
[05:05:44]
[05:05:44] + Processing work unit
[05:05:44] Core required: FahCore_11.exe
[05:05:44] Core found.
[05:05:44] Working on queue slot 02 [November 20 05:05:44 UTC]
[05:05:44] + Working ...
[05:05:44] - Calling '.\FahCore_11.exe -dir work/ -suffix 02 -priority 96 -checkpoint 6 -verbose -lifeline 4208 -version 620'
[05:05:45]
[05:05:45] *------------------------------*
[05:05:45] Folding@Home GPU Core - Beta
[05:05:45] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[05:05:45]
[05:05:45] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[05:05:45] Build host: amoeba
[05:05:45] Board Type: Nvidia
[05:05:45] Core      :
[05:05:45] Preparing to commence simulation
[05:05:45] - Looking at optimizations...
[05:05:45] - Created dyn
[05:05:45] - Files status OK
[05:05:45] - Expanded 45864 -> 246249 (decompressed 536.9 percent)
[05:05:45] Called DecompressByteArray: compressed_data_size=45864 data_size=246249, decompressed_data_size=246249 diff=0
[05:05:45] - Digital signature verified
[05:05:45]
[05:05:45] Project: 5506 (Run 8, Clone 200, Gen 192)
[05:05:45]
[05:05:45] Assembly optimizations on if available.
[05:05:45] Entering M.D.
[05:05:51] Working on p5506_supervillin_e1
[05:05:52] Client config found, loading data.
[05:05:52] mdrun_gpu returned
[05:05:52] NANs detected on GPU
[05:05:52]
[05:05:52] Folding@home Core Shutdown: UNSTABLE_MACHINE
[05:05:55] CoreStatus = 7A (122)
[05:05:55] Sending work to server
[05:05:55] Project: 5506 (Run 8, Clone 200, Gen 192)
[05:05:55] - Read packet limit of 540015616... Set to 524286976.
[05:05:55] - Error: Could not get length of results file work/wuresults_02.dat
[05:05:55] - Error: Could not read unit 02 file. Removing from queue.
[05:05:55] Trying to send all finished work units
[05:05:55] + No unsent completed units remaining.
[05:05:55] - Preparing to get new work unit...
[05:05:55] + Attempting to get work packet
[05:05:55] - Will indicate memory of 2044 MB
[05:05:55] - Connecting to assignment server
[05:05:55] Connecting to http://assign-GPU.stanford.edu:8080/
[05:05:55] Posted data.
[05:05:55] Initial: 40AB; - Successful: assigned to (171.64.65.106).
[05:05:55] + News From Folding@Home: GPU folding beta
[05:05:55] Loaded queue successfully.
[05:05:55] Connecting to http://171.64.65.106:8080/
[05:05:55] Initial: 0000; - Receiving payload (expected size: 46376)
[05:05:56] - Downloaded at ~45 kB/s
[05:05:56] - Averaged speed for that direction ~75 kB/s
[05:05:56] + Received work.
[05:05:56] Trying to send all finished work units
[05:05:56] + No unsent completed units remaining.
[05:05:56] + Closed connections
[05:06:01]
[05:06:01] + Processing work unit
[05:06:01] Core required: FahCore_11.exe
[05:06:01] Core found.
[05:06:01] Working on queue slot 03 [November 20 05:06:01 UTC]
[05:06:01] + Working ...
[05:06:01] - Calling '.\FahCore_11.exe -dir work/ -suffix 03 -priority 96 -checkpoint 6 -verbose -lifeline 4208 -version 620'
[05:06:01]
[05:06:01] *------------------------------*
[05:06:01] Folding@Home GPU Core - Beta
[05:06:01] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[05:06:01]
[05:06:01] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[05:06:01] Build host: amoeba
[05:06:01] Board Type: Nvidia
[05:06:01] Core      :
[05:06:01] Preparing to commence simulation
[05:06:01] - Looking at optimizations...
