Project: 5506 (Run 6, Clone 324, Gen 171) bad wu
mikeb12
Post by mikeb12 »
Vista64 6.20r1 console
looks like a bad wu. this gpu completes wu's back to back without issues 24/7..
until it got this wu.
[16:37:16] Folding@home Core Shutdown: FINISHED_UNIT
[16:37:20] CoreStatus = 64 (100)
[16:37:20] Sending work to server
[16:37:20] Project: 5506 (Run 2, Clone 744, Gen 125)
[16:37:20] + Attempting to send results [October 18 16:37:20 UTC]
[16:37:43] + Results successfully sent
[16:37:43] Thank you for your contribution to Folding@Home.
[16:37:43] + Number of Units Completed: 44
[16:37:47] - Preparing to get new work unit...
[16:37:47] + Attempting to get work packet
[16:37:47] - Connecting to assignment server
[16:37:48] - Successful: assigned to (171.64.65.106).
[16:37:48] + News From Folding@Home: GPU folding beta
[16:37:48] Loaded queue successfully.
[16:37:49] + Closed connections
[16:37:49]
[16:37:49] + Processing work unit
[16:37:49] Core required: FahCore_11.exe
[16:37:49] Core found.
[16:37:49] Working on queue slot 08 [October 18 16:37:49 UTC]
[16:37:49] + Working ...
[16:37:49]
[16:37:49] *------------------------------*
[16:37:49] Folding@Home GPU Core - Beta
[16:37:49] Version 1.15 (Mon Oct 13 11:11:30 PDT 2008)
[16:37:49]
[16:37:49] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[16:37:49] Build host: amoeba
[16:37:49] Board Type: Nvidia
[16:37:49] Core      :
[16:37:49] Preparing to commence simulation
[16:37:49] - Looking at optimizations...
[16:37:49] - Created dyn
[16:37:49] - Files status OK
[16:37:49] - Expanded 45479 -> 246249 (decompressed 541.4 percent)
[16:37:49] Called DecompressByteArray: compressed_data_size=45479 data_size=246249, decompressed_data_size=246249 diff=0
[16:37:49] - Digital signature verified
[16:37:49]
[16:37:49] Project: 5506 (Run 6, Clone 324, Gen 171)
[16:37:49]
[16:37:49] Assembly optimizations on if available.
[16:37:49] Entering M.D.
[16:37:56] Working on p5506_supervillin_e1
[16:37:56] Client config found, loading data.
[16:37:56] Starting GUI Server
[16:37:57] mdrun_gpu returned
[16:37:57] NANs detected on GPU
[16:37:57]
[16:37:57] Folding@home Core Shutdown: UNSTABLE_MACHINE
[16:38:00] CoreStatus = 7A (122)
[16:38:00] Sending work to server
[16:38:00] Project: 5506 (Run 6, Clone 324, Gen 171)
[16:38:00] - Error: Could not get length of results file work/wuresults_08.dat
[16:38:00] - Error: Could not read unit 08 file. Removing from queue.
[16:38:00] - Preparing to get new work unit...
[16:38:00] + Attempting to get work packet
[16:38:00] - Connecting to assignment server
[16:38:00] - Successful: assigned to (171.64.65.106).
[16:38:00] + News From Folding@Home: GPU folding beta
[16:38:00] Loaded queue successfully.
[16:38:01] + Closed connections
[16:38:06]
[16:38:06] + Processing work unit
[16:38:06] Core required: FahCore_11.exe
[16:38:06] Core found.
[16:38:06] Working on queue slot 09 [October 18 16:38:06 UTC]
[16:38:06] + Working ...
[16:38:06]
[16:38:06] *------------------------------*
[16:38:06] Folding@Home GPU Core - Beta
[16:38:06] Version 1.15 (Mon Oct 13 11:11:30 PDT 2008)
[16:38:06]
[16:38:06] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[16:38:06] Build host: amoeba
[16:38:06] Board Type: Nvidia
[16:38:06] Core      :
[16:38:06] Preparing to commence simulation
[16:38:06] - Looking at optimizations...
