Where and who do you report a bad wu to?
wickedwahine
Post by wickedwahine »
What is the correct way to report a bad wu to Stanford? So it will stop showing up... :evil: I have been told from prior post 2665 (Run 2 clone 715 gen 52) is bad. I have upgraded and updated and deleted everything, got 2669 (run 17 clone 113 gen 9) which ran just fine, and soon thereafter, here comes the repeat offender 2665 (Run 2 clone 715 gen 52) and again, hanging between 3 and 8%.
Re: Where and who do you report a bad wu to?
You're in the right place ;)
wickedwahine
Folding for OCN, Vmware/ubuntu distro (hence not being able to upgrade to 6.23beta client), quad/Vista ultimate. Never had a problem for months until this wu. I have tried uninstalling, deleting work and queue folders, In 4 days, I have been able to fold 1 project 2668 (Run 1, Clone 452, Gen 10) by doing manual restarts and it finally deleted the wu, and assigned me 2668, but now 2665 (Run 2, Clone 715, Gen 52) is returning and it just stops the client, not even error message, just nothing, halted at 2%, trying to restart just prolongs the agony to up to 10% or so and then the same thing. Can't monitor the puter all day, as it is home and not at work.... Do you need anything from me to look into this? I can send log later if you need it. I have looked for this wu in the forums, although you told me it is a bad wu, don't see anyone reporting it unless run clone gen don't matter, is there elsewhere to look? What should I do. Help will be appreciated, and I apologize if I am not going the proper way to ask for it, or double posting, I truly don't know what to do and I want to keep on folding :(
Thx
