Project: 5506 (Run 5, Clone 961, Gen 56)
anko1
(3.2GHz) HT;Windows XP
Post by anko1 »
Hmm. I'm not overclocked, so I presumed the problem wasn't me, but maybe it is, or maybe just bad luck? On the other hand, I'm not accused of an unstable machine this time. ;-)
[22:56:00] + Closed connections
[22:56:00]
[22:56:00] + Processing work unit
[22:56:00] Core required: FahCore_11.exe
[22:56:00] Core found.
[22:56:00] Working on queue slot 04 [October 18 22:56:00 UTC]
[22:56:00] + Working ...
[22:56:00] - Calling '.\FahCore_11.exe -dir work/ -suffix 04 -priority 96 -checkpoint 15 -verbose -lifeline 684 -version 620'
[22:56:00]
[22:56:00] *------------------------------*
[22:56:00] Folding@Home GPU Core - Beta
[22:56:00] Version 1.15 (Mon Oct 13 11:11:30 PDT 2008)
[22:56:00]
[22:56:00] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[22:56:00] Build host: amoeba
[22:56:00] Board Type: Nvidia
[22:56:00] Core      :
[22:56:00] Preparing to commence simulation
[22:56:00] - Looking at optimizations...
[22:56:00] - Created dyn
[22:56:00] - Files status OK
[22:56:00] - Expanded 45508 -> 246249 (decompressed 541.1 percent)
[22:56:00] Called DecompressByteArray: compressed_data_size=45508 data_size=246249, decompressed_data_size=246249 diff=0
[22:56:00] - Digital signature verified
[22:56:00]
[22:56:00] Project: 5506 (Run 5, Clone 961, Gen 56)
[22:56:00]
[22:56:00] Assembly optimizations on if available.
[22:56:00] Entering M.D.
[22:56:06] Working on p5506_supervillin_e1
[22:56:07] Client config found, loading data.
[22:56:07] Starting GUI Server
[22:57:36] Completed 1%
[22:59:06] Completed 2%
[23:00:35] Completed 3%
[23:02:06] Completed 4%
[23:03:35] Completed 5%
[23:05:03] Completed 6%
[23:06:30] Completed 7%
[23:07:57] Completed 8%
[23:09:26] Completed 9%
[23:10:47] Run: exception thrown during GuardedRun
[23:10:47] Run: exception thrown in GuardedRun -- Gromacs cannot continue further.
[23:10:47] Going to send back what have done -- stepsTotalG=25000000
[23:10:47] Work fraction=0.0992 steps=25000000.
[23:10:51] logfile size=21319 infoLength=21319 edr=0 trr=23
[23:10:51] - Writing 21855 bytes of core data to disk...
[23:10:51]   ... Done.
[23:10:51]
[23:10:51] Folding@home Core Shutdown: EARLY_UNIT_END
[23:10:54] CoreStatus = 72 (114)
[23:10:54] Sending work to server
[23:10:54] Project: 5506 (Run 5, Clone 961, Gen 56)
[23:10:54] - Read packet limit of 540015616... Set to 524286976.
[23:10:54] + Attempting to send results [October 18 23:10:54 UTC]
[23:10:54] - Reading file work/wuresults_04.dat from core
[23:10:54]   (Read 21855 bytes from disk)
[23:10:54] Connecting to http://171.64.65.106:8080/
[23:10:54] Posted data.
[23:10:55] Initial: 0000; - Uploaded at ~22 kB/s
[23:10:55] - Averaged speed for that direction ~44 kB/s
[23:10:55] + Results successfully sent
[23:10:55] Thank you for your contribution to Folding@Home.
Re: Project: 5506 (Run 5, Clone 961, Gen 56)
Someone else was able to complete this WU successfully.
anko1
Post by anko1 »
Well, should I worry about my machine? I have an ASUS P5Q mother board, VGA BFG 9800TX R graphics card and an Intel C2Q cpu. I'm not overclocked and completing most of my units successfully. Is a certain amount of attrition normal?
I think it's just core instabilities related to latest version ... you're not alone : viewtopic.php?f=52&t=6203 ;)
anko1
Post by anko1 »
Thanks for reassurance! [I'd actually cruised through most of that thread already, but had been so successful until those two relatively close units, that I was feeling somewhat smug about my computer's performance. Guess I just got brought back down to earth. ;-) ]
