FAH as a service?
batman113
- Hardware configuration: WILKINS00:Intel Core2 Quad Q6600 2.4GHz 8GB PC6400/800MHz RAM Asus P5N32 Mobo Western Digital 160GB HD PNY GeForce 8800GT 256MB GDDR3
WILKINS02-Celeron D 2.8 GHz 2GB Corsair Value Select 80GB WD HD ATI RADEON HD 3450 Foxconn Mobo
WILKINS03(laptop)-Intel Core 2 Duo T7500 2.2GHz 2GB DDR2 RAM 160GB HD
RADIOSERVER-Pentium 4 3.2GHz 512mb DDR RAM 120GB HD - Contact:
Re: FAH as a service?
Yes, of course.
You need to use the console client, and answer yes when it asks in the configuration process if you want to run it in service mode.
jrweiss
CPU 6.20 client works in XP or Vista. GPU 6.20 client works in XP, may not work in Vista. SMP client not yet supported.
I run 1 GPU + 3 CPU clients on my Q9450, all as Services.
batman113
Mang0Ju1ce
Hijrweiss wrote:CPU 6.20 client works in XP or Vista. GPU 6.20 client works in XP, may not work in Vista. SMP client not yet supported.
If the GPU client is run as a service, do you know if the client will shut down automatically if a game is launched? Does the frame rate suffer at all?
jrweiss
I don't play games. You'll have to try it on your equipment.
codysluder
Running as a service should have nothing to do with either changes to the frame rate or shutting down automatically. Both the game and FAH are trying to share the resources of the GPU. Some games request exclusive use of the GPU; some do not. FAH should be responding appropriately, though I suspect that the optimization level of FahCore_11 and the driver version (both of which change from time to time) may also be factors.Mang0Ju1ce wrote:Hijrweiss wrote:CPU 6.20 client works in XP or Vista. GPU 6.20 client works in XP, may not work in Vista. SMP client not yet supported.
metal03326
- Hardware configuration: Mainboard: Asus M2R32-MVP (AMD 580X CrossFire Chipset)
CPU: AMD Athlon X2 3800+@2.4GHz
CPU cooler: Arctic Cooling Freezer 64 Pro PWM
RAM: 2x1 GB Team XTreme Dark 800MHz@5-5-5-16 in Dual Channel mode
Video Card: Sapphire HD 2600 XT@850MHz GDDR4@2200MHz
HDD: WESTERN DIGITAL 640GB Caviar® Black™ SATA2 7200rpm 32MB
OS: Microsoft Windows 7 Ultimate x64
Clients (always latest version): SMP2
Dell Inspiron 1000 (Celeron@2.2GHz) - Location: Vratsa, Bulgaria.
I play a lot of games. Some games like Need For Speed Most Wanted can't be played with F@H GPU2 running. The FPS is the same, but from time to time (around 10-20 seconds interval) there is a big drop in it (only for a moment). Because the game is very dynamic, one of those FPS drops makes it unplayable. Many people would say "It's from your video card". Yes my video is low end (2600 XT), but games like Assassins Creed, Crysis and other that are many times hard on the video than Most Wanted, do not have any issues while F@H is running. So it depends on the game and on your hardware.
