Project: 5506 (Run 5, Clone 53, Gen 104)
Oldhat
Post by Oldhat »
Hi,
Just got an EUE on this project number without it even apparently starting. I am still running Version 1.09, but this is the first EUE that I have noted on this computer.
Specs are Windows XP SP3 C2D e2160 @ stock 1024Mb RAM P965 DS3 running two 8800GS GPU Clients.
[12:01:03] + Attempting to send results [October 13 12:01:03 UTC]
[12:01:18] + Results successfully sent
[12:01:18] Thank you for your contribution to Folding@Home.
[12:01:18] + Number of Units Completed: 485
[12:01:22] - Preparing to get new work unit...
[12:01:22] + Attempting to get work packet
[12:01:22] - Connecting to assignment server
[12:01:22] - Successful: assigned to (171.64.65.106).
[12:01:22] + News From Folding@Home: GPU folding beta
[12:01:23] Loaded queue successfully.
[12:01:24] + Closed connections
[12:01:24]
[12:01:24] + Processing work unit
[12:01:24] Core required: FahCore_11.exe
[12:01:24] Core found.
[12:01:24] Working on queue slot 00 [October 13 12:01:24 UTC]
[12:01:24] + Working ...
[12:01:24]
[12:01:24] *------------------------------*
[12:01:24] Folding@Home GPU Core - Beta
[12:01:24] Version 1.09 (Fri Aug 1 11:46:54 PDT 2008)
[12:01:24]
[12:01:24] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[12:01:24] Build host: amoeba
[12:01:24] Board Type: Nvidia
[12:01:24] Core      :
[12:01:24] Preparing to commence simulation
[12:01:24] - Looking at optimizations...
[12:01:24] - Created dyn
[12:01:24] - Files status OK
[12:01:24] - Expanded 45613 -> 246249 (decompressed 539.8 percent)
[12:01:24] Called DecompressByteArray: compressed_data_size=45613 data_size=246249, decompressed_data_size=246249 diff=0
[12:01:24] - Digital signature verified
[12:01:24]
[12:01:24] Project: 5506 (Run 5, Clone 53, Gen 104)
[12:01:24]
[12:01:24] Assembly optimizations on if available.
[12:01:24] Entering M.D.
[12:01:31] Working on p5506_supervillin_e1
[12:01:31] Client config found, loading data.
[12:01:31] Starting GUI Server
[12:01:32] mdrun_gpu returned -1
[12:01:32] Going to send back what have done.
[12:01:33] logfile size: 10893 info=10893 bed=0 hdr=25
[12:01:33] - Writing 11431 bytes of core data to disk...
[12:01:33]   ... Done.
[12:01:33]
[12:01:33] Folding@home Core Shutdown: EARLY_UNIT_END
[12:01:37] CoreStatus = 72 (114)
[12:01:37] Sending work to server
[12:01:37] Project: 5506 (Run 5, Clone 53, Gen 104)
[12:01:37] - Read packet limit of 540015616... Set to 524286976.
[12:01:37] + Attempting to send results [October 13 12:01:37 UTC]
[12:01:38] + Results successfully sent
[12:01:38] Thank you for your contribution to Folding@Home.
[12:01:42] - Preparing to get new work unit...
[12:01:42] + Attempting to get work packet
[12:01:42] - Connecting to assignment server
[12:01:42] - Successful: assigned to (171.64.65.106).
[12:01:42] + News From Folding@Home: GPU folding beta
[12:01:42] Loaded queue successfully.
[12:01:44] + Closed connections
[12:01:49]
Cheers
Re: Project: 5506 (Run 5, Clone 53, Gen 104)
Thanks for the report : this is a bad WU. There is multiple reports in the DB for 0 points, so no one was able to start it :(
Oldhat
Post by Oldhat »
Thanks for the heads up, toTOW. :)
It isn't to much of a problem now with the much improved error handling in the latest clients.
Cheers
