Project: 2665 (Run 0, Clone 810, Gen 35)
mikeb12
Post by mikeb12 »
Vista 64 6.23 mpich
just reporting the wu. since I noticed gen 34 had a report also from August.
viewtopic.php?f=19&t=4925
this is gen 35.
[07:44:43] Project: 2665 (Run 0, Clone 810, Gen 35)
[07:44:43]
[07:44:43] Assembly optimizations on if available.
[07:44:43] Entering M.D.
[07:45:03] al work packet
[07:45:03]
[07:45:03] Project: 2665 (Run 0, Clone 810, Gen 35)
[07:45:03]
[07:45:04] 65 (Run 0, Clone 810, Gen 35)
[07:45:04]
[07:45:04] Entering M.D.
[07:45:12] Rejecting checkpoint
[07:45:14] Protein: HGG in water
[07:45:14] Writing local files
[07:45:21] Extra SSE boost OK.
[07:45:21] Writing local files
[07:45:22] Completed 0 out of 250000 steps  (0 percent)
[08:03:48] Writing local files
[08:03:48] Completed 2500 out of 250000 steps  (1 percent)
[08:20:46] Writing local files
[08:20:46] Completed 5000 out of 250000 steps  (2 percent)
[08:25:36]  often see other project units terminating early like this
[08:25:36]   too, you may wish to check the stability of youlogfile size: 12967
[08:25:36] - Writing 13517 bytes of core data to disk...
[08:25:36]   ... Done.
[08:25:36] e size: 12967
[08:25:36] re data to disk...
[08:25:36] - Failed to delete work/wudata_08.bed
[08:25:36] Warning:  check for stray files
[08:25:36]
[08:25:36] Folding@home Core Shutdown: EARLY_UNIT_END
[08:25:36] Finalizing output
[08:25:36] , etc.).
[08:25:36] Going to send back what have done.
[08:25:36] logfile size: 9422
[08:25:36] - Writing 9972 bytes of core data to disk...
[08:27:36]
[08:27:36] Folding@home Core Shutdown: EARLY_UNIT_END
[08:27:36]
[08:27:40] CoreStatus = 7B (123)
[08:27:40] Sending work to server
[08:27:40] Project: 2665 (Run 0, Clone 810, Gen 35)
[08:27:40] + Attempting to send results [October 6 08:27:40 UTC]
[08:27:41] + Results successfully sent
[08:27:41] Thank you for your contribution to Folding@Home.
[08:27:45] - Preparing to get new work unit...
[08:27:45] + Attempting to get work packet
[08:27:45] - Connecting to assignment server
[08:27:46] - Successful: assigned to (171.64.65.64).
[08:27:46] + News From Folding@Home: Welcome to Folding@Home
[08:27:46] Loaded queue successfully.
[08:28:20] + Closed connections
[08:28:25]
[08:28:25] + Processing work unit
[08:28:25] Work type a1 not eligible for variable processors
[08:28:25] Core required: FahCore_a1.exe
[08:28:25] Core found.
[08:28:25] Using generic mpiexec calls
[08:28:25] Working on queue slot 09 [October 6 08:28:25 UTC]
[08:28:25] + Working ...
[08:28:25]
[08:28:25] *------------------------------*
[08:28:25] Folding@Home Gromacs SMP Core
[08:28:25] Version 1.74 (March 10, 2007)
[08:28:25]
[08:28:25] Preparing to commence simulation
[08:28:25] - Ensuring status. Please wait.
[08:28:30] - Starting from initial work packet
[08:28:30]
[08:28:30] Project: 2665 (Run 2, Clone 750, Gen 55)
[08:28:30]
[08:28:30] Assembly optimizations on if available.
[08:28:30] Entering M.D.
[08:28:49] al work packet
[08:28:49]
[08:28:49] Project: 2665 (Run 2, Clone 750, Gen 55)
[08:28:49]
[08:28:50] Entering M.D.
[08:28:51] ne 750, Gen 55)
[08:28:51]
[08:28:52] Entering M.D.
[08:28:59] Rejecting checkpoint
[08:29:02] Protein: HGG with glycosylations
[08:29:02] Writing local files
[08:29:11] Extra SSE boost OK.
[08:29:11] Writing local files
[08:29:12] Completed 0 out of 250000 steps  (0 percent)
[08:47:21] Writing local files
[08:47:21] Completed 2500 out of 250000 steps  (1 percent)
[09:04:42] Writing local files
[09:04:42] Completed 5000 out of 250000 steps  (2 percent)
[09:21:28] Writing local files
[09:21:28] Completed 7500 out of 250000 steps  (3 percent)
[09:38:11] Writing local files
[09:38:11] Completed 10000 out of 250000 steps  (4 percent)
[09:55:04] Writing local files
[09:55:04] Completed 12500 out of 250000 steps  (5 percent)
[10:11:44] Writing local files
[10:11:45] Completed 15000 out of 250000 steps  (6 percent)
[10:28:26] Writing local files
[10:28:26] Completed 17500 out of 250000 steps  (7 percent)
[10:45:06] Writing local files
[10:45:07] Completed 20000 out of 250000 steps  (8 percent)
[11:01:47] Writing local files
[11:01:47] Completed 22500 out of 250000 steps  (9 percent)
[11:18:27] Writing local files
[11:18:27] Completed 25000 out of 250000 steps  (10 percent)
[11:35:14] Writing local files
[11:35:14] Completed 27500 out of 250000 steps  (11 percent)
Re: Project: 2665 (Run 0, Clone 810, Gen 35)
There is an other report for partial credit for this WU. :(
