Project: 2665 (Run 0, Clone 652, Gen 51)
Datsun 1600
Post by Datsun 1600 »
I know these are nearly over but here is one to take out of the mix, give me the p2653s or 3000 series, I have had a gutfull of these underscored WUs. Only running 1 SMP comp now, but I can easily turn it off.
Datsun 1600
[19:18:50] + Attempting to send results [October 8 19:18:50 UTC]
[19:22:00] + Results successfully sent
[19:22:00] Thank you for your contribution to Folding@Home.
[19:22:00] + Number of Units Completed: 64
[19:22:01] Using generic mpiexec calls
[19:24:05] - Preparing to get new work unit...
[19:24:05] + Attempting to get work packet
[19:24:05] - Connecting to assignment server
[19:24:09] - Successful: assigned to (171.64.65.64).
[19:24:09] + News From Folding@Home: Welcome to Folding@Home
[19:24:09] Loaded queue successfully.
[19:25:06] + Closed connections
[19:25:06]
[19:25:06] + Processing work unit
[19:25:06] Work type a1 not eligible for variable processors
[19:25:06] Core required: FahCore_a1.exe
[19:25:06] Core found.
[19:25:06] Using generic mpiexec calls
[19:25:06] Working on queue slot 00 [October 8 19:25:06 UTC]
[19:25:06] + Working ...
[19:25:06]
[19:25:06] *------------------------------*
[19:25:06] Folding@Home Gromacs SMP Core
[19:25:06] Version 1.74 (March 10, 2007)
[19:25:06]
[19:25:06] Preparing to commence simulation
[19:25:06] - Ensuring status. Please wait.
[19:25:10] - Starting from initial work packet
[19:25:10]
[19:25:10] Project: 2665 (Run 0, Clone 652, Gen 51)
[19:25:10]
[19:25:11] Assembly optimizations on if available.
[19:25:11] Entering M.D.
[19:25:33]  percent)
[19:25:33] - Starting from initial work packet
[19:25:33]
[19:25:33] Project: 2665 (Run 0, Clone 652, Gen 51)
[19:25:33]
[19:25:35] Entering M.D.
[19:25:41] Rejecting checkpoint
[19:25:42] Protein: HGG in water
[19:25:42] Writing local files
[19:25:50] Extra SSE boost OK.
[19:25:50] Writing local files
[19:25:50] Completed 0 out of 250000 steps  (0 percent)
[19:38:25] Writing local files
[19:38:26] Completed 2500 out of 250000 steps  (1 percent)
[19:51:00] Writing local files
[19:51:00] Completed 5000 out of 250000 steps  (2 percent)
[20:03:34] Writing local files
[20:03:35] Completed 7500 out of 250000 steps  (3 percent)
[20:16:08] Writing local files
[20:16:08] Completed 10000 out of 250000 steps  (4 percent)
[20:28:42] Writing local files
[20:28:42] Completed 12500 out of 250000 steps  (5 percent)
[20:41:17] Writing local files
[20:41:17] Completed 15000 out of 250000 steps  (6 percent)
[20:53:52] Writing local files
[20:53:53] Completed 17500 out of 250000 steps  (7 percent)
[21:06:28] Writing local files
[21:06:28] Completed 20000 out of 250000 steps  (8 percent)
[21:19:04] Writing local files
[21:19:04] Completed 22500 out of 250000 steps  (9 percent)
[21:30:55] Warning:  long 1-4 interactions
[21:30:55] Quit 101 - NaN detected: (ener[20])
[21:30:55]
[21:30:55] Simulation instability has been encountered. The run has entered a
[21:30:55]   state from which no further progress can be made.
[21:30:55] This may be the correct result of the simulation, however if you
[21:30:55]   often see other project units terminating early like this
[21:30:55]   too, you may wish to check the stability of your computer (issues
[21:30:55]   such as high temperature, overclocking, etc.).
[21:30:55] Going to send back what have done.
[21:30:55] logfile size: 26307
[21:30:55] - Writing 26857 bytes of core data to disk...
