Project: 2665 (Run 2, Clone 447, Gen 52)
osgorth
Post by osgorth »
Well, looks like I ran into problems with this one.
[07:51:22] Project: 2665 (Run 2, Clone 447, Gen 52)
<snip>
[12:00:55] Completed 40000 out of 250000 steps  (16 percent)
[12:06:15] Warning:  long 1-4 interactions
[12:06:16] Quit 101 - NaN detected: (ener[20])
[12:06:16]
[12:06:16] Simulation instability has been encountered. The run has entered a
[12:06:16]   state from which no further progress can be made.
[12:06:16] This may be the correct result of the simulation, however if you
[12:06:16]   often see other project units terminating early like this
[12:06:16]   too, you may wish to check the stability of your computer (issues
[12:06:16]   such as high temperature, overclocking, etc.).
[12:06:16] Going to send back what have done.
[12:06:16] logfile size: 39092
[12:06:16] - Writing 39642 bytes of core data to disk...
[12:06:16]   ... Done.
[12:06:16] No C.P. to delete.
[12:08:16]
[12:08:16] Folding@home Core Shutdown: EARLY_UNIT_END
[12:08:16]
[12:08:19] CoreStatus = 7B (123)
[12:08:19] Client-core communications error: ERROR 0x7b
[12:08:19] This is a sign of more serious problems, shutting down.
Moved the queue to another box and reprocessing it now, see if it fails again.
Re: Project: 2665 (Run 2, Clone 447, Gen 52)
There is 3 reports for partial credit for this WU.
You should run qfix, and move to an other WU.
osgorth
Post by osgorth »
It failed again.. So yeah. I ran qfix but that didn't help. Had to launch a new SMP client in a different work dir, and now I finally got a new WU!
