[18:58:02] Project: 2665 (Run 3, Clone 827, Gen 25)
[18:58:02]
[18:58:03] Assembly optimizations on if available.
[18:58:03] Entering M.D.
[18:58:10] Rejecting checkpoint
[18:58:11] Protein: HGG in water
[18:58:11] Writing local files
[18:58:19] Extra SSE boost OK.
[18:58:20] Writing local files
[18:58:20] Completed 0 out of 250000 steps  (0 percent)
[19:04:56]
[19:04:56] - Writing 9958 bytes of core data to disk...
[19:04:56]   ... Done.
[19:04:56] ave done.
[19:04:56] logfile size: 9422
[19:04:57] o delete work/wudata_08.sas
[19:04:57] - Failed to delete work/wudata_08.goe
[19:04:57] Warning:  check for stray files
[19:04:57]
[19:04:57] Folding@home Core Shutdown: EARLY_UNIT_END
[19:04:57] Finalizing output
[19:04:57] ata_08.goe
[19:04:57] - Failed to delete work/wudata_08.pdo
[19:04:57] - Failed to delete work/wudata_08.xvg
[19:06:57]
[19:06:57] Folding@home Core Shutdown: EARLY_UNIT_END
[19:06:57]
[19:07:00] CoreStatus = 7B (123)
[19:07:00] Client-core communications error: ERROR 0x7b
[19:07:00] Deleting current work unit & continuing...
[19:07:00] Using generic mpiexec calls
[19:09:20] - Warning: Could not delete all work unit files (8): Core returned invalid code
[19:09:20] Trying to send all finished work units
[19:09:20] + No unsent completed units remaining.
[19:09:20] - Preparing to get new work unit...
[19:09:20] + Attempting to get work packet
[19:09:20] - Will indicate memory of 2046 MB
[19:09:20] - Connecting to assignment server
[19:09:20] Connecting to http://assign.stanford.edu:8080/
[19:09:21] Posted data.
[19:09:21] Initial: 40AB; - Successful: assigned to (171.64.65.64).
[19:09:21] + News From Folding@Home: Welcome to Folding@Home
[19:09:21] Loaded queue successfully.
[19:09:21] Connecting to http://171.64.65.64:8080/
[19:09:26] Posted data.
[19:09:26] Initial: 0000; - Receiving payload (expected size: 4746478)
[19:09:36] - Downloaded at ~463 kB/s
[19:09:36] - Averaged speed for that direction ~421 kB/s
[19:09:36] + Received work.
[19:09:36] + Closed connections
[19:09:41]
[19:09:41] + Processing work unit
[19:09:41] Work type a1 not eligible for variable processors
[19:09:41] Core required: FahCore_a1.exe
[19:09:41] Core found.
[19:09:41] Using generic mpiexec calls
[19:09:41] Working on queue slot 09 [October 7 19:09:41 UTC]
[19:09:41] + Working ...
[19:09:41] - Calling 'mpiexec -np 4 -channel auto -host 127.0.0.1 FahCore_a1.exe -dir work/ -suffix 09 -checkpoint 15 -forceasm -verbose -lifeline 3568 -version 622'
[19:09:42]
[19:09:42] *------------------------------*
[19:09:42] Folding@Home Gromacs SMP Core
[19:09:42] Version 1.74 (March 10, 2007)
[19:09:42]
[19:09:42] Preparing to commence simulation
[19:09:42] - Ensuring status. Please wait.
[19:09:59] - Assembly optimizations manually forced on.
[19:09:59] - Not checking prior termination.
[19:10:11] - Expanded 4745966 -> 24426905 (decompressed 514.6 percent)
[19:10:11] - Starting from initial work packet
[19:10:11]
[19:10:11] Project: 2665 (Run 3, Clone 827, Gen 25)
[19:10:11]
[19:10:12] Assembly optimizations on if available.
[19:10:12] Entering M.D.
[19:10:12] e 827, Gen 25)
[19:10:12]
[19:10:14] Assembly optimizations on if available.
[19:10:14] Entering M.D.
[19:10:20] Rejecting checkpoint
[19:10:21] Protein: HGG in water
[19:10:21] Writing local files
[19:10:29] Extra SSE boost OK.
[19:10:29] Writing local files
[19:10:30] Completed 0 out of 250000 steps  (0 percent)
[19:17:14] G- Writing 9958 bytes of core data to disk...
