Capping Uploads
DreadedOne509
Capping Uploads
Post by DreadedOne509 »
Did a search, no joy.
Is it possible to cap the upload speeds when the folding client is returning
a finished work unit? Having several clients running (all SMP and GPU) can
really cripple the LAN/WAN when even one is uploading let alone 2 or 3
at the same time.
Would be very nice to have a cap range built into the options.
tear
Hardware configuration: None
Re: Capping Uploads
Post by tear »
With Unices you sure can go with trickle. Dunno about windows though.
HTH,
tear
One man's ceiling is another man's floor.
anandhanju
Re: Capping Uploads
Post by anandhanju »
Have heard of a program called NetLimiter (first search result in Google); never used it.
Re: Capping Uploads
anandhanju wrote:Have heard of a program called NetLimiter (first search result in Google); never used it.
I heard about this program too ;)
DreadedOne509
Re: Capping Uploads
NetLimiter looks like it would do what I was asking, but it would cost me several hundred dollars in licenses for the systems I have.
Perhaps I should be looking for a router that can do this or hope that Stanford can build into the clients a bandwidth cap option
for uploads.
