Project: 5506 (Run 6, Clone 886, Gen 36)
Flathead74
Post by Flathead74 »
I think it is possible that this is a bad WU.
I have received it six times now and the results are exactly the same each time.
A little misleading perhaps, because I did not request the shutdown, the client did.
[03:39:34] Project: 5506 (Run 6, Clone 886, Gen 36)
[03:39:34]
[03:39:34] Assembly optimizations on if available.
[03:39:34] Entering M.D.
[03:39:40] Working on p5506_supervillin_e1
[03:39:41] Client config found, loading data.
[03:39:41] mdrun_gpu returned
[03:39:41] NANs detected on GPU
[03:39:41]
[03:39:41] Folding@home Core Shutdown: INTERRUPTED
[03:39:44] CoreStatus = 66 (102)
[03:39:44] + Shutdown requested by user. Exiting.***** Got a SIGTERM signal (2)
[03:39:44] Killing all core threads
Folding@Home Client Shutdown.
Re: Project: 5506 (Run 6, Clone 886, Gen 36)
Yes it's a bad WU ... there are many reports for 0 credit in the DB.
What version of the core do you use to get the INTERRUPTED error ?
Flathead74
toTOW wrote:Yes it's a bad WU ... there are many reports for 0 credit in the DB.
Version 1.13
Force update to 1.15, it solves the INTERRUPTED issue.
Flathead74
Thanks, toTOW.
