Project: 5114 (Run 28, Clone 88, Gen 2) EARLY_UNIT_END
luke.from.italy
Post by luke.from.italy »
hi everyone! i use client version 6.20 (systray) and this unit was not completed and sent back to result server. anyone knows what happened??
(my computer is not overclocked)
this is my log file:
[17:55:39] Folding@Home Gromacs 3.3 Core
[17:55:39] Version 1.93 (July 23, 2008)
[17:55:39]
[17:55:39] Preparing to commence simulation
[17:55:39] - Looking at optimizations...
[17:55:39] - Files status OK
[17:55:41] - Expanded 1164474 -> 6173133 (decompressed 530.1 percent)
[17:55:42]
[17:55:42] Project: 5114 (Run 28, Clone 88, Gen 2)
[17:55:42]
[17:55:43] Assembly optimizations on if available.
[17:55:43] Entering M.D.
[17:55:50] FAH Init
[17:55:50] Checkpoint file:
[17:55:56] (Starting from checkpoint)
[17:55:56] Read checkpoint
[17:55:56] Protein: Calmodulin in water
[17:55:56] Writing local files
[17:55:59] Completed 137684 out of 500000 steps  (27 percent)
[17:56:00] Extra SSE boost OK.
[18:11:33] Writing local files
[18:11:33] Completed 140000 out of 500000 steps  (28 percent)
[18:45:05] Writing local files
[18:45:05] Completed 145000 out of 500000 steps  (29 percent)
[19:18:38] Writing local files
[19:18:39] Completed 150000 out of 500000 steps  (30 percent)
[19:52:11] Writing local files
[19:52:11] Completed 155000 out of 500000 steps  (31 percent)
[22:28:53] Quit 101 - NaN detected: (ener[28])
[22:28:53]
[22:28:53] Simulation instability has been encountered. The run has entered a
[22:28:53]   state from which no further progress can be made.
[22:28:53] This may be the correct result of the simulation, however if you
[22:28:53]   often see other project units terminating early like this
[22:28:53]   too, you may wish to check the stability of your computer (issues
[22:28:53]   such as high temperature, overclocking, etc.).
[22:28:53] Going to send back what have done.
[22:28:53] logfile size: 66691
[22:28:53] - Writing 67241 bytes of core data to disk...
[22:28:53]   ... Done.
[22:28:54]
[22:28:54] Folding@home Core Shutdown: EARLY_UNIT_END
[22:28:58] CoreStatus = 72 (114)
[22:28:58] Sending work to server
[22:28:58] Project: 5114 (Run 28, Clone 88, Gen 2)
Re: project 5114 (run 28, clone 88, gen 2) EARLY_UNIT_END
Someone else completed this WU successfully.
Re: Project: 5114 (Run 28, Clone 88, Gen 2) EARLY_UNIT_END
And NaN errors are typically caused by hardware problems, bad memory, over clocked too much, etc.
luke.from.italy
ok, thank you!
