Project: 2665 (Run 0, Clone 98, Gen 35)
ElectricVehicle
Post by ElectricVehicle »
[15:53:20] Completed 7500 out of 250000 steps (3 percent)
[16:01:14] files
[16:01:14] : long 1-4 interactions
[16:03:14] wn: EARLY_UNIT_END
[16:03:14] Finalizing output
[16:10:29] - Autosending finished units... [October 6 16:10:29 UTC]
[16:10:29] Trying to send all finished work units
[16:10:29] + No unsent completed units remaining.
[16:10:29] - Autosend completed
client hung....
                       Folding@Home Client Version 6.22 SMP Beta2r3
                          http://folding.stanford.edu
Launch directory: C:\Fah
Executable: C:\Fah\Folding@home-Win32-x86.exe
Arguments: -smp -verbosity 9
[09:26:41] - Ask before connecting: No
[09:26:41] - User name: [EV]Solar (Team 104636)
[09:26:41] - User ID: 37D9A66E498A77C3
[09:26:41] - Machine ID: 1
[14:52:31] *------------------------------*
[14:52:31] Folding@Home Gromacs SMP Core
[14:52:31] Version 1.74 (March 10, 2007)
[14:52:31]
[14:52:31] Preparing to commence simulation
[14:52:31] - Looking at optimizations...
[14:52:31] - Created dyn
[14:52:31] - Files status OK
[14:52:39] - Expanded 4746293 -> 24426905 (decompressed 514.6 percent)
[14:52:39] - Starting from initial work packet
[14:52:39]
[14:52:39] Project: 2665 (Run 0, Clone 98, Gen 35)
[14:52:39]
[14:52:39] Assembly optimizations on if available.
[14:52:39] Entering M.D.
[14:53:00] ial work packet
[14:53:00]
[14:53:00] Project: 2665 (Run 0, Clone 98, Gen 35)
[14:53:00]
[14:53:00] Entering M.D.
[14:53:08] one 98, Gen 35)
[14:53:08]
[14:53:08] Entering M.D.
[14:53:14] Warning:  cannot record process ID
[14:53:14] Rejecting checkpoint
[14:53:16]
[14:53:16] Writing local files
[14:53:16]
[14:53:27] Extra SSE boost OK.
[14:53:27] Writing local files
[14:53:28] Completed 0 out of 250000 steps  (0 percent)
[15:13:25] Writing local files
[15:13:25] Completed 2500 out of 250000 steps  (1 percent)
[15:33:22] Writing local files
[15:33:22] Completed 5000 out of 250000 steps  (2 percent)
[15:53:20] Writing local files
[16:01:14]  files
Fold On! (with 100% Renewable, 0 Carbon electricity) ElectricVehicle EV1, RAV4 EV, LEAF, Bolt EV, Volt, M3, s4 Simulator
Re: Project: 2665 (Run 0, Clone 98, Gen 35)
There's no data for this WU yet ...
Did you send partial results with qfix ?
ElectricVehicle
No, I didn't qfix. If I get a rash of bad WU's again, I'll try to qfix more often. But with 2 SMP clients on the same computer you have to make sure to back up the good WUs and stop in the right sequence or you risk losing good work. At the time I had two other WUs that were over 50% done when I noticed the bad WUs, so I left it alone.
Good news is between 4 SMP clients on two quad core computers, I've probably finished about 10 consecutive WU's with no issues and the computers have not had anything changed, just the WUs changed. So it looks like someone managed to collect or stop the bad WU's that were causing us all problems!
Now if the slow server upload gets fixed... (1-2 hours to upload to 171.64.65.64) I understand they're working on new server code that may fix this at some time in the future.
You should update your client to v6.23 : viewtopic.php?f=46&t=6143 ;)