[16:38:06] - Created dyn
[16:38:06] - Files status OK
[16:38:06] - Expanded 45479 -> 246249 (decompressed 541.4 percent)
[16:38:06] Called DecompressByteArray: compressed_data_size=45479 data_size=246249, decompressed_data_size=246249 diff=0
[16:38:06] - Digital signature verified
[16:38:06]
[16:38:06] Project: 5506 (Run 6, Clone 324, Gen 171)
[16:38:06]
[16:38:06] Assembly optimizations on if available.
[16:38:06] Entering M.D.
[16:38:13] Working on p5506_supervillin_e1
[16:38:13] Client config found, loading data.
[16:38:13] mdrun_gpu returned
[16:38:13] NANs detected on GPU
[16:38:13]
[16:38:13] Folding@home Core Shutdown: UNSTABLE_MACHINE
[16:38:13] Starting GUI Server
[16:38:17] CoreStatus = 7A (122)
[16:38:17] Sending work to server
[16:38:17] Project: 5506 (Run 6, Clone 324, Gen 171)
[16:38:17] - Error: Could not get length of results file work/wuresults_09.dat
[16:38:17] - Error: Could not read unit 09 file. Removing from queue.
[16:38:17] - Preparing to get new work unit...
[16:38:17] + Attempting to get work packet
[16:38:17] - Connecting to assignment server
[16:38:17] - Successful: assigned to (171.64.65.106).
[16:38:17] + News From Folding@Home: GPU folding beta
[16:38:17] Loaded queue successfully.
[16:38:18] + Closed connections
[16:38:23]
[16:38:23] + Processing work unit
[16:38:23] Core required: FahCore_11.exe
[16:38:23] Core found.
[16:38:23] Working on queue slot 00 [October 18 16:38:23 UTC]
[16:38:23] + Working ...
[16:38:23]
[16:38:23] *------------------------------*
[16:38:23] Folding@Home GPU Core - Beta
[16:38:23] Version 1.15 (Mon Oct 13 11:11:30 PDT 2008)
[16:38:23]
[16:38:23] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[16:38:23] Build host: amoeba
[16:38:23] Board Type: Nvidia
[16:38:23] Core      :
[16:38:23] Preparing to commence simulation
[16:38:23] - Looking at optimizations...
[16:38:23] - Created dyn
[16:38:23] - Files status OK
[16:38:23] - Expanded 45479 -> 246249 (decompressed 541.4 percent)
[16:38:23] Called DecompressByteArray: compressed_data_size=45479 data_size=246249, decompressed_data_size=246249 diff=0
[16:38:23] - Digital signature verified
[16:38:23]
[16:38:23] Project: 5506 (Run 6, Clone 324, Gen 171)
[16:38:23]
[16:38:23] Assembly optimizations on if available.
[16:38:23] Entering M.D.
[16:38:30] Working on p5506_supervillin_e1
[16:38:30] Client config found, loading data.
[16:38:30] Starting GUI Server
[16:38:30] mdrun_gpu returned
[16:38:30] NANs detected on GPU
[16:38:30]
[16:38:30] Folding@home Core Shutdown: UNSTABLE_MACHINE
[16:38:33] CoreStatus = 7A (122)
[16:38:33] Sending work to server
[16:38:33] Project: 5506 (Run 6, Clone 324, Gen 171)
[16:38:33] - Error: Could not get length of results file work/wuresults_00.dat
[16:38:33] - Error: Could not read unit 00 file. Removing from queue.
[16:38:33] - Preparing to get new work unit...
[16:38:33] + Attempting to get work packet
[16:38:33] - Connecting to assignment server
[16:38:34] - Successful: assigned to (171.64.65.106).
[16:38:34] + News From Folding@Home: GPU folding beta
[16:38:34] Loaded queue successfully.
[16:38:35] + Closed connections
[16:38:40]
[16:38:40] + Processing work unit
[16:38:40] Core required: FahCore_11.exe
[16:38:40] Core found.
[16:38:40] Working on queue slot 01 [October 18 16:38:40 UTC]
[16:38:40] + Working ...
