Project: 2665 (Run 3, Clone 689, Gen 46)
ei57
Post by ei57 »
Got EUE 3 times on this WU. EUE'ed almost before it started on every attempt.
Have been assigned a new non-2665 WU now that works just fine. Seems like WU's other than 2665 are less likely to EUE.
[19:39:41] Project: 2665 (Run 3, Clone 689, Gen 46)
[19:39:41]
[19:39:43] Entering M.D.
[19:39:49] Rejecting checkpoint
[19:39:51] NaN detected: x[23838][2]=5.39614 v[23838][2]=NaN
[19:39:51] utdown: BAD_CORE_FILES
[19:39:51] Finalizing output
[19:41:51] ES
[19:41:51]
[19:41:51] Folding@home Core Shutdown: BAD_CORE_FILES
[19:41:52] aN
[19:41:52]
[19:41:52] Folding@home Core Shutdown: BAD_CORE_FILES
[19:41:52] Finalizing output
[19:43:56] CoreStatus = 1 (1)
[19:43:56] Client-core communications error: ERROR 0x1
[19:43:56] Deleting current work unit & continuing...
Re: Project: 2665 (Run 3, Clone 689, Gen 46)
There is 4 reports for 0 points un the DB, this is a bad WU :(
You should upgrade your client to v6.23 which should improve the EUE handling ;)
