Project: 2665 (Run 3, Clone 783, Gen 57)
Datsun 1600
Post by Datsun 1600 »
Another one for the bin.
[11:00:42] + Attempting to send results [October 16 11:00:42 UTC]
[11:03:50] + Results successfully sent
[11:03:50] Thank you for your contribution to Folding@Home.
[11:03:50] + Number of Units Completed: 73
[11:03:51] Using generic mpiexec calls
[11:05:55] - Preparing to get new work unit...
[11:05:55] + Attempting to get work packet
[11:05:55] - Connecting to assignment server
[11:05:58] - Successful: assigned to (171.64.65.64).
[11:05:58] + News From Folding@Home: Welcome to Folding@Home
[11:05:59] Loaded queue successfully.
[11:06:54] + Closed connections
[11:06:54]
[11:06:54] + Processing work unit
[11:06:54] Work type a1 not eligible for variable processors
[11:06:54] Core required: FahCore_a1.exe
[11:06:54] Core found.
[11:06:54] Using generic mpiexec calls
[11:06:54] Working on queue slot 02 [October 16 11:06:54 UTC]
[11:06:54] + Working ...
[11:06:54]
[11:06:54] *------------------------------*
[11:06:54] Folding@Home Gromacs SMP Core
[11:06:54] Version 1.74 (March 10, 2007)
[11:06:54]
[11:06:54] Preparing to commence simulation
[11:06:54] - Ensuring status. Please wait.
[11:06:59] - Starting from initial work packet
[11:06:59]
[11:06:59] Project: 2665 (Run 3, Clone 783, Gen 57)
[11:06:59]
[11:06:59] Assembly optimizations on if available.
[11:06:59] Entering M.D.
[11:07:22]  percent)
[11:07:22] - Starting from initial work packet
[11:07:22]
[11:07:22] Project: 2665 (Run 3, Clone 783, Gen 57)
[11:07:22]
[11:07:23] Entering M.D.
[11:07:29] Rejecting checkpoint
[11:07:31] Protein: HGG in water
[11:07:31] Writing local files
[11:07:38] Extra SSE boost OK.
[11:07:38] Writing local files
[11:07:39] Completed 0 out of 250000 steps  (0 percent)
[11:20:10] Writing local files
[11:20:10] Completed 2500 out of 250000 steps  (1 percent)
[11:20:58] Warning:  long 1-4 interactions
[11:20:59] o delete work/wudata_02.chk
[11:20:59] - Failed to delete work/wud- Failed to delete work/wudata_02.xvg
[11:20:59] Warning:  check for stray files
[11:20:59] tray files
[11:20:59]
[11:20:59] Folding@home Core Shutdown: EARLY_UNIT_END
[11:20:59] Finalizing output
[11:22:59] @home Core Shutdown: EARLY_UNIT_END
[11:23:02] CoreStatus = 7B (123)
[11:23:02] Client-core communications error: ERROR 0x7b
[11:23:02] Deleting current work unit & continuing...
[11:23:02] Using generic mpiexec calls
[11:25:06] - Preparing to get new work unit...
[11:25:06] + Attempting to get work packet
[11:25:06] - Connecting to assignment server
[11:25:10] - Successful: assigned to (171.64.65.64).
[11:25:10] + News From Folding@Home: Welcome to Folding@Home
[11:25:10] Loaded queue successfully.
[11:27:41] + Closed connections
[11:27:46]
[11:27:46] + Processing work unit
[11:27:46] Work type a1 not eligible for variable processors
[11:27:46] Core required: FahCore_a1.exe
[11:27:46] Core found.
[11:27:46] Using generic mpiexec calls
[11:27:46] Working on queue slot 03 [October 16 11:27:46 UTC]
[11:27:46] + Working ...
[11:27:46]
[11:27:46] *------------------------------*
[11:27:46] Folding@Home Gromacs SMP Core
[11:27:46] Version 1.74 (March 10, 2007)
[11:27:46]
[11:27:46] Preparing to commence simulation
[11:27:46] - Ensuring status. Please wait.