[16:38:40]
[16:38:40] *------------------------------*
[16:38:40] Folding@Home GPU Core - Beta
[16:38:40] Version 1.15 (Mon Oct 13 11:11:30 PDT 2008)
[16:38:40]
[16:38:40] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[16:38:40] Build host: amoeba
[16:38:40] Board Type: Nvidia
[16:38:40] Core      :
[16:38:40] Preparing to commence simulation
[16:38:40] - Looking at optimizations...
[16:38:40] - Created dyn
[16:38:40] - Files status OK
[16:38:40] - Expanded 45479 -> 246249 (decompressed 541.4 percent)
[16:38:40] Called DecompressByteArray: compressed_data_size=45479 data_size=246249, decompressed_data_size=246249 diff=0
[16:38:40] - Digital signature verified
[16:38:40]
[16:38:40] Project: 5506 (Run 6, Clone 324, Gen 171)
[16:38:40]
[16:38:40] Assembly optimizations on if available.
[16:38:40] Entering M.D.
[16:38:47] Working on p5506_supervillin_e1
[16:38:47] Client config found, loading data.
[16:38:48] mdrun_gpu returned
[16:38:48] NANs detected on GPU
[16:38:48]
[16:38:48] Folding@home Core Shutdown: UNSTABLE_MACHINE
[16:38:50] CoreStatus = 7A (122)
[16:38:50] Sending work to server
[16:38:50] Project: 5506 (Run 6, Clone 324, Gen 171)
[16:38:50] - Error: Could not get length of results file work/wuresults_01.dat
[16:38:50] - Error: Could not read unit 01 file. Removing from queue.
[16:38:50] - Preparing to get new work unit...
[16:38:50] + Attempting to get work packet
[16:38:50] - Connecting to assignment server
[16:38:51] - Successful: assigned to (171.64.65.106).
[16:38:51] + News From Folding@Home: GPU folding beta
[16:38:51] Loaded queue successfully.
[16:38:52] + Closed connections
[16:38:57]
[16:38:57] + Processing work unit
[16:38:57] Core required: FahCore_11.exe
[16:38:57] Core found.
[16:38:57] Working on queue slot 02 [October 18 16:38:57 UTC]
[16:38:57] + Working ...
[16:38:57]
[16:38:57] *------------------------------*
[16:38:57] Folding@Home GPU Core - Beta
[16:38:57] Version 1.15 (Mon Oct 13 11:11:30 PDT 2008)
[16:38:57]
[16:38:57] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[16:38:57] Build host: amoeba
[16:38:57] Board Type: Nvidia
[16:38:57] Core      :
[16:38:57] Preparing to commence simulation
[16:38:57] - Looking at optimizations...
[16:38:57] - Created dyn
[16:38:57] - Files status OK
[16:38:57] - Expanded 45479 -> 246249 (decompressed 541.4 percent)
[16:38:57] Called DecompressByteArray: compressed_data_size=45479 data_size=246249, decompressed_data_size=246249 diff=0
[16:38:57] - Digital signature verified
[16:38:57]
[16:38:57] Project: 5506 (Run 6, Clone 324, Gen 171)
[16:38:57]
[16:38:57] Assembly optimizations on if available.
[16:38:57] Entering M.D.
[16:39:04] Working on p5506_supervillin_e1
[16:39:04] Client config found, loading data.
[16:39:04] mdrun_gpu returned
[16:39:04] NANs detected on GPU
[16:39:04]
[16:39:04] Folding@home Core Shutdown: UNSTABLE_MACHINE
[16:39:07] CoreStatus = 7A (122)
[16:39:07] Sending work to server
[16:39:07] Project: 5506 (Run 6, Clone 324, Gen 171)
[16:39:07] - Error: Could not get length of results file work/wuresults_02.dat
[16:39:07] - Error: Could not read unit 02 file. Removing from queue.
[16:39:07] EUE limit exceeded. Pausing 24 hours.
Folding@Home Client Shutdown.
Re: Project: 5506 (Run 6, Clone 324, Gen 171) bad wu
There are three other reports for 0 point for this WU ... it looks like a bad one indeed :(
