Project: 5651 (Run 0, Clone 32, Gen 3)
EvilAlchemist
Hardware configuration: 2 x X5550 Xeons - SuperMicro MBD-X8DAi-O
Server 2008 R2 x64 - 12GB Crucial DDR3 ECC Ram
PCP&C 910 Silencer - 1 x HIS 4850 ICEQ Turbo Edition
6 x E5530 Xeons (3 Systems) - SUPERMICRO MBD-X8DTL-i-O
Server 2008 RS x64 - 8GB DDR3 GSkill Non-ECC Ram
Seasonic 80+ Bronze 380w PSU
2 x E5504 - SUPERMICRO MBD-X8DTL-i-O
Server 2008 R2 x64 - 6GB DDR3 GSkill Non-ECC Ram
2.3 TB Raid 5 Array - Corsair 520 Power Supply
E5504 - EVGA X58 ATX Motherboard
Windows 7 x64 - 6GB DDR3 GSkill Non-ECC Ram
Seasonic 300 Power Supply
Intel X5550 CPU - EVGA X58 Micro ATX Motherboard
Windows 7 x64 - 3GB Corsair DDR3-1600
Corsair 550 Power Supply - ATI 4350
Dell Vostro 1500 Laptop - Intel T9300 C2D CPU
Windows 7 x64 - 4 GB DDR2-6400 - nVidia 8400m GS
Xeon 3075 C2D - Intel P35 Motherboard - 4GB DDR2 Non-ECC Ram
Server 2008 R2 x64- Seasonic 300 Power Supply
Post by EvilAlchemist »
Project: 5651 (Run 0, Clone 32, Gen 3) - Core_11 - Version 1.18
[02:15:29]
[02:15:29] *------------------------------*
[02:15:29] Folding@Home GPU Core - Beta
[02:15:29] Version 1.18 (Mon Oct 13 11:11:30 PDT 2008)
[02:15:29]
[02:15:29] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[02:15:29] Build host: amoeba
[02:15:29] Board Type: AMD
[02:15:29] Core      :
[02:15:29] Preparing to commence simulation
[02:15:29] - Looking at optimizations...
[02:15:29] - Created dyn
[02:15:29] - Files status OK
[02:15:29] - Expanded 80946 -> 408077 (decompressed 504.1 percent)
[02:15:29] Called DecompressByteArray: compressed_data_size=80946 data_size=408077, decompressed_data_size=408077 diff=0
[02:15:29] - Digital signature verified
[02:15:29]
[02:15:29] Project: 5651 (Run 0, Clone 32, Gen 3)
[02:15:29]
[02:15:29] Assembly optimizations on if available.
[02:15:29] Entering M.D.
[02:15:35] Working on CMF
[02:15:35] Client config found, loading data.
[02:15:35] Starting GUI Server
[02:15:41] mdrun_gpu returned
[02:15:41] NANs detected on GPU
[02:15:41]
[02:15:41] Folding@home Core Shutdown: UNSTABLE_MACHINE
[02:15:45] CoreStatus = 7A (122)
[02:15:45] Sending work to server
[02:15:45] Project: 5651 (Run 0, Clone 32, Gen 3)
[02:15:45] - Error: Could not get length of results file work/wuresults_02.dat
[02:15:45] - Error: Could not read unit 02 file. Removing from queue.
• E2140 @ 2.1Ghz
• Abit IB9 P965 Motherboard
• 4GB PC2-6400
• Vista x64 SP1 - UAC Enabled
• Catalyst 8.10 Driver
• HIS 4850 ICEQ (PCI-E x16)
• GPU2 Systray Client Version 6.20r1 --> Running in "XP Compatibility Mode"
Could this caused by the change from Core_12 1.16 --> Core_11 1.18 on these projects. They were stable on Core_12 1.16
There was also another report filed here --> viewtopic.php?f=51&t=6575 on Project: 5651 (Run 0, Clone 282, Gen 7).
Then again, it might just be a few bad Work units and the rest are fine.
Re: Project: 5651 (Run 0, Clone 32, Gen 3)
Someone else completed Project: 5651 (Run 0, Clone 32, Gen 3) successfully.
kasson
Pande Group Member
Post by kasson »
It could be a core version issue or random bad luck. There are definitely issues with the core that we (and especially Mark) are still trying to pin down.
