Project 2665 (Run 3, Clone 298, Gen 54)
mosh5382
Post by mosh5382 »
I completed this work unit early this morning and I'm pretty sure it was within the deadline. The unit did complete to 100% but then errored out with "Client-core communications error: ERROR 0x7b". I had to use qfix to make it "sendable" but it appears to have sent correctly. Here is a portion of my log file:
[07:14:05] Completed 247500 out of 250000 steps  (99 percent)
[08:05:24] Writing local files
[08:05:26] Completed 250000 out of 250000 steps  (100 percent)
[08:05:26] Writing final coordinates.
[08:05:29] Past main M.D. loop
[08:05:29] Will end MPI now
[08:06:29]
[08:06:29] Finished Work Unit:
[08:06:29] - Reading up to 21310704 from "work/wudata_07.arc": Read 21310704
[08:06:29] - Reading up to 658872 from "work/wudata_07.xtc": Read 658872
[08:06:29] goefile size: 0
[08:06:29] logfile size: 231086
[08:06:29] Leaving Run
[08:06:34] - Writing 22207882 bytes of core data to disk...
[08:06:36]   ... Done.
[08:06:36] - Failed to delete work/wudata_07.sas
[08:06:36] - Failed to delete work/wudata_07.goe
[08:06:36] Warning:  check for stray files
[08:06:36] - Shutting down core
[08:08:36]
[08:08:36] Folding@home Core Shutdown: FINISHED_UNIT
[08:08:36]
[08:08:41] CoreStatus = 7B (123)
[08:08:41] Client-core communications error: ERROR 0x7b
[08:08:41] Deleting current work unit & continuing...
[08:08:41] Using generic mpiexec calls
[08:10:51] - Preparing to get new work unit...
[08:10:51] + Attempting to get work packet
[08:10:51] - Connecting to assignment server
[08:10:51] - Successful: assigned to (171.64.65.64).
[08:10:51] + News From Folding@Home: Welcome to Folding@Home
[08:10:52] Loaded queue successfully.
[08:10:52] + Could not connect to Work Server
[08:10:52] - Attempt #1  to get work failed, and no other work to do.
Waiting before retry.
[08:11:09] + Attempting to get work packet
[08:11:09] - Connecting to assignment server
[08:11:09] - Successful: assigned to (171.64.65.64).
[08:11:09] + News From Folding@Home: Welcome to Folding@Home
[08:11:09] Loaded queue successfully.
[08:11:31] + Closed connections
[08:11:36]
[08:11:36] + Processing work unit
[08:11:36] Work type a1 not eligible for variable processors
[08:11:36] Core required: FahCore_a1.exe
[08:11:36] Core found.
[08:11:36] Using generic mpiexec calls
[08:11:36] Working on queue slot 08 [October 7 08:11:36 UTC]
[08:11:36] + Working ...
[08:11:41]
[08:11:41] *------------------------------*
[08:11:41] Folding@Home Gromacs SMP Core
[08:11:41] Version 1.74 (March 10, 2007)
[08:11:41]
[08:11:41] Preparing to commence simulation
[08:11:41] - Ensuring status. Please wait.
[08:11:50] - Starting from initial work packet
[08:11:51]
[08:11:51] Project: 2665 (Run 1, Clone 786, Gen 56)
[08:11:51]
[08:11:53] Assembly optimizations on if available.
[08:11:53] Entering M.D.
[08:12:18] al work packet
[08:12:18]
[08:12:18] Project: 2665 (Run 1, Clone 786, Gen 56)
[08:12:18]
[08:12:22] 65 (Run 1, Clone 786, Gen 56)
[08:12:22]
[08:12:26] Entering M.D.
[08:12:32] Rejecting checkpoint
[08:12:36] Protein: IBX in water
[08:12:36] Writing local files
[08:12:51] Extra SSE boost OK.
[08:12:52] Writing local files
[08:12:53] Completed 0 out of 250000 steps  (0 percent)
[09:02:29] Writing local files
[09:02:29] Completed 2500 out of 250000 steps  (1 percent)
[09:52:03] Writing local files
[09:52:04] Completed 5000 out of 250000 steps  (2 percent)
[10:41:41] Writing local files
[10:41:41] Completed 7500 out of 250000 steps  (3 percent)
[11:31:20] Writing local files
[11:31:20] Completed 10000 out of 250000 steps  (4 percent)
[12:20:58] Writing local files
[12:20:58] Completed 12500 out of 250000 steps  (5 percent)
[13:10:30] Writing local files
[13:10:30] Completed 15000 out of 250000 steps  (6 percent)
Folding@Home Client Shutdown at user request.
Folding@Home Client Shutdown.
--- Opening Log file [October 7 13:42:50 UTC]
                       Folding@Home Client Version 6.22 SMP Beta2r3
                          http://folding.stanford.edu
Launch directory: C:\Documents and Settings\cmosher\fah
Executable: Folding@home-Win32-x86.exe
Arguments: -send all
[13:42:50] - Ask before connecting: No
[13:42:50] - User name: mosh5382 (Team 11298)
[13:42:50] - User ID: 739D74162AEE2D7B
[13:42:50] - Machine ID: 1
[13:42:50]
[13:42:50] Loaded queue successfully.
[13:42:50] Attempting to return result(s) to server...
[13:42:50] Project:
[13:42:50] - Read packet limit of 540015616... Set to 524286976.
[13:42:50] + Attempting to send results [October 7 13:42:50 UTC]
[13:49:43] + Results successfully sent
[13:49:43] Thank you for your contribution to Folding@Home.
[13:49:43] + Number of Units Completed: 4
I have not received credit for the WU so I was hoping you received it. I appoligize if this is not the correct place to post this message. As you can see I'm new to the forum.
Re: Project 2665 (Run 3, Clone 298, Gen 54)
Hi mosh5382 (team 11298),
Your WU (P2665 R3 C298 G54) was added to the stats database on 2008-10-07 08:47:37 for 0 points of credit.
The error code indicates it's a duplicate result (but it's the only report from you ... two other people completed it successfully without issue).
