Hi !
I recently misconfigured my client and some units could not be sent to FAH servers.
I have fixed the problem and finally sent the units, but can't find it in my stats.
these units were completed between Dec. 30 and Jan. 4, and were sent between Jan. 4 and Jan. 5
Here are the project references :
Project: 4108 (Run 34, Clone 16, Gen 3)
Project: 2417 (Run 18, Clone 75, Gen 17)
Project: 2621 (Run 43, Clone 46, Gen 4)
Project: 2417 (Run 44, Clone 90, Gen 14)
Project: 4102 (Run 101, Clone 9, Gen 5)
Project: 4107 (Run 35, Clone 19, Gen 6)
Project: 2417 (Run 11, Clone 24, Gen 15)
Project: 2418 (Run 41, Clone 56, Gen 10)
My informations :
[Inpact]_TiTan91
Team : 51
Thanks
Missing points (8 units)
Re: Missing points (8 units)
set the client option for USE IE SETTINGS to NO!
You did receive credit for these WUs, your client just didn't get back an acknowledgement from the servers because of that incorrect setting above. If that setting is already NO, then you have AV or Firewall software doing the same thing. Configure it to accept FAH traffic.
For example...
Hi [Inpact]_TiTan91 (team 51),
Your WU (P4108 R34 C16 G3) was added to the stats database on 2007-12-30 13:06:00 for 164 points of credit.
Your WU (P4108 R34 C16 G3) was added to the stats database on 2007-12-30 19:04:32 for 0 points of credit.
Your WU (P4108 R34 C16 G3) was added to the stats database on 2007-12-31 01:04:22 for 0 points of credit.
For example...
Your WU (P2417 R18 C75 G17) was added to the stats database on 2007-12-31 22:52:02 for 500 points of credit.
Your WU (P2621 R43 C46 G4) was added to the stats database on 2008-01-01 06:59:49 for 292 points of credit.
Your WU (P2417 R44 C90 G14) was added to the stats database on 2008-01-02 18:56:32 for 500 points of credit.
Your WU (P4102 R101 C9 G5) was added to the stats database on 2008-01-04 07:06:04 for 215 points of credit.
Your WU (P4107 R35 C19 G6) was added to the stats database on 2008-01-01 07:04:35 for 215 points of credit.
Your WU (P2417 R11 C24 G15) was added to the stats database on 2008-01-03 06:52:04 for 500 points of credit.
Your WU (P2418 R41 C56 G10) was added to the stats database on 2008-01-04 02:56:22 for 500 points of credit.
7im >
use ie settings was set to "yes", that's why i've had this problem
but i had already changed it to "no" before posting, that's how i finally sent my units
Anyway, thanks for the credit
Hello Titan
- Hardware configuration: Computer 1:
CPU: Intel Q6600@2,4GHz
RAM: 8GB
OS: Windows 7 SP1
Video: EVGA GTX550Ti SC (NVIDIA GeForce GTX550Ti GPU - 1GB GDDR5)
(OC: GPU@981MHz / Shaders@1962 / Memory@4514)
PSU: OCZ StealthXtream 600 Watt
Client 7.4.4
Computer 2:
CPU: AMD AthlonII X4 635 @2.9GHz
RAM: 4GB
OS: Windows Server 2008 R2 SP2
Client 7.4.4, configured as a service
Computer 3:
CPU: Intel Core i7-4790K @4.0GHz
GPU: EVGA GTX980 @1.518GHz
RAM: 32 GB
OS: Windows 7 SP1
Client 7.4.4
Computer 4:
CPU: Intel Core i5 M560 @2,67GHz
RAM: 4 GB
OS: Windows 7 Enterprise
Client: Win-SMP2
Computer 5:
CPU: Intel Core i3 4370 @3.8GHz
RAM: 8GB
OS: Windows 7 SP1
Client 7.4.4 configured as a service - Location: Netherlands
Where would I find these figures? Are they in a logfile somewhere, or on a website?7im wrote: For example...
I seem to be missing some points for an SMP-WU, but I'm not sure. So I'd like to check this.
Corné
You can't. They're in a Stanford database that only forum Moderators and the Pande Group have access to. You have to give us the Project / Run / Clone / Gen numbers so we can look them up for you.CBT wrote:Where would I find these figures? Are they in a logfile somewhere, or on a website?![]()
