Project: 3065 (Run 2, Clone 117, Gen 24)
Phantom
Post by Phantom »
Running this WU on a Mac Mini (1.83 GHz Core Duo w/ 512MB RAM)... Similar problem as reported on these other series 30xx WUs:
Project: 3062 (Run 2, Clone 179, Gen 18)
Project: 3064 (Run 2, Clone 118, Gen 16)
Unfortunately, can't seem to successfully download the latest beta 6.23 client for Mac OS X from the supplied link (new 6.23 public beta client)-- so, this problem repeats and repeats on at least one of my Mac Minis in my folding farm at any given time -- causing continued significant loss of scientific results. :e(
anandhanju
Re: Project: 3065 (Run 2, Clone 117, Gen 24)
Post by anandhanju »
Here's the link to download the new 6.23 public beta client: viewtopic.php?f=24&t=6142
Report troubles with the client at viewtopic.php?f=13&t=6145
sortofageek
Post by sortofageek »
This one was completed successfully for full credit by another donor.
Hopefully, you are having a better success rate now.
Phantom
Post by Phantom »
@sortofageek --
I'm still having mixed success... I've been using the 6.23 public beta client, but it does not solve everything. Just had another similar failure today @ 92+% complete -- Project 3043 (Run 2, Clone 52, Gen 80)... Same failure symptoms so I didn't post and flood the boards. Alas, we persist. Note that the problems seem most prevalent on Core Duo processors -- as opposed to the more common Core 2 Duo processors... Might want/need to consider not assigning those types of WUs to Core Duos...
Oh, I long for the Project 26xx series which seems to run without a hitch on Mac OS X w/ Intel processors...
Fold on!
