Project: 2665 (Run 3, Clone 415, Gen 46)
arhughes
Post by arhughes »
This unit has failed twice for me, both at 71% with the same error message
[10:06:40] Completed 175000 out of 250000 steps  (70 percent)
[10:21:40] Timered checkpoint triggered.
[10:24:53] Writing local files
[10:24:54] Completed 177500 out of 250000 steps  (71 percent)
[10:39:54] Timered checkpoint triggered.
[10:42:56] Warning:  long 1-4 interactions
[10:42:56] Gromacs cannot continue further.
[10:42:56] Going to send back what have done.
[10:42:56] logfile size: 143505
[10:42:56] - Writing 144041 bytes of core data to disk...
[10:42:56]   ... Done.
[10:42:56] - Failed to delete work/wudata_01.sas
[10:42:56] - Failed to delete work/wudata_01.goe
[10:42:56] Warning:  check for stray files
[10:44:56]
[10:44:56] Folding@home Core Shutdown: EARLY_UNIT_END
[10:44:56]
[10:44:59] CoreStatus = 7B (123)
[10:44:59] Client-core communications error: ERROR 0x7b
[10:44:59] This is a sign of more serious problems, shutting down.
Re: Project: 2665 (Run 3, Clone 415, Gen 46)
There is no reports for this WU in the stat DB yet.
Use qfix to submit partial results and move to another WU : viewtopic.php?f=19&t=6042
You also need to update your client with latest version to avoid the "shutting down" issue : viewtopic.php?f=46&t=4913
arhughes
Post by arhughes »
I tried running qfix and sending in the result but I got this error:
[13:20:45] Project: 0 (Run 0, Clone 0, Gen 0)
[13:20:45] - Warning: Asked to send unfinished unit to server
[13:20:45] - Failed to send unit 00 to server
I ended up uninstalling FAH and reinstalling it, and it downloaded a different WU.
