finished the WU, now can't upload??
[00:36:56] Completed 125000 out of 125000 steps (100%)
[00:36:56] Writing final coordinates.
[00:36:58] Past main M.D. loop
[00:37:59]
[00:37:59] Finished Work Unit:
[00:37:59] - Reading up to 7393248 from "work/wudata_07.arc": Read 7393248
[00:37:59] - Reading up to 10460532 from "work/wudata_07.xtc": Read 10460532
[00:37:59] goefile size: 0
[00:37:59] logfile size: 32465
[00:38:00] Leaving Run
[00:38:03] - Writing 17935809 bytes of core data to disk...
[00:38:13] Done: 17935297 -> 17456287 (compressed to 97.3 percent)
[00:38:15] ... Done.
[00:38:18] - Shutting down core
[00:38:18]
[00:38:18] Folding@home Core Shutdown: FINISHED_UNIT
[00:38:21] CoreStatus = 64 (100)
[00:38:21] Sending work to server
[00:38:21] + Attempting to send results
[00:38:22] - Couldn't send HTTP request to server
[00:38:22] + Could not connect to Work Server (results)
[00:38:22] (171.64.65.65:8080)
[00:38:22] - Error: Could not transmit unit 07 (completed January 7) to work server.
[00:38:22] Keeping unit 07 in queue.
[00:38:22] + Attempting to send results
[00:38:22] (171.65.103.100:8080)
[00:38:22] Could not transmit unit 07 to Collection server; keeping in queue.
[00:38:22] - Preparing to get new work unit...
[00:38:22] + Attempting to get work packet
[00:38:22] - Connecting to assignment server
[00:38:22] - Successful: assigned to (171.64.65.111).
[00:38:22] + News From Folding@Home: Welcome to Folding@Home
[00:38:22] Loaded queue successfully.
[00:38:24] + Attempting to send results
[00:38:24] - Couldn't send HTTP request to server
[00:38:24] + Could not connect to Work Server (results)
[00:38:24] (171.64.65.65:8080)
[00:38:24] - Error: Could not transmit unit 07 (completed January 7) to work server.
[00:38:24] (171.65.103.100:8080)
[00:38:24] Could not transmit unit 07 to Collection server; keeping in queue.
[00:38:24] + Closed connections
[00:38:24]
[00:38:24] + Processing work unit
[00:38:24] Core required: FahCore_81.exe
[00:38:24] Core found.
[00:38:24] Working on Unit 08 [January 7 00:38:24]
[00:38:24] + Working ...
[00:38:25]
[00:38:25] *------------------------------*
[00:38:25] Folding@Home Gromacs Simulated Tempering Core
[00:38:25] Version 1.00 (Dec 9, 2006)
[00:38:25]
[00:38:25] Preparing to commence simulation
[00:38:25] - Looking at optimizations...
[00:38:25] - Created dyn
[00:38:25] - Files status OK
[00:38:25] - Expanded 561682 -> 2772113 (decompressed 493.5 percent)
[00:38:25] - Starting from initial work packet
[00:38:25]
[00:38:25] Project: 4107 (Run 54, Clone 9, Gen 3)
[00:38:25]
[00:38:25] Assembly optimizations on if available.
[00:38:25] Entering M.D.
Gromacs is Copyright (c) 1991-2003, University of Groningen, The Netherlands
This inclusion of Gromacs code in the Folding@Home Core is under
a special license (see http://folding.stanford.edu/gromacs.html)
specially granted to Stanford by the copyright holders. If you
are interested in using Gromacs, visit http://www.gromacs.org where
you can download a free version of Gromacs under
the terms of the GNU General Public License (GPL) as published
by the Free Software Foundation; either version 2 of the License,
or (at your option) any later version.
[00:38:32] Protein: p4107_ww_unf_Amber03_Extended
[00:38:32]
[00:38:32] Writing local files
[00:38:32] Extra SSE boost OK.
[00:38:32] Completed 0 out of 1500000 steps (0%)
opened a another terminal window and:
[root@lintest ~]# ping 171.64.65.65
PING 171.64.65.65 (171.64.65.65) 56(84) bytes of data.
64 bytes from 171.64.65.65: icmp_seq=1 ttl=52 time=32.0 ms
64 bytes from 171.64.65.65: icmp_seq=2 ttl=52 time=31.6 ms
64 bytes from 171.64.65.65: icmp_seq=3 ttl=52 time=33.2 ms
64 bytes from 171.64.65.65: icmp_seq=4 ttl=52 time=43.6 ms
64 bytes from 171.64.65.65: icmp_seq=5 ttl=52 time=33.4 ms
64 bytes from 171.64.65.65: icmp_seq=6 ttl=52 time=29.8 ms
^C64 bytes from 171.64.65.65: icmp_seq=7 ttl=52 time=34.7 ms
64 bytes from 171.64.65.65: icmp_seq=8 ttl=52 time=32.2 ms
64 bytes from 171.64.65.65: icmp_seq=9 ttl=52 time=30.7 ms
--- 171.64.65.65 ping statistics ---
9 packets transmitted, 9 received, 0% packet loss, time 8000ms
rtt min/avg/max/mdev = 29.873/33.523/43.616/3.820 ms
any ideas?? I can ping the box but not transmit data to it?
I restarted the 504 client, no help. I see three different errors here:
1. Couldn't send HTTP request to server
2. Could not connect to Work Server
3. Could not transmit unit 07......
tried another restart while running a continuous ping against the work server, couldn't connect and upload, but continuous ping had no errors or timeouts.
how do I fix this?
can't upload results??
Re: can't upload results??
well criminy, no sooner did I post this than it uploaded results successfully.
Why does it say: Working on Unit 08 [January 7 01:05:42]
but also : [01:10:01] + Number of Units Completed: 5
Did I lose some? last week there were days when I thought it started another WU, but no results were posted?
User name: Tom (Team 53803)
User ID: 11E7B0865E637D57
Machine ID: 5
Machine ID: 5
I'm pretty sure 'working on unit 8' just means that it's using the 8th position in the queue to store your interim results.
I'm not sure what determines the log report of how many units you've completed. I just rely on the statistics to say how many units I've completed, which is 465 over 5 clients. When I look at any of my logs after it uploads a unit, it never shows a 'high' number as units completed - I think the most I've seen is 49. Maybe it's the number of units completed since the last time I shut down the client?
It shows how many you completed with that client on that machine with that machine ID. Reinstalling a client will reset the count.
