Project: 3064 (Run 2, Clone 118, Gen 16)
Phantom
Post by Phantom »
Running this WU on a Mac Mini (T7600 w/ 1GB RAM)... Was able to manually restart the WU the third time; however, thought I'd report the fact that there was something questionable @ 23% that caused a halt.
First run:
[21:13:39] Warning: long 1-4 interactions
Second run:
[07:00:57] Warning: long 1-4 interactions
Third run:
[16:45:23] Warning: long 1-4 interactions
Edit: Note that during the first and second runs, the WU deleted itself (CoreStatus = 0 (0)) and was subsequently reassigned to this processor with an intervening project 2668 or 2669. The third time this WU was assigned, the WU halted without continuing (CoreStatus = 66 (102)). Manually restarted from checkpoint and has continued to run. (Still running at this moment.)
[13:33:35] - Preparing to get new work unit...
[13:33:35] + Attempting to get work packet
[13:33:35] - Will indicate memory of 1024 MB
[13:33:35] - Connecting to assignment server
[13:33:35] Connecting to http://assign.stanford.edu:8080/
[13:33:35] Posted data.
[13:33:35] Initial: 40AB; - Successful: assigned to (171.64.65.63).
[13:33:35] + News From Folding@Home: Welcome to Folding@Home
[13:33:35] Loaded queue successfully.
[13:33:35] Connecting to http://171.64.65.63:8080/
[13:33:36] Posted data.
[13:33:36] Initial: 0000; - Receiving payload (expected size: 610538)
[13:33:37] - Downloaded at ~596 kB/s
[13:33:37] - Averaged speed for that direction ~577 kB/s
[13:33:37] + Received work.
[13:33:37] Trying to send all finished work units
[13:33:37] + No unsent completed units remaining.
[13:33:37] + Closed connections
[13:33:37]
[13:33:37] + Processing work unit
[13:33:37] Core required: FahCore_a1.exe
[13:33:37] Core found.
[13:33:37] Working on Unit 01 [October 26 13:33:37]
[13:33:37] + Working ...
[13:33:37] - Calling './mpiexec -np 4 -host 127.0.0.1 ./FahCore_a1.exe -dir work/ -suffix 01 -checkpoint 30 -forceasm -verbose -lifeline 241 -version 602'
[13:33:37]
[13:33:37] *------------------------------*
[13:33:37] Folding@Home Gromacs SMP Core
[13:33:37] Version 1.73 (November 27, 2006)
[13:33:37]
[13:33:37] Preparing to commence simulation
[13:33:37] - Ensuring status. Please wait.
[13:33:54] - Assembly optimizations manually forced on.
[13:33:54] - Not checking prior termination.
[13:33:55] - Expanded 610026 -> 3263429 (decompressed 534.9 percent)
[13:33:55] - Starting from initial work packet
[13:33:55]
[13:33:55] Project: 3064 (Run 2, Clone 118, Gen 16)
[13:33:55]
[13:33:55] Assembly optimizations on if available.
[13:33:55] Entering M.D.
[13:34:01] mdrunner cpfilename:
[13:34:01] Rejecting checkpoint
[13:34:02] ProteinWriting local files
[13:34:02]
[13:34:02] Writing local files
[13:34:02] Extra SSE boost OK.
[13:34:02] Completed 0 out of 5000000 steps  (0 percent)
[13:53:29] Writing local files
[13:53:30] Completed 50000 out of 5000000 steps  (1 percent)
[14:12:57] Writing local files
[14:12:57] Completed 100000 out of 5000000 steps  (2 percent)
[14:32:24] Writing local files
[14:32:24] Completed 150000 out of 5000000 steps  (3 percent)
[14:51:53] Writing local files
[14:51:53] Completed 200000 out of 5000000 steps  (4 percent)
[15:11:23] Writing local files
[15:11:23] Completed 250000 out of 5000000 steps  (5 percent)
[15:30:51] Writing local files
[15:30:51] Completed 300000 out of 5000000 steps  (6 percent)
[15:50:19] Writing local files
[15:50:19] Completed 350000 out of 5000000 steps  (7 percent)
[16:09:48] Writing local files
[16:09:48] Completed 400000 out of 5000000 steps  (8 percent)
[16:29:17] Writing local files
[16:29:17] Completed 450000 out of 5000000 steps  (9 percent)
[16:48:45] Writing local files
[16:48:46] Completed 500000 out of 5000000 steps  (10 percent)
[17:08:14] Writing local files
[17:08:14] Completed 550000 out of 5000000 steps  (11 percent)
[17:27:43] Writing local files
[17:27:43] Completed 600000 out of 5000000 steps  (12 percent)
[17:47:12] Writing local files
[17:47:12] Completed 650000 out of 5000000 steps  (13 percent)
[18:06:39] Writing local files
[18:06:39] Completed 700000 out of 5000000 steps  (14 percent)
[18:26:09] Writing local files
[18:26:09] Completed 750000 out of 5000000 steps  (15 percent)
[18:45:37] Writing local files
[18:45:37] Completed 800000 out of 5000000 steps  (16 percent)
[19:05:07] Writing local files
[19:05:07] Completed 850000 out of 5000000 steps  (17 percent)
[19:24:35] Writing local files
[19:24:35] Completed 900000 out of 5000000 steps  (18 percent)
[19:44:04] Writing local files
[19:44:04] Completed 950000 out of 5000000 steps  (19 percent)
[20:03:35] Writing local files
[20:03:35] Completed 1000000 out of 5000000 steps  (20 percent)
[20:23:11] Writing local files
[20:23:11] Completed 1050000 out of 5000000 steps  (21 percent)
[20:42:48] Writing local files
[20:42:48] Completed 1100000 out of 5000000 steps  (22 percent)
[21:02:24] Writing local files
[21:02:24] Completed 1150000 out of 5000000 steps  (23 percent)
[21:13:48] CoreStatus = 0 (0)
[21:13:48] Client-core communications error: ERROR 0x0
[21:13:48] Deleting current work unit & continuing...