[21:30:55]   ... Done.
[21:30:55] - Failed to delete work/wudata_00.arc
[21:30:55] No C.P. to delete.
[21:30:55] - Failed to delete work/wudata_00.dyn
[21:30:55] - Failed to delete work/wudata_00.chk
[21:30:55] - Failed to delete work/wudata_00.pdo
[21:30:55] Warning:  check for stray files
[21:32:55]
[21:32:55] Folding@home Core Shutdown: EARLY_UNIT_END
[21:32:55]
[21:33:00] CoreStatus = 7B (123)
[21:33:00] Client-core communications error: ERROR 0x7b
[21:33:00] Deleting current work unit & continuing...
[21:33:00] Using generic mpiexec calls
[21:35:04] - Preparing to get new work unit...
[21:35:04] + Attempting to get work packet
[21:35:04] - Connecting to assignment server
[21:35:12] - Successful: assigned to (171.64.65.64).
[21:35:12] + News From Folding@Home: Welcome to Folding@Home
[21:35:12] Loaded queue successfully.
[21:36:17] + Closed connections
[21:36:22]
[21:36:22] + Processing work unit
[21:36:22] Work type a1 not eligible for variable processors
[21:36:22] Core required: FahCore_a1.exe
[21:36:22] Core found.
[21:36:22] Using generic mpiexec calls
[21:36:22] Working on queue slot 01 [October 8 21:36:22 UTC]
[21:36:22] + Working ...
[21:36:22]
[21:36:22] *------------------------------*
[21:36:22] Folding@Home Gromacs SMP Core
[21:36:22] Version 1.74 (March 10, 2007)
[21:36:22]
[21:36:22] Preparing to commence simulation
[21:36:22] - Ensuring status. Please wait.
[21:36:26] - Starting from initial work packet
[21:36:26]
[21:36:26] Project: 2665 (Run 0, Clone 652, Gen 51)
[21:36:26]
[21:36:27] Assembly optimizations on if available.
[21:36:27] Entering M.D.
[21:36:49]  percent)
[21:36:49] - Starting from initial work packet
[21:36:49]
[21:36:49] Project: 2665 (Run 0, Clone 652, Gen 51)
[21:36:49]
[21:36:51] Entering M.D.
[21:36:57] Rejecting checkpoint
[21:36:59] Protein: HGG in water
[21:36:59] Writing local files
[21:37:06] Extra SSE boost OK.
[21:37:06] Writing local files
[21:37:07] Completed 0 out of 250000 steps  (0 percent)
[21:49:41] Writing local files
[21:49:41] Completed 2500 out of 250000 steps  (1 percent)
[22:02:16] Writing local files
[22:02:16] Completed 5000 out of 250000 steps  (2 percent)
[22:14:49] Writing local files
[22:14:50] Completed 7500 out of 250000 steps  (3 percent)
[22:27:23] Writing local files
[22:27:23] Completed 10000 out of 250000 steps  (4 percent)
[22:39:57] Writing local files
[22:39:57] Completed 12500 out of 250000 steps  (5 percent)
[22:52:31] Writing local files
[22:52:31] Completed 15000 out of 250000 steps  (6 percent)
[23:05:06] Writing local files
[23:05:06] Completed 17500 out of 250000 steps  (7 percent)
[23:17:41] Writing local files
[23:17:42] Completed 20000 out of 250000 steps  (8 percent)
[23:30:17] Writing local files
[23:30:17] Completed 22500 out of 250000 steps  (9 percent)
[23:42:08] Warning:  long 1-4 interactions
[23:42:08] Quit 101 - NaN detected: (ener[20])
[23:42:08]
[23:42:08] Simulation instability has been encountered. The run has entered a
[23:42:08]   state from which no further progress can be made.
[23:42:08] This may be the correct result of the simulation, however if you
[23:42:08]   often see other project units terminating early like this
[23:42:08]   too, you may wish to check the stability of your computer (issues
[23:42:08]   such as high temperature, overclocking, etc.).