[05:06:01] - Created dyn
[05:06:01] - Files status OK
[05:06:01] - Expanded 45864 -> 246249 (decompressed 536.9 percent)
[05:06:01] Called DecompressByteArray: compressed_data_size=45864 data_size=246249, decompressed_data_size=246249 diff=0
[05:06:01] - Digital signature verified
[05:06:01]
[05:06:01] Project: 5506 (Run 8, Clone 200, Gen 192)
[05:06:01]
[05:06:01] Assembly optimizations on if available.
[05:06:01] Entering M.D.
[05:06:07] Working on p5506_supervillin_e1
[05:06:08] Client config found, loading data.
[05:06:08] mdrun_gpu returned
[05:06:08] NANs detected on GPU
[05:06:08]
[05:06:08] Folding@home Core Shutdown: UNSTABLE_MACHINE
[05:06:11] CoreStatus = 7A (122)
[05:06:11] Sending work to server
[05:06:11] Project: 5506 (Run 8, Clone 200, Gen 192)
[05:06:11] - Read packet limit of 540015616... Set to 524286976.
[05:06:11] - Error: Could not get length of results file work/wuresults_03.dat
[05:06:11] - Error: Could not read unit 03 file. Removing from queue.
[05:06:11] Trying to send all finished work units
[05:06:11] + No unsent completed units remaining.
[05:06:11] - Preparing to get new work unit...
[05:06:11] + Attempting to get work packet
[05:06:11] - Will indicate memory of 2044 MB
[05:06:11] - Connecting to assignment server
[05:06:11] Connecting to http://assign-GPU.stanford.edu:8080/
[05:06:11] Posted data.
[05:06:11] Initial: 40AB; - Successful: assigned to (171.64.65.106).
[05:06:11] + News From Folding@Home: GPU folding beta
[05:06:11] Loaded queue successfully.
[05:06:11] Connecting to http://171.64.65.106:8080/
[05:06:11] Initial: 0000; - Receiving payload (expected size: 46376)
[05:06:12] - Downloaded at ~45 kB/s
[05:06:12] - Averaged speed for that direction ~67 kB/s
[05:06:12] + Received work.
[05:06:12] Trying to send all finished work units
[05:06:12] + No unsent completed units remaining.
[05:06:12] + Closed connections
[05:06:17]
[05:06:17] + Processing work unit
[05:06:17] Core required: FahCore_11.exe
[05:06:17] Core found.
[05:06:17] Working on queue slot 04 [November 20 05:06:17 UTC]
[05:06:17] + Working ...
[05:06:17] - Calling '.\FahCore_11.exe -dir work/ -suffix 04 -priority 96 -checkpoint 6 -verbose -lifeline 4208 -version 620'
[05:06:17]
[05:06:17] *------------------------------*
[05:06:17] Folding@Home GPU Core - Beta
[05:06:17] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[05:06:17]
[05:06:17] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[05:06:17] Build host: amoeba
[05:06:17] Board Type: Nvidia
[05:06:17] Core      :
[05:06:17] Preparing to commence simulation
[05:06:17] - Looking at optimizations...
[05:06:17] - Created dyn
[05:06:17] - Files status OK
[05:06:17] - Expanded 45864 -> 246249 (decompressed 536.9 percent)
[05:06:17] Called DecompressByteArray: compressed_data_size=45864 data_size=246249, decompressed_data_size=246249 diff=0
[05:06:17] - Digital signature verified
[05:06:17]
[05:06:17] Project: 5506 (Run 8, Clone 200, Gen 192)
[05:06:17]
[05:06:17] Assembly optimizations on if available.
[05:06:17] Entering M.D.
[05:06:23] Working on p5506_supervillin_e1
[05:06:24] Client config found, loading data.
[05:06:24] mdrun_gpu returned
[05:06:24] NANs detected on GPU
[05:06:24]
[05:06:24] Folding@home Core Shutdown: UNSTABLE_MACHINE
[05:06:27] CoreStatus = 7A (122)
[05:06:27] Sending work to server
[05:06:27] Project: 5506 (Run 8, Clone 200, Gen 192)
[05:06:27] - Read packet limit of 540015616... Set to 524286976.
