Project: 2665 (Run 3, Clone 613, Gen 55)
lobuxracer
Post by lobuxracer »
Any special reason this WU would get downloaded 14 times in a row and fail every single time at 92%? I'm OK with an EUE, I'm not OK with 14 times in a row on the same machine, and the machine going to sleep for 24 hours. This machine has been consistently producing for more than a year, and it has two FAH SMP instances running concurrently. The other instance is unaffected.
Re: Project: 2665 (Run 3, Clone 613, Gen 55)
Update your client to v6.23, it has better EUE handling and this shouldn't happen.
There is no data in the DB for this WU yet.
lobuxracer
Where can I find v6.23? I'm currently running 6.22 Beta2R3.
anandhanju
Post by anandhanju »
Here: viewtopic.php?f=46&t=6143
Do post your observations (better/ worse/ no change in EUE handling)
lobuxracer
Updated a laptop running a WU it has previously EUE'd a few times. I'll update what it does. After reading the thread, not quite sure if I want to update the other 6 SMP clients I have running just yet.
