Project: 5506 (Run 2, Clone 943, Gen 68)
Torin3
Post by Torin3 »
Looks like I've got another one, different error this time though:
--- Opening Log file [October 12 05:22:56 UTC]
                       Folding@Home Client Version 6.20
                          http://folding.stanford.edu
Launch directory: C:\GPU1
Arguments: -gpu 0 -verbosity 9 -local
[05:22:56] - Ask before connecting: No
[05:22:56] - User name: Torin3 (Team 32)
[05:22:56] - User ID: 610619B278E19D0F
[05:22:56] - Machine ID: 6
[05:22:56]
[05:22:56] Loaded queue successfully.
[05:22:57] Initialization complete
[05:22:57] - Autosending finished units... [October 12 05:22:57 UTC]
[05:22:57] Trying to send all finished work units
[05:22:57]
[05:22:57] + No unsent completed units remaining.
[05:22:57] + Processing work unit
[05:22:57] - Autosend completed
[05:22:57] Core required: FahCore_11.exe
[05:22:57] Core found.
[05:22:57] Working on queue slot 03 [October 12 05:22:57 UTC]
[05:22:57] + Working ...
[05:22:57] - Calling '.\FahCore_11.exe -dir work/ -suffix 03 -priority 96 -nocpulock -checkpoint 15 -verbose -lifeline 3792 -version 620'
[05:22:57]
[05:22:57] *------------------------------*
[05:22:57] Folding@Home GPU Core - Beta
[05:22:57] Version 1.13 (Mon Sep 29 12:58:49 PDT 2008)
[05:22:57]
[05:22:57] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[05:22:57] Build host: amoeba
[05:22:57] Board Type: Nvidia
[05:22:57] Core      :
[05:22:57] Preparing to commence simulation
[05:22:57] - Looking at optimizations...
[05:22:57] - Files status OK
[05:22:57] - Expanded 42227 -> 246249 (decompressed 583.1 percent)
[05:22:57] Called DecompressByteArray: compressed_data_size=42227 data_size=246249, decompressed_data_size=246249 diff=0
[05:22:57] - Digital signature verified
[05:22:57]
[05:22:57] Project: 5506 (Run 2, Clone 943, Gen 68)
[05:22:57]
[05:22:57] Assembly optimizations on if available.
[05:22:57] Entering M.D.
[05:23:03] Working on p5506_supervillin_e1
[05:23:04] Client config found, loading data.
[05:23:04] mdrun_gpu returned
[05:23:04] SHAKE violations on GPU
[05:23:04]
[05:23:04] Folding@home Core Shutdown: INTERRUPTED
[05:23:07] CoreStatus = 66 (102)
[05:23:07] + Shutdown requested by user. Exiting.***** Got a SIGTERM signal (2)
[05:23:07] Killing all core threads
Folding@Home Client Shutdown.
--- Opening Log file [October 12 05:25:06 UTC]
[05:25:06] - Ask before connecting: No
[05:25:06] - User name: Torin3 (Team 32)
[05:25:06] - User ID: 610619B278E19D0F
[05:25:06] - Machine ID: 6
[05:25:06]
[05:25:07] Loaded queue successfully.
[05:25:07] Initialization complete
[05:25:07]
[05:25:07] + Processing work unit
[05:25:07] - Autosending finished units... [October 12 05:25:07 UTC]
[05:25:07] Trying to send all finished work units
[05:25:07] + No unsent completed units remaining.
[05:25:07] - Autosend completed
[05:25:07] Core required: FahCore_11.exe
[05:25:07] Core found.
[05:25:07] Working on queue slot 03 [October 12 05:25:07 UTC]
[05:25:07] + Working ...
[05:25:07] - Calling '.\FahCore_11.exe -dir work/ -suffix 03 -priority 96 -nocpulock -checkpoint 15 -verbose -lifeline 4920 -version 620'
[05:25:07]
[05:25:07] *------------------------------*
[05:25:07] Folding@Home GPU Core - Beta
[05:25:07] Version 1.13 (Mon Sep 29 12:58:49 PDT 2008)
[05:25:07]
[05:25:07] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[05:25:07] Build host: amoeba
[05:25:07] Board Type: Nvidia
[05:25:07] Core      :
[05:25:07] Preparing to commence simulation
[05:25:07] - Looking at optimizations...
[05:25:07] - Files status OK
[05:25:07] - Expanded 42227 -> 246249 (decompressed 583.1 percent)
[05:25:07] Called DecompressByteArray: compressed_data_size=42227 data_size=246249, decompressed_data_size=246249 diff=0
[05:25:07] - Digital signature verified
[05:25:07]
[05:25:07] Project: 5506 (Run 2, Clone 943, Gen 68)
[05:25:07]
[05:25:07] Assembly optimizations on if available.
[05:25:07] Entering M.D.
[05:25:13] Working on p5506_supervillin_e1
[05:25:14] Client config found, loading data.
[05:25:14] mdrun_gpu returned
[05:25:14] SHAKE violations on GPU
[05:25:14]
[05:25:14] Folding@home Core Shutdown: INTERRUPTED
[05:25:17] CoreStatus = 66 (102)
[05:25:17] + Shutdown requested by user. Exiting.***** Got a SIGTERM signal (2)
[05:25:17] Killing all core threads
Re: Project: 5506 (Run 2, Clone 943, Gen 68)
This is a bad WU too ... many reports for 0 credit in the DB :(
