CPU Usage
SCARFACE12
CPU Usage
Post by SCARFACE12 »
I run F@H 24/7 on my computer and I always have it turned up so that it takes all my cpu usage. I was wondering if thats going to f^ my pc?
sneakers55
Re: CPU Usage
Post by sneakers55 »
SCARFACE12 wrote:I run F@H 24/7 on my computer and I always have it turned up so that it takes all my cpu usage.
Any mechanical/electronic device has a finite lifespan but computers obsolete themselves so rapidly you'll be wanting to upgrade before it wears out.
AMD Athlon X2 Dual Core 4200+ (2.2 GHz)
Intel C2D 6400 (2.13 GHz)
Intel C2D T7800 (2.6 GHz)
PS3
Re: CPU Usage
Heat is the biggest enemy. With proper cooling, and regular cleaning of the heatsinks, etc., the above statement is very true, even when overclocking and pushing the system that much harder.
SCARFACE12
Re: CPU Usage
Ok thank you for your help!
v00d00
Hardware configuration: FX8320e (6 cores enabled) @ stock,
- 16GB DDR3,
- Zotac GTX 1050Ti @ Stock.
- Gigabyte GTX 970 @ Stock
Debian 9.
Ran Seti@Home prior to that.
Re: CPU Usage
Post by v00d00 »
But in reality you will probably be a fair bit older when it dies.
I base the above on the fact i have a Intel Pentium 133 still running that is now about 10 years old. I have hard drives that are even older. I even have a working 80286 from back in the day that still happily boots MSDOS 5.
Given decent cooling, your cpu/hard drive/gpu/etc... should last until you next upgrade.
