This unit almost made it, then it exited with an error I haven't seen before - see below:
[21:51:59] Completed 96%
[21:52:28] mdrun_gpu returned
[21:52:28] Nonzero force sum on GPU
[21:52:28]
[21:52:28] Folding@home Core Shutdown: UNSTABLE_MACHINE
[21:52:39] CoreStatus = 7A (122)
[21:52:39] Sending work to server
[21:52:39] Project: 5015 (Run 7, Clone 68, Gen 235)
[21:52:39] - Read packet limit of 540015616... Set to 524286976.
[21:52:39] - Error: Could not get length of results file work/wuresults_04.dat
[21:52:39] - Error: Could not read unit 04 file. Removing from queue.
[21:52:39] - Preparing to get new work unit...
Any idea what happened here? This machine does not crash WUs normally. It uses a Gigabyte 8800GTS (G92-chip) at stock clocks.
Was the WU credited by the way? I'm not sure since I never got a "Thank you for contributing.." message, just the two errors shown above.
Thanks!
Re: Project: 5015 (Run 7, Clone 68, Gen 235)
There's another report for partial credit.
It might be the en of a simulation (see the high Gen number) or a core 1.15 instability ... not much you could do about it.