[23:21:13] - Preparing to get new work unit...
[23:21:13] + Attempting to get work packet
[23:21:13] - Will indicate memory of 1024 MB
[23:21:13] - Connecting to assignment server
[23:21:13] Connecting to http://assign.stanford.edu:8080/
[23:21:13] Initial: 40AB; - Successful: assigned to (171.64.65.63).
[23:21:13] + News From Folding@Home: Welcome to Folding@Home
[23:21:13] Loaded queue successfully.
[23:21:13] Connecting to http://171.64.65.63:8080/
[23:21:14] Initial: 0000; - Receiving payload (expected size: 610538)
[23:21:15] - Downloaded at ~596 kB/s
[23:21:15] - Averaged speed for that direction ~614 kB/s
[23:21:15] + Received work.
[23:21:15] + Closed connections
[23:21:15]
[23:21:15] + Processing work unit
[23:21:15] Core required: FahCore_a1.exe
[23:21:15] Core found.
[23:21:15] Working on Unit 03 [October 27 23:21:15]
[23:21:15] + Working ...
[23:21:15] - Calling './mpiexec -np 4 -host 127.0.0.1 ./FahCore_a1.exe -dir work/ -suffix 03 -checkpoint 30 -forceasm -verbose -lifeline 241 -version 602'
[23:21:15]
[23:21:15] *------------------------------*
[23:21:15] Folding@Home Gromacs SMP Core
[23:21:15] Version 1.73 (November 27, 2006)
[23:21:15]
[23:21:15] Preparing to commence simulation
[23:21:15] - Ensuring status. Please wait.
[23:21:32] - Assembly optimizations manually forced on.
[23:21:32] - Not checking prior termination.
[23:21:33] - Expanded 610026 -> 3263429 (decompressed 534.9 percent)
[23:21:33] - Starting from initial work packet
[23:21:33]
[23:21:33] Project: 3064 (Run 2, Clone 118, Gen 16)
[23:21:33]
[23:21:33] Assembly optimizations on if available.
[23:21:33] Entering M.D.
[23:21:39] mdrunner cpfilename:
[23:21:39] Protein: p3064_lambdaProteinWriting local files
[23:21:39]
[23:21:39] Writing local files
[23:21:40] Extra SSE boost OK.
