Special exit:
[04:22:17] + Closed connections
[04:22:17]
[04:22:17] + Processing work unit
[04:22:17] Core required: FahCore_82.exe
[04:22:17] Core found.
[04:22:17] Working on Unit 04 [November 3 04:22:17]
[04:22:17] + Working ...
[04:22:17] - Calling 'FahCore_82.exe -dir work/ -suffix 04 -checkpoint 15 -verbose -lifeline 876 -version 503'
[04:22:17]
[04:22:17] *------------------------------*
[04:22:17] Folding@Home PMD Core
[04:22:17] Version 1.03 (September 7, 2005)
[04:22:17]
[04:22:17] Preparing to commence simulation
[04:22:17] - Looking at optimizations...
[04:22:17] - Created dyn
[04:22:17] - Files status OK
[04:22:17] - Expanded 22713 -> 143196 (decompressed 630.4 percent)
[04:22:17]
[04:22:17] Project: 4617 (Run 14, Clone 7, Gen 54)
[04:22:17]
[04:22:17] Assembly optimizations on if available.
[04:22:17] Entering M.D.
[04:22:22] + New frame time estimate; Working...
[04:22:24] Protein: p4617_T0_villin-16_minout
[04:22:24]
[04:22:24] Completed 0 out of 2500000 steps  (0)
[04:22:27] + New frame time estimate; Working...
[04:32:13] Writing local files
[04:32:13] Completed 25000 out of 2500000 steps  (1)
                                 {snip}
[05:01:45] + Working ...Printing Queue Information
CURRENT QUEUE:
00  EMPTY
01  DONE      "Folding@Home" (81) 171.64.122.72:8080  October 27 16:44->October 27 19:43:18
02  EMPTY
03  DONE      "Folding@Home" (81) 171.64.122.72:8080  October 24 12:25->October 24 15:27:29
04 *ACTIVE    "Folding@Home" (82) 169.230.26.30:8080  November 3 04:17 | December 5 16:17
05  EMPTY
06  EMPTY
07  EMPTY
08  EMPTY
09  EMPTY
[05:11:42] Writing local files
[05:11:42] Completed 125000 out of 2500000 steps  (5)
                                    {snip}
[06:35:54] Trying to send all finished work units
[06:35:54] + Attempting to send results
[06:35:54] - Reading file work/wuresults_01.dat from core
[06:35:54]   (Read 589022 bytes from disk)
[06:35:54] Connecting to http://171.64.122.72:8080/
[06:36:15] - Couldn't send HTTP request to server
[06:36:15] + Could not connect to Work Server (results)
[06:36:15]     (171.64.122.72:8080)
[06:36:15] - Error: Could not transmit unit 01 (completed October 27) to work server.
[06:36:15] - 45 failed uploads of this unit.
                            {snip}
[06:36:15] + Attempting to send results
[06:36:15] - Reading file work/wuresults_03.dat from core
[06:36:15]   (Read 593698 bytes from disk)
[06:36:15] Connecting to http://171.64.122.72:8080/
[06:38:25] - Couldn't send HTTP request to server
[06:38:25] + Could not connect to Work Server (results)
[06:38:25]     (171.64.122.72:8080)
[06:38:25] - Error: Could not transmit unit 03 (completed October 24) to work server.
[06:38:25] - 73 failed uploads of this unit.
                            {snip}
[06:38:26] + Sent 0 of 2 completed units to the server
[06:38:26] - Autosend completed
[06:38:26] + Working...
[06:38:44] Writing checkpoint files
[06:45:12] Writing local files
[06:45:12] Completed 350000 out of 2500000 steps  (14)
                           {snip}
[12:21:44] Completed 1125000 out of 2500000 steps  (45)
[12:25:58] Writing checkpoint files
[12:32:36] Writing local files
[12:32:36] Completed 1150000 out of 2500000 steps  (46)
[12:32:36] Writing checkpoint files
[12:32:39] + Writing 'sec_per_frame = 26.000000' to config
[12:32:39] + Working ...Unit 3's deadline (November 3 12:25) has passed.
[12:38:30] CoreStatus = 65 (101)
[12:38:30] Core internal error: SPECIAL_EXIT
[12:38:31] - Autosending finished units...
[12:38:31] Trying to send all finished work unitsCode: Select all
[12:38:31] + Attempting to send results
[12:38:31] - Reading file work/wuresults_01.dat from core
[12:38:31]   (Read 589022 bytes from disk)
[12:38:31] Connecting to http://171.64.122.72:8080/
[12:38:35]
[12:38:35] + Processing work unit
[12:38:35] Core required: FahCore_82.exe
[12:38:35] Core found.
[12:38:35] Working on Unit 04 [November 3 12:38:35]
[12:38:35] + Working ...
[12:38:35] - Calling 'FahCore_82.exe -dir work/ -suffix 04 -checkpoint 15 -verbose -lifeline 876 -version 503'
[12:38:35]
[12:38:35] *------------------------------*
[12:38:35] Folding@Home PMD Core
[12:38:35] Version 1.03 (September 7, 2005)
[12:38:35]
[12:38:35] Preparing to commence simulation
[12:38:35] - Ensuring status. Please wait.
[12:38:52] - Looking at optimizations...
[12:38:52] - Working with standard loops on this execution.
[12:38:52] - Previous termination of core was improper.
[12:38:52] - Files status OK
[12:38:52] - Expanded 22713 -> 143196 (decompressed 630.4 percent)
[12:38:52]
[12:38:52] Project: 4617 (Run 14, Clone 7, Gen 54)
[12:38:52]
[12:38:52] Error: Could not write local file.  Exiting.
[12:38:57] - Shutting down core
[12:38:57]
[12:38:57] Folding@home Core Shutdown: FILE_IO_ERROR
[12:39:01] CoreStatus = 75 (117)
[12:39:01] Error opening or reading from a file.
[12:39:01] Deleting current work unit & continuing...
[12:39:05] Trying to send all finished work units
[12:39:05] - Already sending work
[12:39:05] + Sent 0 of 1 completed units to the server