[23:42:08] Going to send back what have done.
[23:42:08] logfile size: 26307
[23:42:08] - Writing 26857 bytes of core data to disk...
[23:42:08]   ... Done.
[23:42:08] - Failed to delete work/wudata_01.arc
[23:42:08] - Failed to delete work/wudata_01.xtc
[23:42:08] No C.P. to delete.
[23:42:08] - Failed to delete work/wudata_01.dyn
[23:42:08] - Failed to delete work/wudata_01.pdo
[23:42:08] - Failed to delete work/wudata_01.xvg
[23:42:08] Warning:  check for stray files
[23:44:08]
[23:44:08] Folding@home Core Shutdown: EARLY_UNIT_END
[23:44:08]
[23:44:12] CoreStatus = 7B (123)
[23:44:12] Client-core communications error: ERROR 0x7b
[23:44:12] Deleting current work unit & continuing...
[23:44:12] Using generic mpiexec calls
[23:46:16] - Preparing to get new work unit...
[23:46:16] + Attempting to get work packet
[23:46:16] - Connecting to assignment server
[23:46:20] - Successful: assigned to (171.64.65.64).
[23:46:20] + News From Folding@Home: Welcome to Folding@Home
[23:46:20] Loaded queue successfully.
[23:47:23] + Closed connections
[23:47:28]
[23:47:28] + Processing work unit
[23:47:28] Work type a1 not eligible for variable processors
[23:47:28] Core required: FahCore_a1.exe
[23:47:28] Core found.
[23:47:28] Using generic mpiexec calls
[23:47:28] Working on queue slot 02 [October 8 23:47:28 UTC]
[23:47:28] + Working ...
[23:47:28]
[23:47:28] *------------------------------*
[23:47:28] Folding@Home Gromacs SMP Core
[23:47:28] Version 1.74 (March 10, 2007)
[23:47:28]
[23:47:28] Preparing to commence simulation
[23:47:28] - Ensuring status. Please wait.
[23:47:32] - Starting from initial work packet
[23:47:32]
[23:47:32] Project: 2665 (Run 0, Clone 652, Gen 51)
[23:47:32]
[23:47:33] Assembly optimizations on if available.
[23:47:33] Entering M.D.
[23:47:55]  percent)
[23:47:55] - Starting from initial work packet
[23:47:55]
[23:47:55] Project: 2665 (Run 0, Clone 652, Gen 51)
[23:47:55]
[23:47:57] Entering M.D.
[23:48:03] Rejecting checkpoint
[23:48:04] Protein: HGG in water
[23:48:04] Writing local files
[23:48:12] Extra SSE boost OK.
[23:48:12] Writing local files
[23:48:12] Completed 0 out of 250000 steps  (0 percent)
[00:00:47] Writing local files
[00:00:48] Completed 2500 out of 250000 steps  (1 percent)
[00:13:22] Writing local files
[00:13:22] Completed 5000 out of 250000 steps  (2 percent)
[00:25:56] Writing local files
[00:25:56] Completed 7500 out of 250000 steps  (3 percent)
[00:38:30] Writing local files
[00:38:30] Completed 10000 out of 250000 steps  (4 percent)
[00:51:04] Writing local files
[00:51:04] Completed 12500 out of 250000 steps  (5 percent)
[01:03:39] Writing local files
[01:03:39] Completed 15000 out of 250000 steps  (6 percent)
[01:16:14] Writing local files
[01:16:15] Completed 17500 out of 250000 steps  (7 percent)
[01:28:50] Writing local files
[01:28:50] Completed 20000 out of 250000 steps  (8 percent)
[01:41:26] Writing local files
[01:41:26] Completed 22500 out of 250000 steps  (9 percent)
[01:53:17] Warning:  long 1-4 interactions
[01:53:18] for stray files
[01:53:18]  files
[01:53:18]
[01:53:18] Folding@home Core Shutdown: EARLY_UNIT_END
[01:53:18] Finalizing output
[01:53:18]  run has entered a
[01:53:18]   state from which no further progress can be made.