[23:21:40] Writing local files
[23:21:40] Completed 0 out of 5000000 steps  (0 percent)
[23:41:07] Writing local files
[23:41:07] Completed 50000 out of 5000000 steps  (1 percent)
[00:00:36] Writing local files
[00:00:36] Completed 100000 out of 5000000 steps  (2 percent)
[00:20:04] Writing local files
[00:20:04] Completed 150000 out of 5000000 steps  (3 percent)
[00:39:33] Writing local files
[00:39:33] Completed 200000 out of 5000000 steps  (4 percent)
[00:59:03] Writing local files
[00:59:03] Completed 250000 out of 5000000 steps  (5 percent)
[01:18:31] Writing local files
[01:18:31] Completed 300000 out of 5000000 steps  (6 percent)
[01:38:00] Writing local files
[01:38:00] Completed 350000 out of 5000000 steps  (7 percent)
[01:57:29] Writing local files
[01:57:29] Completed 400000 out of 5000000 steps  (8 percent)
[02:16:58] Writing local files
[02:16:58] Completed 450000 out of 5000000 steps  (9 percent)
[02:36:27] Writing local files
[02:36:27] Completed 500000 out of 5000000 steps  (10 percent)
[02:55:56] Writing local files
[02:55:56] Completed 550000 out of 5000000 steps  (11 percent)
[03:15:25] Writing local files
[03:15:25] Completed 600000 out of 5000000 steps  (12 percent)
[03:34:53] Writing local files
[03:34:53] Completed 650000 out of 5000000 steps  (13 percent)
[03:54:21] Writing local files
[03:54:22] Completed 700000 out of 5000000 steps  (14 percent)
[04:13:52] Writing local files
[04:13:52] Completed 750000 out of 5000000 steps  (15 percent)
[04:33:22] Writing local files
[04:33:23] Completed 800000 out of 5000000 steps  (16 percent)
[04:52:51] Writing local files
[04:52:51] Completed 850000 out of 5000000 steps  (17 percent)
[05:12:20] Writing local files
[05:12:20] Completed 900000 out of 5000000 steps  (18 percent)
[05:31:49] Writing local files
[05:31:49] Completed 950000 out of 5000000 steps  (19 percent)
[05:51:18] Writing local files
[05:51:19] Completed 1000000 out of 5000000 steps  (20 percent)
[06:10:47] Writing local files
[06:10:47] Completed 1050000 out of 5000000 steps  (21 percent)
[06:30:16] Writing local files
[06:30:16] Completed 1100000 out of 5000000 steps  (22 percent)
[06:49:46] Writing local files
[06:49:46] Completed 1150000 out of 5000000 steps  (23 percent)
[07:01:01]
[07:01:01] Folding@home Core Shutdown: INTERRUPTED
[07:01:05] CoreStatus = 0 (0)
[07:01:05] Client-core communications error: ERROR 0x0
[07:01:05] Deleting current work unit & continuing...
[09:05:54] - Preparing to get new work unit...
[09:05:54] + Attempting to get work packet
[09:05:54] - Will indicate memory of 1024 MB
[09:05:54] - Connecting to assignment server
[09:05:54] Connecting to http://assign.stanford.edu:8080/
[09:05:54] Posted data.
[09:05:54] Initial: 40AB; - Successful: assigned to (171.64.65.63).
[09:05:54] + News From Folding@Home: Welcome to Folding@Home
[09:05:54] Loaded queue successfully.
[09:05:54] Connecting to http://171.64.65.63:8080/
[09:05:55] Posted data.
[09:05:55] Initial: 0000; - Receiving payload (expected size: 610538)
[09:05:56] - Downloaded at ~596 kB/s
[09:05:56] - Averaged speed for that direction ~638 kB/s
[09:05:56] + Received work.
[09:05:56] + Closed connections
[09:05:56]
[09:05:56] + Processing work unit
[09:05:56] Core required: FahCore_a1.exe
[09:05:56] Core found.
[09:05:56] Working on Unit 05 [October 29 09:05:56]
[09:05:56] + Working ...
[09:05:56] - Calling './mpiexec -np 4 -host 127.0.0.1 ./FahCore_a1.exe -dir work/ -suffix 05 -checkpoint 30 -forceasm -verbose -lifeline 241 -version 602'
[09:05:56]
[09:05:56] *------------------------------*
[09:05:56] Folding@Home Gromacs SMP Core
[09:05:56] Version 1.73 (November 27, 2006)
[09:05:56]
[09:05:56] Preparing to commence simulation
[09:05:56] - Ensuring status. Please wait.
[09:06:13] - Assembly optimizations manually forced on.
[09:06:13] - Not checking prior termination.
[09:06:14] - Expanded 610026 -> 3263429 (decompressed 534.9 percent)
[09:06:14] - Starting from initial work packet
[09:06:14]
[09:06:14] Project: 3064 (Run 2, Clone 118, Gen 16)
[09:06:14]
[09:06:14] Assembly optimizations on if available.
[09:06:14] Entering M.D.
[09:06:20] mdrunner cpfilename:
[09:06:20] Protein: p3064_lambdaProteinWriting local files
[09:06:20]
[09:06:20] Writing local files
[09:06:21] Extra SSE boost OK.
