I have had multiple 100% EUE failure rate on this WU at 92% each time since 22 Oct.
[05:58:33] Completed 230000 out of 250000 steps (92 percent)
[06:07:11] Warning: long 1-4 interactions
[06:07:12] Gromacs cannot continue further.
[06:07:12] Going to send back what have done.
[06:07:12] logfile size: 180932
[06:07:12] - Writing 181468 bytes of core data to disk...
[06:07:12] ... Done.
[06:09:18]
[06:09:18] Folding@home Core Shutdown: EARLY_UNIT_END
[06:09:18]
[06:09:24] CoreStatus = 7B (123)
[06:09:24] Client-core communications error: ERROR 0x7b
[06:09:24] Deleting current work unit & continuing...
[06:09:24] Using generic mpiexec calls
[06:11:28] - Warning: Could not delete all work unit files (3): Core returned invalid code
[06:11:28] Trying to send all finished work units
[06:12:17] Project: 2665 (Run 2, Clone 68, Gen 56)
[06:12:17]
[06:12:17] 665 (Run 2, Clone 68, Gen 56)
[07:42:57] Folding@home Core Shutdown: EARLY_UNIT_END
[07:43:03] CoreStatus = 7B (123)
[07:43:03] Client-core communications error: ERROR 0x7b
Project: 2665 (Run 2, Clone 68, Gen 56) - EUE [ERROR 0x7b]
Re: 2665 (Run 2, Clone 68, Gen 56)-EUE
If you're not using the 6.23 client yet, we would recommend upgrading. That client does automatic EUE reporting for most types of EUE's.
There is another report in the DB for partial credit.
HenryW
- Hardware configuration: Msi P35 Neo-F
Q6600 B3 OC 2.8
A DATA 2x1GB DDR2 800
ULTRA Xpro 800W PSU
PNY 9600 GT
XP Home SP3
Did that yesterday after seeing it on the forum here. I figured I would stop getting the same WU over and over again by doing that. I just wanted anyone that has anything to do with it be aware of that specifiic WU being a problem as I did a cursory search and didn't see it mentioned. I account for about 4%-5% of my teams folding so when mine takes a dump it affects my team quite a bit and probably doesn't help Stanford much either.
