[18:28:42] + Closed connections
[18:28:42]
[18:28:42] + Processing work unit
[18:28:42] Core required: FahCore_11.exe
[18:28:42] Core found.
[18:28:42] Working on queue slot 01 [November 7 18:28:42 UTC]
[18:28:42] + Working ...
[18:28:42] - Calling '.\FahCore_11.exe -dir work/ -suffix 01 -priority 96 -checkpoint 15 -verbose -lifeline 2372 -version 620'
[18:28:42]
[18:28:42] *------------------------------*
[18:28:42] Folding@Home GPU Core - Beta
[18:28:42] Version 1.15 (Mon Oct 13 11:11:30 PDT 2008)
[18:28:42]
[18:28:42] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[18:28:42] Build host: amoeba
[18:28:42] Board Type: Nvidia
[18:28:42] Core :
[18:28:42] Preparing to commence simulation
[18:28:42] - Looking at optimizations...
[18:28:42] - Created dyn
[18:28:42] - Files status OK
[18:28:42] - Expanded 45578 -> 246249 (decompressed 540.2 percent)
[18:28:42] Called DecompressByteArray: compressed_data_size=45578 data_size=246249, decompressed_data_size=246249 diff=0
[18:28:42] - Digital signature verified
[18:28:42]
[18:28:42] Project: 5506 (Run 5, Clone 210, Gen 233)
[18:28:42]
[18:28:42] Assembly optimizations on if available.
[18:28:42] Entering M.D.
[18:28:49] Working on p5506_supervillin_e1
[18:28:49] Client config found, loading data.
[18:28:49] Starting GUI Server
[18:30:16] Completed 1%
{snip}
[20:17:06] Completed 75%
[20:17:38] Run: exception thrown during GuardedRun
[20:17:38] Run: exception thrown in GuardedRun -- Gromacs cannot continue further.
[20:17:38] Going to send back what have done -- stepsTotalG=25000000
[20:17:38] Work fraction=0.7538 steps=25000000.
[20:17:42] logfile size=97942 infoLength=97942 edr=0 trr=23
[20:17:42] - Writing 98478 bytes of core data to disk...
[20:17:42] ... Done.
[20:17:42]
[20:17:42] Folding@home Core Shutdown: UNSTABLE_MACHINE
[20:17:47] CoreStatus = 7A (122)
[20:17:47] Sending work to server
[20:17:47] Project: 5506 (Run 5, Clone 210, Gen 233)
[20:17:47] - Read packet limit of 540015616... Set to 524286976.
[20:17:47] + Attempting to send results [November 7 20:17:47 UTC]
[20:17:47] - Reading file work/wuresults_01.dat from core
[20:17:47] (Read 98478 bytes from disk)
[20:17:47] Connecting to http://171.64.65.106:8080/
[20:17:48] Posted data.
[20:17:49] Initial: 0000; - Uploaded at ~48 kB/s
[20:17:49] - Averaged speed for that direction ~49 kB/s
[20:17:49] + Results successfully sent
[20:17:49] Thank you for your contribution to Folding@Home.