[05:06:27] - Error: Could not get length of results file work/wuresults_04.dat
[05:06:27] - Error: Could not read unit 04 file. Removing from queue.
[05:06:27] Trying to send all finished work units
[05:06:27] + No unsent completed units remaining.
[05:06:27] - Preparing to get new work unit...
[05:06:27] + Attempting to get work packet
[05:06:27] - Will indicate memory of 2044 MB
[05:06:27] - Connecting to assignment server
[05:06:27] Connecting to http://assign-GPU.stanford.edu:8080/
[05:06:27] Posted data.
[05:06:27] Initial: 40AB; - Successful: assigned to (171.64.65.106).
[05:06:27] + News From Folding@Home: GPU folding beta
[05:06:27] Loaded queue successfully.
[05:06:27] Connecting to http://171.64.65.106:8080/
[05:06:27] Initial: 0000; - Receiving payload (expected size: 46376)
[05:06:28] - Downloaded at ~45 kB/s
[05:06:28] - Averaged speed for that direction ~63 kB/s
[05:06:28] + Received work.
[05:06:28] Trying to send all finished work units
[05:06:28] + No unsent completed units remaining.
[05:06:28] + Closed connections
[05:06:33]
[05:06:33] + Processing work unit
[05:06:33] Core required: FahCore_11.exe
[05:06:33] Core found.
[05:06:33] Working on queue slot 05 [November 20 05:06:33 UTC]
[05:06:33] + Working ...
[05:06:33] - Calling '.\FahCore_11.exe -dir work/ -suffix 05 -priority 96 -checkpoint 6 -verbose -lifeline 4208 -version 620'
[05:06:33]
[05:06:33] *------------------------------*
[05:06:33] Folding@Home GPU Core - Beta
[05:06:33] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[05:06:33]
[05:06:33] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[05:06:33] Build host: amoeba
[05:06:33] Board Type: Nvidia
[05:06:33] Core      :
[05:06:33] Preparing to commence simulation
[05:06:33] - Looking at optimizations...
[05:06:33] - Created dyn
[05:06:33] - Files status OK
[05:06:33] - Expanded 45864 -> 246249 (decompressed 536.9 percent)
[05:06:33] Called DecompressByteArray: compressed_data_size=45864 data_size=246249, decompressed_data_size=246249 diff=0
[05:06:33] - Digital signature verified
[05:06:33]
[05:06:33] Project: 5506 (Run 8, Clone 200, Gen 192)
[05:06:33]
[05:06:33] Assembly optimizations on if available.
[05:06:33] Entering M.D.
[05:06:39] Working on p5506_supervillin_e1
[05:06:40] Client config found, loading data.
[05:06:40] mdrun_gpu returned
[05:06:40] NANs detected on GPU
[05:06:40]
[05:06:40] Folding@home Core Shutdown: UNSTABLE_MACHINE
[05:06:43] CoreStatus = 7A (122)
[05:06:43] Sending work to server
[05:06:43] Project: 5506 (Run 8, Clone 200, Gen 192)
[05:06:43] - Read packet limit of 540015616... Set to 524286976.
[05:06:43] - Error: Could not get length of results file work/wuresults_05.dat
[05:06:43] - Error: Could not read unit 05 file. Removing from queue.
[05:06:43] EUE limit exceeded. Pausing 24 hours.
[11:05:27] - Autosending finished units... [November 20 11:05:27 UTC]
[11:05:27] Trying to send all finished work units
[11:05:27] + No unsent completed units remaining.
[11:05:27] - Autosend completed
[11:05:27] + Working...
Come on guy's enough already
dschief
EVGA1060
Post by dschief »
Ok , I'm done.Third freeze up on the same box in less than 12 hrs. on one Quad machine alone. Shutting down all Gpu clients until Monday, maybe
something will be resolved by then.
