SQL error while using the search function.
Locked
I just ran into this error while using the search function :
Erreur générale
SQL ERROR [ mysql4 ]
Server shutdown in progress [1053]
Une erreur SQL est arrivée en chargeant cette page. Contactez l’administrateur du forum si ce problème persiste.
I reposted my search request, and it worked well ... maybe a temporary error, but I wanted to let you know about that.
uncle_fungus
Re: SQL error while using the search function.
Post by uncle_fungus »
Every-so-often the SQL database service gets restarted on the server, and you probably hit the search button just as that was happening.
Locked
