Project: 5506 (Run 2, Clone 943, Gen 68)
ei57
Post by ei57 »
Multiple EUE's on this WU at the same point - SHAKE violations on GPU.
[06:55:30] Folding@Home GPU Core - Beta
[06:55:30] Version 1.15 (Mon Oct 13 11:11:30 PDT 2008)
[06:55:30]
[06:55:30] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[06:55:30] Build host: amoeba
[06:55:30] Board Type: Nvidia
[06:55:30] Core      :
[06:55:30] Preparing to commence simulation
[06:55:30] - Looking at optimizations...
[06:55:30] - Created dyn
[06:55:30] - Files status OK
[06:55:30] - Expanded 42227 -> 246249 (decompressed 583.1 percent)
[06:55:30] Called DecompressByteArray: compressed_data_size=42227 data_size=246249, decompressed_data_size=246249 diff=0
[06:55:30] - Digital signature verified
[06:55:30]
[06:55:30] Project: 5506 (Run 2, Clone 943, Gen 68)
[06:55:30]
[06:55:30] Assembly optimizations on if available.
[06:55:30] Entering M.D.
[06:55:37] Working on p5506_supervillin_e1
[06:55:37] Client config found, loading data.
[06:55:37] mdrun_gpu returned
[06:55:37] SHAKE violations on GPU
[06:55:37]
[06:55:37] Folding@home Core Shutdown: UNSTABLE_MACHINE
[06:55:40] CoreStatus = 7A (122)
[06:55:40] Sending work to server
[06:55:40] Project: 5506 (Run 2, Clone 943, Gen 68)
[06:55:40] - Read packet limit of 540015616... Set to 524286976.
[06:55:40] - Error: Could not get length of results file work/wuresults_00.dat
[06:55:40] - Error: Could not read unit 00 file. Removing from queue.
[06:55:40] Trying to send all finished work units
Re: Project: 5506 (Run 2, Clone 943, Gen 68)
This is a bad WU ... I see many reports for 0 points in the DB :(
