Project: 4743 (Run 1, Clone 264, Gen 53)
hawkchalk
Post by hawkchalk »
Hello!
I seem to be having an issue with WU 4743 which is P4743_lam5w_30. Up until no I have had no issues with the GPU client but it is hanging everytime on this WU. The log files says the following:
Folding@Home GPU Core - Beta
[14:06:43] Version 1.18 (Mon Oct 13 11:11:30 PDT 2008)
[14:06:43]
[14:06:43] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[14:06:43] Build host: amoeba
[14:06:43] Board Type: AMD
[14:06:43] Core :
[14:06:43] Preparing to commence simulation
[14:06:43] - Looking at optimizations...
[14:06:43] - Created dyn
[14:06:43] - Files status OK
[14:06:43] - Expanded 88319 -> 447304 (decompressed 506.4 percent)
[14:06:43] Called DecompressByteArray: compressed_data_size=88319 data_size=447304, decompressed_data_size=447304 diff=0
[14:06:43] - Digital signature verified
[14:06:43]
[14:06:43] Project: 4743 (Run 1, Clone 264, Gen 53)
[14:06:43]
[14:06:43] Assembly optimizations on if available.
[14:06:43] Entering M.D.
[14:06:49] Working on p4743_lam5w_300K
[14:06:49] Client config found, loading data.
[14:06:50] Starting GUI Server
[14:06:55] mdrun_gpu returned
[14:06:55] NANs detected on GPU
[14:06:55]
[14:06:55] Folding@home Core Shutdown: UNSTABLE_MACHINE
[14:06:59] CoreStatus = 7A (122)
[14:06:59] Sending work to server
[14:06:59] Project: 4743 (Run 1, Clone 264, Gen 53)
[14:06:59] - Read packet limit of 540015616... Set to 524286976.
[14:06:59] - Error: Could not get length of results file work/wuresults_00.dat
[14:06:59] - Error: Could not read unit 00 file. Removing from queue.
[14:06:59] EUE limit exceeded. Pausing 24 hours.
[14:07:37] Opening ...
The display shows a large grey sphere with multicolor rings that appear to form the surface. Any help in fixing this would be appreciated..I'd like to get back to folding on the Visiontek HD 3870 oc edition.
v/r
Hawkchalk
CoMePrAdZ
Hardware configuration: Pentium 4 524
Celeron @2.2ghz w/ 512 MB, folding for team 130783
Distributed Clusters over My School :D
Re: WU 4743
Post by CoMePrAdZ »
Did You overclocked Your GPU?
"... Folding for everything ..."
Team 130783
hawkchalk
Re: WU 4743
Post by hawkchalk »
Specifically I have not overclocked the GPU but the board is an "overclock edition". Without a core running it is currently 36C and when it runs a core it is about 56C. As I said earlier I've not had a problem until this particular project. Is there some way to "dump" this project and get another to test?
Re: WU 4743
Do you use Vista ?
If yes, try to run the client in "XP compatibility" mode.
hawkchalk
Re: WU 4743
Post by hawkchalk »
Yes, I'm running Vista Ultimate. Can you elaborate some on the XP compatibility mode? I have not run across that in any of the documentation but I will do a search shortly but knowing me help would be good!! :ewink:
hawkchalk
Re: WU 4743
Post by hawkchalk »
Well, I found a reference for running "XP compatibility mode" on the web, made the change to the application and WHAMO!! P4743_lam5w_300k is now running! Thanks for the help!
v/r
Mike B.
