I've been folding for the DD Squad for a few months and am running both the GPU2 and the x86 CPU clients on the same system. Now I've just discovered that the CPU client can't upload the results...here's from the log file:
[23:10:41] + Attempting to send results [November 4 23:10:41 UTC]
[23:10:41] - Connecting to assignment server
[23:10:41] - Couldn't send HTTP request to server
[23:10:41] (Got status 503)
[23:10:41] + Could not connect to Work Server (results)
[23:10:41] (171.64.65.65:8080)
[23:10:41] + Retrying using alternative port
[23:10:42] - Couldn't send HTTP request to server
[23:10:42] (Got status 503)
[23:10:42] + Could not connect to Work Server (results)
[23:10:42] (171.64.65.65:80)
[23:10:42] - Error: Could not transmit unit 00 (completed November 4) to work server.
[23:10:42] - Read packet limit of 540015616... Set to 524286976.
[23:10:42] + Attempting to send results [November 4 23:10:42 UTC]
[23:10:42] - Successful: assigned to (171.64.65.65).
[23:10:42] + News From Folding@Home: Welcome to Folding@Home
[23:10:42] Loaded queue successfully.
[23:10:42] (171.67.108.25:8080)
[23:10:42] + Retrying using alternative port
[23:10:43] - Couldn't send HTTP request to server
[23:10:43] (Got status 503)
[23:10:43] + Could not connect to Work Server
[23:10:43] - Attempt #1 to get work failed, and no other work to do.
Waiting before retry.
[23:10:43] + Could not connect to Work Server (results)
[23:10:43] (171.67.108.25:80)
[23:10:43] Could not transmit unit 00 to Collection server; keeping in queue.
[23:10:43] Project: 2611 (Run 0, Clone 265, Gen 105)
[23:10:43] - Read packet limit of 540015616... Set to 524286976.
[23:10:43] + Attempting to send results [November 4 23:10:43 UTC]
[23:10:43] (171.64.65.65:8080)
[23:10:43] + Retrying using alternative port
[23:10:43] (171.64.65.65:80)
[23:10:43] - Error: Could not transmit unit 00 (completed November 4) to work server.
[23:10:43] - Read packet limit of 540015616... Set to 524286976.I've just noticed whenever I (re-)start the CPU client it displays a message about trying to send result until I pause the client after which it then displays working progress (like 10/125), <--- all when holding the cursor over the client.
System specs:
CPU: AMD Athlon X2 5000+ Black Edition @ 3.1 GHz (230 MHz FSB)
RAM: 4x1 GB PC2-8500 Kingston HyperX @ 960 MHz
Video cards: 2 x Sapphire Radeon HD 3870 512MB GDDR4 @ standard clocks
Mobo: MSI K9A2 Platinum V2
OS: Win XP SP3 and fully updated
Video card driver: ATI Catalyst "HotFix" driver optimized for "Far Cry 2", (hotfix_xp32-64_dd_ccc_70516), installed.
DirectX Latest, August 2008 version.
Chipset drivers: CCC 2008.0722.2134.36815, SBDrv: 2.7
Firewall: ZoneAlarm version 7.0.483.000
Any help would be greatly appreciated.