[11:27:51] - Starting from initial work packet
[11:27:51]
[11:27:51] Project: 2665 (Run 3, Clone 783, Gen 57)
[11:27:51]
[11:27:51] Assembly optimizations on if available.
[11:27:51] Entering M.D.
[11:28:14]  percent)
[11:28:14] cket
[11:28:14]
[11:28:14] Project: 2665 (Run 3, Clone 783, Gen 57)
[11:28:14]
[11:28:14] 65 (Run 3, Clone 783, Gen 57)
[11:28:14]
[11:28:15] Entering M.D.
[11:28:21] Rejecting checkpoint
[11:28:23] Protein: HGG in water
[11:28:23] Writing local files
[11:28:30] Extra SSE boost OK.
[11:28:30] Writing local files
[11:28:31] Completed 0 out of 250000 steps  (0 percent)
[11:41:02] Writing local files
[11:41:02] Completed 2500 out of 250000 steps  (1 percent)
[11:41:51]  to delete work/wudata_03.arc
[11:41:51] - Failed to delete work/wudata_03.xtc
[11:41:51] ng to send back what have done.
[11:41:51] logfile size: 11376
[11:41:51] - Writing 11912 bytes of core data to disk...
[11:41:51]   ... Done.
[11:41:51] utdown: EARLY_UNIT_END
[11:41:51] Finalizing output
[11:43:51] tdown: EARLY_UNIT_END
[11:43:51]
[11:43:51] Folding@home Core Shutdown: EARLY_UNIT_END
[11:43:54] CoreStatus = 7B (123)
[11:43:54] Client-core communications error: ERROR 0x7b
[11:43:54] Deleting current work unit & continuing...
[11:43:54] Using generic mpiexec calls
[11:45:58] - Preparing to get new work unit...
[11:45:58] + Attempting to get work packet
[11:45:58] - Connecting to assignment server
[11:46:02] - Successful: assigned to (171.64.65.64).
[11:46:02] + News From Folding@Home: Welcome to Folding@Home
[11:46:02] Loaded queue successfully.
[11:47:00] + Closed connections
[11:47:05]
[11:47:05] + Processing work unit
[11:47:05] Work type a1 not eligible for variable processors
[11:47:05] Core required: FahCore_a1.exe
[11:47:05] Core found.
[11:47:05] Using generic mpiexec calls
[11:47:05] Working on queue slot 04 [October 16 11:47:05 UTC]
[11:47:05] + Working ...
[11:47:05]
[11:47:05] *------------------------------*
[11:47:05] Folding@Home Gromacs SMP Core
[11:47:05] Version 1.74 (March 10, 2007)
[11:47:05]
[11:47:05] Preparing to commence simulation
[11:47:05] - Ensuring status. Please wait.
[11:47:09] - Starting from initial work packet
[11:47:09]
[11:47:09] Project: 2665 (Run 3, Clone 783, Gen 57)
[11:47:09]
[11:47:10] Assembly optimizations on if available.
[11:47:10] Entering M.D.
[11:47:32]  percent)
[11:47:32] cket
[11:47:32]
[11:47:32] Project: 2665 (Run 3, Clone 783, Gen 57)
[11:47:32]
[11:47:33] 65 (Run 3, Clone 783, Gen 57)
[11:47:33]
[11:47:34] Entering M.D.
[11:47:40] Rejecting checkpoint
[11:47:41] Protein: HGG in water
[11:47:41] Writing local files
[11:47:49] Extra SSE boost OK.