[19:17:14]   ... Done.
[19:17:14] - Failed to delete work/wudata_09.arc
[19:17:14] No C.P. to delete.
[19:17:14] - Failed to delete work/wudat- Failed to delete work/wudata_09.sas
[19:17:14] - Failed to delete work/wudata_09.goe
[19:17:14] War
[19:17:14] Folding@home Core Shutdown: EARLY_UNIT_END
[19:17:14] Finalizing output
[19:19:14] Y_UNIT_END
[19:19:14]
[19:19:14] Folding@home Core Shutdown: EARLY_UNIT_END
[19:19:18] CoreStatus = 7B (123)
[19:19:18] Client-core communications error: ERROR 0x7b
[19:19:18] Deleting current work unit & continuing...
[19:19:18] Using generic mpiexec calls
[19:21:38] - Warning: Could not delete all work unit files (9): Core returned invalid code
[19:21:38] Trying to send all finished work units
[19:21:38] + No unsent completed units remaining.
[19:21:38] - Preparing to get new work unit...
[19:21:38] + Attempting to get work packet
[19:21:38] - Will indicate memory of 2046 MB
[19:21:38] - Connecting to assignment server
[19:21:38] Connecting to http://assign.stanford.edu:8080/
[19:21:38] Posted data.
[19:21:38] Initial: 40AB; - Successful: assigned to (171.64.65.64).
[19:21:38] + News From Folding@Home: Welcome to Folding@Home
[19:21:38] Loaded queue successfully.
[19:21:38] Connecting to http://171.64.65.64:8080/
[19:21:44] Posted data.
[19:21:44] Initial: 0000; - Receiving payload (expected size: 4746478)
[19:21:59] - Downloaded at ~309 kB/s
[19:21:59] - Averaged speed for that direction ~399 kB/s
[19:21:59] + Received work.
[19:21:59] + Closed connections
[19:22:04]
[19:22:04] + Processing work unit
[19:22:04] Work type a1 not eligible for variable processors
[19:22:04] Core required: FahCore_a1.exe
[19:22:04] Core found.
[19:22:04] Using generic mpiexec calls
[19:22:04] Working on queue slot 00 [October 7 19:22:04 UTC]
[19:22:04] + Working ...
[19:22:04] - Calling 'mpiexec -np 4 -channel auto -host 127.0.0.1 FahCore_a1.exe -dir work/ -suffix 00 -checkpoint 15 -forceasm -verbose -lifeline 3568 -version 622'
[19:22:05]
[19:22:05] *------------------------------*
[19:22:05] Folding@Home Gromacs SMP Core
[19:22:05] Version 1.74 (March 10, 2007)
[19:22:05]
[19:22:05] Preparing to commence simulation
[19:22:05] - Ensuring status. Please wait.
[19:22:22] - Assembly optimizations manually forced on.
[19:22:22] - Not checking prior termination.
[19:22:33] - Expanded 4745966 -> 24426905 (decompressed 514.6 percent)
[19:22:34] - Starting from initial work packet
[19:22:34]
[19:22:34] Project: 2665 (Run 3, Clone 827, Gen 25)
[19:22:34]
[19:22:35] Assembly optimizations on if available.
[19:22:35] Entering M.D.
[19:22:42] Rejecting checkpoint
[19:22:44] Protein: HGG in water
[19:22:44] Writing local files
[19:22:51] Extra SSE boost OK.
[19:22:52] Writing local files
[19:22:52] Completed 0 out of 250000 steps  (0 percent)
[19:29:39]
[19:29:39] - Writing 9958 bytes of core data to disk...
[19:29:39]   ... Done.
[19:29:39] - Failed to delete work/wudata_00.xtc
[19:29:39] No C.P. to delete.
[19:29:39] - Failed to delete work/wudata_00.sas
[19:29:39] - Failed to delete work/wudat- Failed to delete work/wudata_00.sas
[19:29:39] - F
[19:29:39] Folding@home Core Shutdown: EARLY_UNIT_END
[19:29:39] Finalizing output
[19:29:39] iles
[19:31:39]
[19:31:39] Folding@home Core Shutdown: EARLY_UNIT_END
[19:31:39]
[19:31:43] CoreStatus = 7B (123)
[19:31:43] Client-core communications error: ERROR 0x7b
[19:31:43] - Attempting to download new core...