[01:53:18] This may be the correct result of the simulation, however if you
[01:53:18]   often see other project units terminating early like this
[01:53:18]   too, you may wish to check the stability of your computer (issues
[01:53:18]   such as high temperature, overclocking, etc.).
[01:53:18] Going to send back what have done.
[01:53:18] logfile size: 26307
[01:53:18] - Writing 26857 bytes of core data to disk...
[01:53:18]   ... Done.
[01:55:18]
[01:55:18] Folding@home Core Shutdown: EARLY_UNIT_END
[01:55:18]
[01:55:22] CoreStatus = 7B (123)
[01:55:22] Client-core communications error: ERROR 0x7b
[01:55:22] - Attempting to download new core...
[01:55:22] + Downloading new core: FahCore_a1.exe
[01:55:26] + 10240 bytes downloaded
[01:55:26] + 20480 bytes downloaded
[01:55:26] + 30720 bytes downloaded
[01:55:35] + 788480 bytes downloaded
[01:55:35] + 789667 bytes downloaded
[01:55:35] Verifying core Core_a1.fah...
[01:55:35] Signature is VALID
[01:55:35]
[01:55:35] Trying to unzip core FahCore_a1.exe
[01:55:36] Decompressed FahCore_a1.exe (2035712 bytes) successfully
[01:55:41] + Core successfully engaged
[01:55:41] Deleting current work unit & continuing...
[01:55:41] Using generic mpiexec calls
[01:57:45] - Preparing to get new work unit...
[01:57:45] + Attempting to get work packet
[01:57:45] - Connecting to assignment server
[01:57:48] - Successful: assigned to (171.64.65.64).
[01:57:48] + News From Folding@Home: Welcome to Folding@Home
[01:57:48] Loaded queue successfully.
[01:57:53] - Attempt #1  to get work failed, and no other work to do.
Waiting before retry.
[01:58:06] + Attempting to get work packet
[01:58:06] - Connecting to assignment server
[01:58:06] - Successful: assigned to (171.64.65.64).
[01:58:06] + News From Folding@Home: Welcome to Folding@Home
[01:58:07] Loaded queue successfully.
[01:59:05] + Closed connections
[01:59:10]
[01:59:10] + Processing work unit
[01:59:10] Work type a1 not eligible for variable processors
[01:59:10] Core required: FahCore_a1.exe
[01:59:10] Core found.
[01:59:10] Using generic mpiexec calls
[01:59:10] Working on queue slot 03 [October 9 01:59:10 UTC]
[01:59:10] + Working ...
[01:59:10]
[01:59:10] *------------------------------*
[01:59:10] Folding@Home Gromacs SMP Core
[01:59:10] Version 1.74 (March 10, 2007)
[01:59:10]
[01:59:10] Preparing to commence simulation
[01:59:10] - Ensuring status. Please wait.
[01:59:15] - Starting from initial work packet
[01:59:15]
[01:59:15] Project: 2665 (Run 3, Clone 877, Gen 56)
[01:59:15]
[01:59:15] Assembly optimizations on if available.
[01:59:15] Entering M.D.
[01:59:38]  percent)
[01:59:38] cket
[01:59:38]
[01:59:38] Project: 2665 (Run 3, Clone 877, Gen 56)
[01:59:38]
[01:59:38] 65 (Run 3, Clone 877, Gen 56)
[01:59:38]
[01:59:39] Entering M.D.
[01:59:45] Rejecting checkpoint
[01:59:47] Protein: HGG in water
[01:59:47] Writing local files
[01:59:54] Extra SSE boost OK.
[01:59:55] Writing local files
[01:59:55] Completed 0 out of 250000 steps  (0 percent)
Re: Project: 2665 (Run 0, Clone 652, Gen 51)
There is a report for patial credit for this WU in the DB.
Have you submitted your partial result with qfix viewtopic.php?f=19&t=6042 ?
