Project: 2621 (Run 95, Clone 91, Gen 16)
Birdman86
Post by Birdman86 »
My first problem with CPU client, most likely broken WU:
[12:18:09] + Processing work unit
[12:18:09] Core required: FahCore_78.exe
[12:18:09] Core found.
[12:18:09] Working on queue slot 07 [November 5 12:18:09 UTC]
[12:18:09] + Working ...
[12:18:09]
[12:18:09] *------------------------------*
[12:18:09] Folding@Home Gromacs Core
[12:18:09] Version 1.90 (March 8, 2006)
[12:18:09]
[12:18:09] Preparing to commence simulation
[12:18:09] - Looking at optimizations...
[12:18:09] - Created dyn
[12:18:09] - Files status OK
[12:18:11] - Expanded 415596 -> 10645865 (decompressed 2561.5 percent)
[12:18:11] - Starting from initial work packet
[12:18:11]
[12:18:11] Project: 2621 (Run 95, Clone 91, Gen 16)
[12:18:11]
[12:18:11] Assembly optimizations on if available.
[12:18:11] Entering M.D.
[12:18:18] Protein: p2621_p1475_tet1_03_1 t= 20000.00000
[12:18:18]
[12:18:18] Writing local files
[12:18:18] Gromacs error.
[12:18:18]
[12:18:18] Folding@home Core Shutdown: UNKNOWN_ERROR
[12:18:22] CoreStatus = 79 (121)
[12:18:22] Client-core communications error: ERROR 0x79
[12:18:22] This is a sign of more serious problems, shutting down.
[15:47:45] + Working...
--- Opening Log file [November 5 20:56:35 UTC]
# Windows CPU Systray Edition #################################################
                       Folding@Home Client Version 6.20
                          http://folding.stanford.edu
Launch directory: C:\Users\admin\AppData\Roaming\Folding@home-x86
[20:56:35] - Ask before connecting: No
[20:56:35] - User name: Birdman86 (Team 50711)
[20:56:35] - User ID: 5246E567044FC6C7
[20:56:35] - Machine ID: 1
[20:56:35]
[20:56:35] Loaded queue successfully.
[20:56:35] Initialization complete
[20:56:35]
[20:56:35] + Processing work unit
[20:56:35] Core required: FahCore_78.exe
[20:56:35] Core found.
[20:56:35] Working on queue slot 07 [November 5 20:56:35 UTC]
[20:56:35] + Working ...
[20:56:35]
[20:56:35] *------------------------------*
[20:56:35] Folding@Home Gromacs Core
[20:56:35] Version 1.90 (March 8, 2006)
[20:56:35]
[20:56:35] Preparing to commence simulation
[20:56:35] - Ensuring status. Please wait.
[20:56:52] - Looking at optimizations...
[20:56:52] - Working with standard loops on this execution.
[20:56:52] - Created dyn
[20:56:52] - Files status OK
[20:56:54] - Expanded 415596 -> 10645865 (decompressed 2561.5 percent)
[20:56:54] - Starting from initial work packet
[20:56:54]
[20:56:54] Project: 2621 (Run 95, Clone 91, Gen 16)
[20:56:54]
[20:56:54] Entering M.D.
[20:57:01] Protein: p2621_p1475_tet1_03_1 t= 20000.00000
[20:57:01]
[20:57:01] Writing local files
[20:57:01] Gromacs error.
[20:57:01]
[20:57:01] Folding@home Core Shutdown: UNKNOWN_ERROR
[20:57:03] CoreStatus = 79 (121)
[20:57:03] Client-core communications error: ERROR 0x79
[20:57:03] This is a sign of more serious problems, shutting down.
Birdman86
Re: Project: 2621 (Run 95, Clone 91, Gen 16)
Post by Birdman86 »
I removed queue.dat and the contents of work folder twice and got another WU.
So problem solved here, but someone may get that problem next time.
sortofageek
Post by sortofageek »
Project: 2621 (Run 95, Clone 91, Gen 16) isn't a bad WU. Another donor completed it successfully for full credit.
Birdman86
Post by Birdman86 »
I'm still getting the same WU and it always stops my client. I delete work folder and queue.dat, get other WU, leave my PC folding alone and it folds some WU's, gets that bad WU and stops. Actually I have 3 CPU clients and 2 nVidia GPU clients running, and the others fold flawlessly. This first CPU client (Machine ID 1) also folds all other WU's flawlessly, but this one always gets the same UNKNOWN_ERROR in a few seconds.
sortofageek wrote:Project: 2621 (Run 95, Clone 91, Gen 16) isn't a bad WU. Another donor completed it successfully for full credit.
Where did you see that ?
When I look in the DB, I only have one report for 0 credit.
Birdman86
Post by Birdman86 »
I have got that WU at least 6 times between my posts, but I can't send results since my client quits every time that WU is in queue.
Is there any way to avoid that WU?
It will be assigned 5 or 6 times when you delete it, then the server will give up, and send you another WU.