[11:47:49] Writing local files
[11:47:49] Completed 0 out of 250000 steps  (0 percent)
[12:00:20] Writing local files
[12:00:20] Completed 2500 out of 250000 steps  (1 percent)
[12:01:09] Warning:  long 1-4 interactions
[12:01:09] rk/wudata_04.dyn
[12:01:09] - Failed to delete work/wudata_04.bed
[12:01:09] - Faile- Failed to delete work/wudata_WarningWarning:  check for stray files
[12:01:09]
[12:01:09] Folding@home Core Shutdown: EARLY_UNIT_END
[12:01:09] Finalizing output
[12:01:09] check for stray files
[12:03:09]
[12:03:09] Folding@home Core Shutdown: EARLY_UNIT_END
[12:03:09]
[12:03:13] CoreStatus = 7B (123)
[12:03:13] Client-core communications error: ERROR 0x7b
[12:03:13] - Attempting to download new core...
[12:03:13] + Downloading new core: FahCore_a1.exe
[12:03:18] + 10240 bytes downloaded
[12:03:18] + 20480 bytes downloaded
[12:03:19] + 30720 bytes downloaded
[12:03:28] + 778240 bytes downloaded
[12:03:28] + 788480 bytes downloaded
[12:03:28] + 789667 bytes downloaded
[12:03:28] Verifying core Core_a1.fah...
[12:03:28] Signature is VALID
[12:03:28]
[12:03:28] Trying to unzip core FahCore_a1.exe
[12:03:28] Decompressed FahCore_a1.exe (2035712 bytes) successfully
[12:03:33] + Core successfully engaged
[12:03:33] Deleting current work unit & continuing...
[12:03:33] Using generic mpiexec calls
[12:05:37] - Preparing to get new work unit...
[12:05:37] + Attempting to get work packet
[12:05:37] - Connecting to assignment server
[12:05:42] - Successful: assigned to (171.64.65.64).
[12:05:42] + News From Folding@Home: Welcome to Folding@Home
[12:05:43] Loaded queue successfully.
[12:05:47] - Attempt #1  to get work failed, and no other work to do.
Waiting before retry.
[12:06:02] + Attempting to get work packet
[12:06:02] - Connecting to assignment server
[12:06:02] - Successful: assigned to (171.64.65.64).
[12:06:02] + News From Folding@Home: Welcome to Folding@Home
[12:06:03] Loaded queue successfully.
[12:07:00] + Closed connections
[12:07:05]
[12:07:05] + Processing work unit
[12:07:05] Work type a1 not eligible for variable processors
[12:07:05] Core required: FahCore_a1.exe
[12:07:05] Core found.
[12:07:05] Using generic mpiexec calls
[12:07:05] Working on queue slot 05 [October 16 12:07:05 UTC]
[12:07:05] + Working ...
[12:07:05]
[12:07:05] *------------------------------*
[12:07:05] Folding@Home Gromacs SMP Core
[12:07:05] Version 1.74 (March 10, 2007)
[12:07:05]
[12:07:05] Preparing to commence simulation
[12:07:05] - Ensuring status. Please wait.
[12:07:10] - Starting from initial work packet
[12:07:10]
[12:07:10] Project: 2665 (Run 0, Clone 284, Gen 58)
[12:07:10]
[12:07:10] Assembly optimizations on if available.
[12:07:10] Entering M.D.
[12:07:33]  percent)
[12:07:33] cket
[12:07:33]
[12:07:33] Project: 2665 (Run 0, Clone 284, Gen 58)
[12:07:33]
[12:07:33] 65 (Run 0, Clone 284, Gen 58)
[12:07:33]
[12:07:34] Entering M.D.
[12:07:40] Rejecting checkpoint
[12:07:42] Protein: HGG in water
[12:07:42] Writing local files
[12:07:49] Extra SSE boost OK.
[12:07:50] Writing local files
[12:07:50] Completed 0 out of 250000 steps  (0 percent)
[12:20:23] Writing local files
[12:20:23] Completed 2500 out of 250000 steps  (1 percent)
Re: Project: 2665 (Run 3, Clone 783, Gen 57)
Update your client to 6.23 : it handles EUE better.
There is an other report for partial credit in the DB for this WU.
Datsun 1600
Doesn't matter, the last SMP Boxen gets turned off this weekend, it is not worth the running costs.
