Project: 2665 (Run 0, Clone 429, Gen 47)
Grzesiek
Post by Grzesiek »
[14:26:55] Completed 0 out of 250000 steps  (0 percent)
[14:41:50] Warning:  long 1-4 interactions
[14:41:51] - Writing 9958 bytes of core data to disk...
[14:41:51]   ... Done.
[14:41:51] - Failed to delete work/wudata_04.arc
[14:41:51] - Failed to delete work/wudata_04.sas
[14:41:51] - Failed to- Failed to delete work/wudata_04.sas
[14:41:51] Folding@home Core Shutdown: EARLY_UNIT_END
[14:41:51] Finalizing output
[14:43:51]  Core Shutdown: EARLY_UNIT_END
[14:43:51]
[14:43:51] Folding@home Core Shutdown: EARLY_UNIT_END
[14:43:54] CoreStatus = 7B (123)
[14:43:54] Client-core communications error: ERROR 0x7b
[14:43:54] Deleting current work unit & continuing...
4 times in a row, after which the client deleted, redownloaded and restarted fahcore_a1.exe with new a new WU (Project: 2665 (Run 0, Clone 984, Gen 58; seems to be running fine so far)
Grzesiek
anandhanju
Re: Project: 2665 (Run 0, Clone 429, Gen 47)
Post by anandhanju »
Have you tried using the new client? Some say it has better EUE handling capabilites and if it can be bothered, will find aliens in 3.6 hours.
There is another report in the stat DB for partial credit.
