Project: 5015 (Run 5, Clone 553, Gen 107)
anko1
(3.2GHz) HT;Windows XP
Post by anko1 »
Gromacs cannot continue.
Btw, should we keep posting these? I know some are core failures rather than bad WUs, but since I do complete some of all the types that do fail, I can't tell if it's a bad WU or a core failure. I have a VGA BFG 9800GTX R card.
[21:11:07] + Closed connections
[21:11:07]
[21:11:07] + Processing work unit
[21:11:07] Core required: FahCore_11.exe
[21:11:07] Core found.
[21:11:07] Working on queue slot 09 [October 30 21:11:07 UTC]
[21:11:07] + Working ...
[21:11:07] - Calling '.\FahCore_11.exe -dir work/ -suffix 09 -priority 96 -checkpoint 15 -verbose -lifeline 2388 -version 620'
[21:11:07]
[21:11:07] *------------------------------*
[21:11:07] Folding@Home GPU Core - Beta
[21:11:07] Version 1.15 (Mon Oct 13 11:11:30 PDT 2008)
[21:11:07]
[21:11:07] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[21:11:07] Build host: amoeba
[21:11:07] Board Type: Nvidia
[21:11:07] Core      :
[21:11:07] Preparing to commence simulation
[21:11:07] - Looking at optimizations...
[21:11:07] - Created dyn
[21:11:07] - Files status OK
[21:11:07] - Expanded 44018 -> 244433 (decompressed 555.3 percent)
[21:11:07] Called DecompressByteArray: compressed_data_size=44018 data_size=244433, decompressed_data_size=244433 diff=0
[21:11:07] - Digital signature verified
[21:11:07]
[21:11:07] Project: 5015 (Run 5, Clone 553, Gen 107)
[21:11:07]
[21:11:07] Assembly optimizations on if available.
[21:11:07] Entering M.D.
[21:11:13] Working on 576 p5005_supervillin_e1
[21:11:14] Client config found, loading data.
[21:11:14] Starting GUI Server
[21:12:48] Completed 1%
    {snip}
[21:56:25] Completed 29%
[21:57:55] Completed 30%
[21:58:50] Run: exception thrown during GuardedRun
[21:58:50] Run: exception thrown in GuardedRun -- Gromacs cannot continue further.
[21:58:50] Going to send back what have done -- stepsTotalG=25000000
[21:58:50] Work fraction=0.3060 steps=25000000.
[21:58:54] logfile size=45498 infoLength=45498 edr=0 trr=23
[21:58:54] - Writing 46034 bytes of core data to disk...
[21:58:54] Done: 45522 -> 6753 (compressed to 14.8 percent)
[21:58:54]   ... Done.
[21:58:54]
[21:58:54] Folding@home Core Shutdown: UNSTABLE_MACHINE
[21:58:58] CoreStatus = 7A (122)
[21:58:58] Sending work to server
[21:58:58] Project: 5015 (Run 5, Clone 553, Gen 107)
[21:58:58] - Read packet limit of 540015616... Set to 524286976.
[21:58:58] + Attempting to send results [October 30 21:58:58 UTC]
[21:58:58] - Reading file work/wuresults_09.dat from core
[21:58:58]   (Read 7265 bytes from disk)
[21:58:58] Connecting to http://171.64.65.20:8080/
[21:58:58] Posted data.
[21:58:58] Initial: 0000; Conversation time very short, giving reduced weight in bandwidth avg
[21:58:58] - Uploaded at ~16 kB/s
[21:58:58] - Averaged speed for that direction ~46 kB/s
[21:58:58] + Results successfully sent
[21:58:58] Thank you for your contribution to Folding@Home.
Re: Project: 5015 (Run 5, Clone 553, Gen 107)
Someone else completed this WU.
anko1
Post by anko1 »
Thanks for checking, toTOW.
