Project: 5506 (Run 0, Clone 207, Gen 204)
anko1
(3.2GHz) HT;Windows XP
Post by anko1 »
EUE
[21:01:55] + Closed connections
[21:01:55]
[21:01:55] + Processing work unit
[21:01:55] Core required: FahCore_11.exe
[21:01:55] Core found.
[21:01:55] Working on queue slot 02 [November 8 21:01:55 UTC]
[21:01:55] + Working ...
[21:01:55] - Calling '.\FahCore_11.exe -dir work/ -suffix 02 -priority 96 -checkpoint 15 -verbose -lifeline 2372 -version 620'
[21:01:55]
[21:01:55] *------------------------------*
[21:01:55] Folding@Home GPU Core - Beta
[21:01:55] Version 1.15 (Mon Oct 13 11:11:30 PDT 2008)
[21:01:55]
[21:01:55] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[21:01:55] Build host: amoeba
[21:01:55] Board Type: Nvidia
[21:01:55] Core      :
[21:01:55] Preparing to commence simulation
[21:01:55] - Looking at optimizations...
[21:01:55] - Created dyn
[21:01:55] - Files status OK
[21:01:55] - Expanded 45560 -> 246249 (decompressed 540.4 percent)
[21:01:55] Called DecompressByteArray: compressed_data_size=45560 data_size=246249, decompressed_data_size=246249 diff=0
[21:01:55] - Digital signature verified
[21:01:55]
[21:01:55] Project: 5506 (Run 0, Clone 207, Gen 204)
[21:01:55]
[21:01:55] Assembly optimizations on if available.
[21:01:55] Entering M.D.
[21:02:02] Working on p5506_supervillin_e1
[21:02:02] Client config found, loading data.
[21:02:02] Starting GUI Server
[21:03:23] Completed 1%
             {snip}
[21:51:57] Completed 37%
[21:52:57] Run: exception thrown during GuardedRun
[21:52:57] Run: exception thrown in GuardedRun -- Gromacs cannot continue further.
[21:52:57] Going to send back what have done -- stepsTotalG=25000000
[21:52:57] Work fraction=0.3773 steps=25000000.
[21:53:01] logfile size=53739 infoLength=53739 edr=0 trr=23
[21:53:01] - Writing 54275 bytes of core data to disk...
[21:53:01]   ... Done.
[21:53:01]
[21:53:01] Folding@home Core Shutdown: EARLY_UNIT_END
[21:53:03] CoreStatus = 72 (114)
[21:53:03] Sending work to server
[21:53:03] Project: 5506 (Run 0, Clone 207, Gen 204)
[21:53:03] - Read packet limit of 540015616... Set to 524286976.
[21:53:03] + Attempting to send results [November 8 21:53:03 UTC]
[21:53:03] - Reading file work/wuresults_02.dat from core
[21:53:03]   (Read 54275 bytes from disk)
[21:53:03] Connecting to http://171.64.65.106:8080/
[21:53:04] Posted data.
[21:53:05] Initial: 0000; - Uploaded at ~27 kB/s
[21:53:05] - Averaged speed for that direction ~44 kB/s
[21:53:05] + Results successfully sent
[21:53:05] Thank you for your contribution to Folding@Home.
Re: Project: 5506 (Run 0, Clone 207, Gen 204)
Someone completed this WU successfully.
anko1
Post by anko1 »
Thanks as always for checking my units.
