Project: 2605 (Run 15, Clone 485, Gen 99)
error10
Post by error10 »
This unit went to 100% at which point I got a Client-core communications error. I tried to run qfix on it, and now it says the work unit has already been sent! But nowhere in my log does it show the WU being successfully sent.
entry 7, status 0, address 171.64.65.56:8080
entry 8, status 0, address 171.64.65.56:8080
entry 9, status 0, address 171.64.122.88:8080
entry 0, status 0, address 171.67.108.24:8080
entry 1, status 0, address 171.64.65.56:8080
entry 2, status 0, address 171.64.65.56:8080
entry 3, status 0, address 171.64.65.56:8080
entry 4, status 0, address 171.64.65.56:8080
  Found results <work/wuresults_04.dat>: proj 2605, run 15, clone 485, gen 99
   -- queue entry: proj 2605, run 15, clone 485, gen 99
   -- already sent
entry 5, status 0, address 171.64.65.64:8080
entry 6, status 1, address 171.67.108.24:8080
File is OK
Is there some way to unmark this WU as sent so I can upload it?
Re: Project: 2605 (Run 15, Clone 485, Gen 99)
Try this procedure :
- run the client with "-delete 04" flag
- run qfix
- restart the client, it should send the recovered result.
error10
Post by error10 »
I tried that, but it still says the work unit is "already sent."
root@underground ~/.fah # ./fah6 -delete 04
Note: Please read the license agreement (fah6 -license). Further
use of this software requires that you have read and accepted this agreement.
--- Opening Log file [October 24 19:05:35]
# Linux Console Edition #######################################################
                       Folding@Home Client Version 6.02
                          http://folding.stanford.edu
Launch directory: /root/.fah
Executable: ./fah6
Arguments: -delete 04
[19:05:35] - Ask before connecting: No
[19:05:35] - User name: error10 (Team 37726)
[19:05:35] - User ID: 3444A76F0D5F0762
[19:05:35] - Machine ID: 1
[19:05:35]
[19:05:35] Loaded queue successfully.
[19:05:35] Deleting work unit #4 from work queue...
[19:05:35] - Failed to delete the requested work unit
Folding@Home Client Shutdown.
root@underground ~/.fah # ./qfix
   -- already sent
entry 6, status 2, address 171.67.108.24:8080
  Found results <work/wuresults_06.dat>: proj 2670, run 2, clone 68, gen 15
   -- queue entry: proj 2670, run 2, clone 68, gen 15
   -- already queued for upload
File is OK
What does the client say when you restart it ?
error10
Post by error10 »
The client just ignores it and goes on working the next WU.
error10
Post by error10 »
I am sure the deadline for this WU is fast approaching. Is there really no way I can send the results?
error10
Post by error10 »
Well it's past deadline now, so nothing I can do. But I'd still like to know how to recover from this situation, in case it happens again.