[09:06:21] Writing local files
[09:06:21] Completed 0 out of 5000000 steps  (0 percent)
[09:25:47] Writing local files
[09:25:48] Completed 50000 out of 5000000 steps  (1 percent)
[09:45:16] Writing local files
[09:45:16] Completed 100000 out of 5000000 steps  (2 percent)
[10:04:43] Writing local files
[10:04:43] Completed 150000 out of 5000000 steps  (3 percent)
[10:24:12] Writing local files
[10:24:12] Completed 200000 out of 5000000 steps  (4 percent)
[10:43:41] Writing local files
[10:43:41] Completed 250000 out of 5000000 steps  (5 percent)
[11:03:08] Writing local files
[11:03:08] Completed 300000 out of 5000000 steps  (6 percent)
[11:22:36] Writing local files
[11:22:36] Completed 350000 out of 5000000 steps  (7 percent)
[11:42:05] Writing local files
[11:42:05] Completed 400000 out of 5000000 steps  (8 percent)
[12:01:33] Writing local files
[12:01:33] Completed 450000 out of 5000000 steps  (9 percent)
[12:21:01] Writing local files
[12:21:02] Completed 500000 out of 5000000 steps  (10 percent)
[12:40:30] Writing local files
[12:40:30] Completed 550000 out of 5000000 steps  (11 percent)
[12:59:59] Writing local files
[12:59:59] Completed 600000 out of 5000000 steps  (12 percent)
[13:19:27] Writing local files
[13:19:27] Completed 650000 out of 5000000 steps  (13 percent)
[13:38:54] Writing local files
[13:38:54] Completed 700000 out of 5000000 steps  (14 percent)
[13:58:23] Writing local files
[13:58:23] Completed 750000 out of 5000000 steps  (15 percent)
[14:17:53] Writing local files
[14:17:53] Completed 800000 out of 5000000 steps  (16 percent)
[14:37:21] Writing local files
[14:37:21] Completed 850000 out of 5000000 steps  (17 percent)
[14:56:49] Writing local files
[14:56:49] Completed 900000 out of 5000000 steps  (18 percent)
[15:16:17] Writing local files
[15:16:17] Completed 950000 out of 5000000 steps  (19 percent)
[15:35:45] Writing local files
[15:35:46] Completed 1000000 out of 5000000 steps  (20 percent)
[15:55:14] Writing local files
[15:55:14] Completed 1050000 out of 5000000 steps  (21 percent)
[16:14:42] Writing local files
[16:14:42] Completed 1100000 out of 5000000 steps  (22 percent)
[16:34:11] Writing local files
[16:34:11] Completed 1150000 out of 5000000 steps  (23 percent)
[16:45:27]
[16:45:27] Folding@home Core Shutdown: INTERRUPTED
[16:45:31] CoreStatus = 66 (102)
[16:45:31] + Shutdown requested by user. Exiting.***** Got a SIGTERM signal (15)
[16:45:31] Killing all core threads
Folding@Home Client Shutdown.
Re: Project 3064 (Run 2, Clone 118, Gen 16)
Someone else completed this WU.
Update your client to 6.23 if you didn't do so.
Phantom
Post by Phantom »
toTOW wrote:Someone else completed this WU.
Just a follow-up... What does this mean? Are WUs assigned to multiple people?
rpmouton
Hardware configuration: 1-MSI 990FXA-GD65V2 AM3+, AMD FX-8120 8-Core Black Edition-3.1 GHz, Mushkin Enhanced Blackline 8GB (2 x 4GB) 1600 MHz and ASUS GeForce GTX 550 Ti. Win 7 64x, 7.1x client with SMP and GPU slots ~14k ppd
2-ASUS M2NE-SLI AM2, AMD Phenom 4 @ 2.3 GHZ, 4 GB @ 800 MHz and ASUS GeForce GTX 550 Ti. Win Vista 64x, 7.1x client with SMP and GPU slots ~10k ppd
3-MSI 785GTM-E45 AM2+, AMD Phenom 4 Propus @ 3 GHZ, 4GB @ 800 MHZ, Win 7 64x, 7.1x client with SMP slots ~4k ppd
4-DELL 2950 Gen III, 2 Xeon E5405 Quad core @ 2GHz, 8 GB @ 669MHz, Ubuntu 12.04, 7.1 client with one SMP slot (bigadv) ~12k ppd
Post by rpmouton »
There has been some discussion on this but I don't recall a definitive answer..
If partial results are returned it definitely gets reassigned. If someone else has completed it you should be able to as well.
regards,
Roger
Phantom
Post by Phantom »
regards,
I just hate to waste CPU/electricity performing work that has already been completed. Hopefully, this is a rare occurrence.
Thanks.
anandhanju
Re: Project: 3064 (Run 2, Clone 118, Gen 16)
Post by anandhanju »
Work units are reissued when
a) Their preferred deadline expires
b) An EUE occurs (it does send a partial result). If there are a certain number of EUEs on the same unit, then the staff pull it out of circulation.
Unlike some other DC projects, this one does *not* send out the same WU to multiple volunteers unless the above mentioned conditions occur.
