Project: 4611 (Run 24, Clone 22, Gen 54)
anko1
(3.2GHz) HT;Windows XP
Post by anko1 »
EUE
[18:53:11] + Closed connections
[18:53:11]
[18:53:11] + Processing work unit
[18:53:11] Core required: FahCore_82.exe
[18:53:11] Core found.
[18:53:11] Working on Unit 07 [October 31 18:53:11]
[18:53:11] + Working ...
[18:53:11] - Calling 'FahCore_82.exe -dir work/ -suffix 07 -checkpoint 15 -verbose -lifeline 964 -version 503'
[18:53:11]
[18:53:11] *------------------------------*
[18:53:11] Folding@Home PMD Core
[18:53:11] Version 1.03 (September 7, 2005)
[18:53:11]
[18:53:11] Preparing to commence simulation
[18:53:11] - Looking at optimizations...
[18:53:11] - Created dyn
[18:53:11] - Files status OK
[18:53:11] - Expanded 12399 -> 81071 (decompressed 653.8 percent)
[18:53:11]
[18:53:11] Project: 4611 (Run 24, Clone 22, Gen 54)
[18:53:11]
[18:53:11] Assembly optimizations on if available.
[18:53:11] Entering M.D.
[18:53:17] Going to send back what have done.
[18:53:17] logfile size: 5649
[18:53:17] - Writing 6169 bytes of core data to disk...
[18:53:17]   ... Done.
[18:53:18]
[18:53:18] Folding@home Core Shutdown: EARLY_UNIT_END
[18:53:21] CoreStatus = 72 (114)
[18:53:21] Sending work to server
[18:53:21] - Already sending work
[18:53:21] Trying to send all finished work units
[18:53:21] + Sent 0 of 3 completed units to the server
ppetrone
Pande Group Member
Re: Project: 4611 (Run 24, Clone 22, Gen 54)
Post by ppetrone »
Thank you for the report!.
paula
anko1
Post by anko1 »
You're welcome, Paula.
Angela
This one is a bad WU, there are many reports for 0 points ... someone will have to remove this WU manually from the server ;)
