Project: 5506 (Run 0, Clone 943, Gen 24)
sick willie
Post by sick willie »
This WU does the same thing every time one of my cards try to run it. So far, I've lost about 24 hours of folding time :(
[03:49:03] Board Type: Nvidia
[03:49:03] Core      :
[03:49:03] Preparing to commence simulation
[03:49:03] - Looking at optimizations...
[03:49:03] - Created dyn
[03:49:03] - Files status OK
[03:49:03] - Expanded 45537 -> 246249 (decompressed 540.7 percent)
[03:49:03] Called DecompressByteArray: compressed_data_size=45537 data_size=246249, decompressed_data_size=246249 diff=0
[03:49:03] - Digital signature verified
[03:49:03]
[03:49:03] Project: 5506 (Run 0, Clone 943, Gen 24)
[03:49:03]
[03:49:03] Assembly optimizations on if available.
[03:49:03] Entering M.D.
[03:49:09] Working on p5506_supervillin_e1
[03:49:10] Client config found, loading data.
[03:49:10] Starting GUI Server
[03:49:10] mdrun_gpu returned
[03:49:10] NANs detected on GPU
[03:49:10]
[03:49:10] Folding@home Core Shutdown: INTERRUPTED
[03:49:13] CoreStatus = 66 (102)
[03:49:13] + Shutdown requested by user. Exiting.
Folding@Home Client Shutdown.
Re: Project 5506 (Run 0, Clone 943, Gen 24)
Force a core update to get rid of the INTERRUPTED messsage.
This is a bad WU, there are many reports for 0 credits :(
sick willie
Re: Project: 5506 (Run 0, Clone 943, Gen 24)
Thanks. I just watched the same gpu get this WU 5 times in a row. There should be some workable mechanism to weed these WU's out after a moderate amount of failures.
