Project: 2492 (Run 106, Clone 6, Gen 0)
Snyde
Post by Snyde »
Just reporting EUE. First one on this box in a loooong time.
Some other problems with this project?
P4, 3.0GHz, 1 Mb RAM, WINXP
****************snip****************
[20:39:41] Completed 137500 out of 250000 steps  (55)
[20:54:42] Timered checkpoint triggered.
[21:09:43] Timered checkpoint triggered.
[21:24:45] Timered checkpoint triggered.
[21:39:46] Timered checkpoint triggered.
[21:40:42] Writing local files
[21:40:42] Completed 140000 out of 250000 steps  (56)
[21:55:47] Timered checkpoint triggered.
[22:10:49] Timered checkpoint triggered.
[22:25:52] Timered checkpoint triggered.
[22:40:54] Timered checkpoint triggered.
[22:41:06] Writing local files
[22:41:06] Completed 142500 out of 250000 steps  (57)
[22:56:07] Timered checkpoint triggered.
[23:11:09] Timered checkpoint triggered.
[23:26:10] Timered checkpoint triggered.
[23:41:12] Timered checkpoint triggered.
[23:41:30] Writing local files
[23:41:31] Completed 145000 out of 250000 steps  (58)
[23:56:31] Timered checkpoint triggered.
[00:00:58] Quit 101 - Fatal error:
[00:00:58] Step 145803, time 291.606 (ps)  LINCS WARNING
[00:00:58] relative constraint deviation after LINCS:
[00:00:58] max 615497472.000000 (between atoms 18548 and 18549) rms 8088222.000000
[00:00:58]
[00:00:58] Simulation instability has been encountered. The run has entered a
[00:00:58]   state from which no further progress can be made.
[00:00:58] This may be the correct result of the simulation, however if you
[00:00:58]   often see other project units terminating early like this
[00:00:58]   too, you may wish to check the stability of your computer (issues
[00:00:58]   such as high temperature, overclocking, etc.).
[00:00:58] Going to send back what have done.
[00:00:58] logfile size: 56834
[00:00:58] - Writing 57534 bytes of core data to disk...
[00:00:58]   ... Done.
[00:00:59]
[00:00:59] Folding@home Core Shutdown: EARLY_UNIT_END
[00:01:01] CoreStatus = 72 (114)
[00:01:01] Sending work to server
[00:01:01] + Attempting to send results
[00:01:01] - Reading file work/wuresults_02.dat from core
[00:01:01]   (Read 57534 bytes from disk)
[00:01:01] Connecting to http://171.65.103.160:8080/
[00:01:04] Posted data.
[00:01:04] Initial: 0000; - Uploaded at ~19 kB/s
[00:01:04] - Averaged speed for that direction ~41 kB/s
[00:01:04] + Results successfully sent
[00:01:04] Thank you for your contribution to Folding@Home.
Regards- :)
jb
Re: Project: 2492 (Run 106, Clone 6, Gen 0)
Hi Snyde (team 0),
Your WU (P2492 R106 C6 G0) was added to the stats database on 2008-10-16 18:23:41 for 527.8 points of credit.
You're the only one to have reported this WU, but this project is quite unstable (see other reports in this forum).
