I wasn't sure where to post so thought I would use here. If it is in the wrong place i apologise.
I have got a Dual Core laptop and currently using two versions of 5.02 to fold with. Someone in my team is using a GPU client utilising his NVidia card. My laptop has one of these which shoul dbe good enough. How dow I set this up and what version is the best to use?
Thanks in advance.
Mike
Which Client??
Re: Which Client??
The GPU Install Guide has everything you need. Click on the GUIDES link on the project homepage, and then follow the links to Windows GPU instructions. Be sure your system meets the minimum requirements listed there.
Re: Which Client??
I wrote an installer for windows, most people report it to work correctly though idk about laptops. The code should recognize which inf section your nvidia card is using though.
www.mtm78.nl/maxfah/publish.htm
